or1k.h
1
5 /*
6  * This file contains information pertaining to the OR1K processor.
7  *
8  * COPYRIGHT (c) 2014 Hesham ALMatary <heshamelmatary@gmail.com>
9  *
10  * Based on code with the following copyright...
11  * COPYRIGHT (c) 1989-1999, 2010.
12  * On-Line Applications Research Corporation (OAR).
13  *
14  * The license and distribution terms for this file may be
15  * found in the file LICENSE in this distribution or at
16  * http://www.rtems.org/license/LICENSE.
17  */
18
19 #ifndef _RTEMS_SCORE_OR1K_H
20 #define _RTEMS_SCORE_OR1K_H
21
22 #ifdef __cplusplus
23 extern "C" {
24 #endif
25
26 /*
27  * This file contains the information required to build
28  * RTEMS for a particular member of the OR1K family.
29  * It does this by setting variables to indicate which
30  * implementation dependent features are present in a particular
31  * member of the family.
32  *
33  * This is a good place to list all the known CPU models
34  * that this port supports and which RTEMS CPU model they correspond
35  * to.
36  */
37
38  /*
39  * Define the name of the CPU family and specific model.
40  */
41
42 #define CPU_NAME "OR1K"
43 #define CPU_MODEL_NAME "OR1200"
44
45 #ifdef __cplusplus
46 }
47 #endif
48
49 #endif /* _RTEMS_SCORE_OR1K_H */
