admin
rtems-admin.git
doxygen
builder
latest
rtems.git
score
cpu
no_cpu
score
no_cpu.h
1
/* no_cpu.h
2
3
* This file sets up basic CPU dependency settings based on
4
* compiler settings. For example, it can determine if
5
* floating point is available. This particular implementation
6
* is specified to the NO CPU port.
7
8
9
* COPYRIGHT (c) 1989-1999.
10
* On-Line Applications Research Corporation (OAR).
11
12
* The license and distribution terms for this file may be
13
* found in the file LICENSE in this distribution or at
14
* http://www.rtems.org/license/LICENSE.
15
16
17
18
#ifndef _RTEMS_SCORE_NO_CPU_H
19
#define _RTEMS_SCORE_NO_CPU_H
20
21
#ifdef __cplusplus
22
extern
"C"
23
#endif
24
25
26
* This file contains the information required to build
27
* RTEMS for a particular member of the NO CPU family.
28
* It does this by setting variables to indicate which
29
* implementation dependent features are present in a particular
30
* member of the family.
31
32
* This is a good place to list all the known CPU models
33
* that this port supports and which RTEMS CPU model they correspond
34
* to.
35
36
37
#if defined(rtems_multilib)
38
39
* Figure out all CPU Model Feature Flags based upon compiler
40
* predefines.
41
42
43
#define CPU_MODEL_NAME "rtems_multilib"
44
#define NOCPU_HAS_FPU 1
45
46
#elif defined(no_cpu)
47
48
#define CPU_MODEL_NAME "no_cpu_model"
49
50
51
#else
52
53
#error "Unsupported CPU Model"
54
55
#endif
56
57
58
* Define the name of the CPU family.
59
60
61
#define CPU_NAME "NO CPU"
62
63
#ifdef __cplusplus
64
65
#endif
66
67
#endif
/* _RTEMS_SCORE_NO_CPU_H */
