void | nis_freeresult () |
nis_result * | nis_lookup () |
nis_result * | nis_list () |
nis_result * | nis_add () |
nis_result * | nis_remove () |
nis_result * | nis_modify () |
nis_result * | nis_add_entry () |
nis_result * | nis_remove_entry () |
nis_result * | nis_modify_entry () |
nis_result * | nis_first_entry () |
nis_result * | nis_next_entry () |
nis_error | nis_mkdir () |
nis_error | nis_rmdir () |
name_pos | nis_dir_cmp () |
nis_name * | nis_getnames () |
void | nis_freenames () |
nis_name | nis_domain_of () |
nis_name | nis_leaf_of () |
nis_name | nis_leaf_of_r () |
nis_name | nis_name_of () |
nis_name | nis_local_group () |
nis_name | nis_local_directory () |
nis_name | nis_local_principal () |
nis_name | nis_local_host () |
void | nis_destroy_object () |
nis_object * | nis_clone_object () |
void | nis_print_object () |
char * | nis_sperrno () |
void | nis_perror () |
char * | nis_sperror () |
void | nis_lerror () |
void | nis_print_group_entry () |
bool_t | nis_ismember () |
nis_error | nis_creategroup () |
nis_error | nis_destroygroup () |
nis_error | nis_addmember () |
nis_error | nis_removemember () |
nis_error | nis_verifygroup () |
void | nis_freeservlist () |
nis_server ** | nis_getservlist () |
nis_error | nis_stats () |
nis_error | nis_servstate () |
void | nis_freetags () |
nis_result * | nis_checkpoint () |
void | nis_ping () |
char ** | __break_name () |
int | __name_distance () |
nis_result * | nis_make_error () |
nis_attr * | __cvt2attr () |
void | nis_free_request () |
nis_error | nis_get_request () |
nis_object * | nis_read_obj () |
int | nis_write_obj () |
int | nis_in_table () |
int | nis_insert_item () |
NIS_HASH_ITEM * | nis_find_item () |
NIS_HASH_ITEM * | nis_remove_item () |
void | nis_insert_name () |
void | nis_remove_name () |
CLIENT * | nis_make_rpchandle () |
void * | nis_get_static_storage () |
char * | nis_data () |
void | nis_print_rights () |
void | nis_print_directory () |
void | nis_print_group () |
void | nis_print_table () |
void | nis_print_link () |
void | nis_print_entry () |
nis_object * | nis_get_object () |
nis_server * | __nis_init_callback () |
int | nis_getdtblsize () |
int | __nis_run_callback () |
log_result * | nis_dump () |
log_result * | nis_dumplog () |
bool_t | __do_ismember () |
nis_name | __nis_map_group () |
nis_name | __nis_map_group_r () |
nis_error | __nis_CacheBind () |
directory_obj * | __nis_CacheSearch () |
bool_t | __nis_CacheRemoveEntry () |
void | __nis_CacheRestart () |
void | __nis_CachePrint () |
void | __nis_CacheDumpStatistics () |
bool_t | writeColdStartFile () |
CLIENT * | __get_ti_clnt () |
int | __strcmp_case_insens () |
int | __strncmp_case_insens () |
fd_result * | nis_finddirectory () |
int | __start_clock () |
u_long | __stop_clock () |
struct signature * | __nis_calculate_encrypted_cksum () |
