admin
rtems-admin.git
doxygen
builder
latest
rtems.git
score
cpu
nios2
score
nios2.h
1
13
14
* COPYRIGHT (c) 1989-1999.
15
* On-Line Applications Research Corporation (OAR).
16
17
* The license and distribution terms for this file may be
18
* found in the file LICENSE in this distribution or at
19
* http://www.rtems.org/license/LICENSE.
20
21
22
23
#ifndef _RTEMS_SCORE_NIOS2_H
24
#define _RTEMS_SCORE_NIOS2_H
25
26
#ifdef __cplusplus
27
extern
"C"
28
#endif
29
30
31
* This file contains the information required to build
32
* RTEMS for a particular member of the NIOS2 family.
33
* It does this by setting variables to indicate which
34
* implementation dependent features are present in a particular
35
* member of the family.
36
37
* This is a good place to list all the known CPU models
38
* that this port supports and which RTEMS CPU model they correspond
39
* to.
40
41
42
43
* Define the name of the CPU family and specific model.
44
45
46
#define CPU_NAME "NIOS2"
47
#define CPU_MODEL_NAME "nios2"
48
49
50
* See also nios2-rtems-gcc -print-multi-lib for all valid combinations of
51
52
* -mno-hw-mul
53
* -mhw-mulx
54
* -mstack-check
55
* -pg
56
* -EB
57
* -mcustom-fpu-cfg=60-1
58
* -mcustom-fpu-cfg=60-2
59
60
61
#ifdef __cplusplus
62
63
#endif
64
65
#endif
/* _RTEMS_SCORE_NIOS2_H */
