admin
rtems-admin.git
doxygen
builder
latest
rtems.git
libnetworking
nfsclient
nfsargs.h
1
2
* Copyright (c) 1989, 1993, 1995
3
* The Regents of the University of California. All rights reserved.
4
5
* This code is derived from software contributed to Berkeley by
6
* Rick Macklem at The University of Guelph.
7
8
9
* modification, are permitted provided that the following conditions
10
* are met:
11
* 1. Redistributions of source code must retain the above copyright
12
* notice, this list of conditions and the following disclaimer.
13
* 2. Redistributions in binary form must reproduce the above copyright
14
* notice, this list of conditions and the following disclaimer in the
15
* documentation and/or other materials provided with the distribution.
16
* 4. Neither the name of the University nor the names of its contributors
17
* may be used to endorse or promote products derived from this software
18
* without specific prior written permission.
19
20
* THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
21
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
22
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
23
* ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
24
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
25
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
26
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
27
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
28
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
29
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
30
* SUCH DAMAGE.
31
32
* @(#)nfs.h 8.4 (Berkeley) 5/1/95
33
* $FreeBSD: src/sys/nfsclient/nfsargs.h,v 1.67 2005/01/07 01:45:51 imp Exp $
34
35
36
37
#ifndef _NFSCLIENT_NFSARGS_H_
38
#define _NFSCLIENT_NFSARGS_H_
39
40
41
* Arguments to mount NFS
42
43
struct
nfs_args
44
struct
sockaddr
*addr;
/* file server address */
45
int
addrlen;
/* length of address */
46
int
sotype;
/* Socket type */
47
int
proto;
/* and Protocol */
48
u_char *fh;
/* File handle to be mounted */
49
int
fhsize;
/* Size, in bytes, of fh */
50
int
flags;
/* flags */
51
int
wsize;
/* write size in bytes */
52
int
rsize;
/* read size in bytes */
53
int
readdirsize;
/* readdir size in bytes */
54
int
timeo;
/* initial timeout in .1 secs */
55
int
retrans;
/* times to retry send */
56
int
maxgrouplist;
/* Max. size of group list */
57
int
readahead;
/* # of blocks to readahead */
58
int
leaseterm;
/* Term (sec) of lease */
59
int
deadthresh;
/* Retrans threshold */
60
char
*hostname;
/* server's name */
61
62
63
64
* NFS mount option flags
65
66
#define NFSMNT_SOFT 0x00000001
/* soft mount (hard is default) */
67
#define NFSMNT_WSIZE 0x00000002
/* set write size */
68
#define NFSMNT_RSIZE 0x00000004
/* set read size */
69
#define NFSMNT_TIMEO 0x00000008
/* set initial timeout */
70
#define NFSMNT_RETRANS 0x00000010
/* set number of request retries */
71
#define NFSMNT_MAXGRPS 0x00000020
/* set maximum grouplist size */
72
#define NFSMNT_INT 0x00000040
/* allow interrupts on hard mount */
73
#define NFSMNT_NOCONN 0x00000080
/* Don't Connect the socket */
74
/* 0x100 free, was NFSMNT_NQNFS */
75
#define NFSMNT_NFSV3 0x00000200
/* Use NFS Version 3 protocol */
76
/* 0x400 free, was NFSMNT_KERB */
77
#define NFSMNT_DUMBTIMR 0x00000800
/* Don't estimate rtt dynamically */
78
/* 0x1000 free, was NFSMNT_LEASETERM */
79
#define NFSMNT_READAHEAD 0x00002000
/* set read ahead */
80
#define NFSMNT_DEADTHRESH 0x00004000
/* set dead server retry thresh */
81
#define NFSMNT_RESVPORT 0x00008000
/* Allocate a reserved port */
82
#define NFSMNT_RDIRPLUS 0x00010000
/* Use Readdirplus for V3 */
83
#define NFSMNT_READDIRSIZE 0x00020000
/* Set readdir size */
84
#define NFSMNT_ACREGMIN 0x00040000
85
#define NFSMNT_ACREGMAX 0x00080000
86
#define NFSMNT_ACDIRMIN 0x00100000
87
#define NFSMNT_ACDIRMAX 0x00200000
88
#define NFSMNT_NOLOCKD 0x00400000
/* Locks are local */
89
#define NFSMNT_NFSV4 0x00800000
/* Use NFS Version 4 protocol */
90
#define NFSMNT_HASWRITEVERF 0x01000000
/* NFSv4 Write verifier */
91
92
#endif
sockaddr
Definition:
socket.h:180
nfs_args
Definition:
nfsargs.h:44
