22 #ifndef _RTEMS_SCORE_MPPKT_H 23 #define _RTEMS_SCORE_MPPKT_H 52 MP_PACKET_MPCI_INTERNAL = 0,
54 MP_PACKET_MESSAGE_QUEUE = 2,
55 MP_PACKET_SEMAPHORE = 3,
56 MP_PACKET_PARTITION = 4,
65 #define MP_PACKET_CLASSES_FIRST MP_PACKET_MPCI_INTERNAL 70 #define MP_PACKET_CLASSES_LAST MP_PACKET_SIGNAL 102 #define MP_PACKET_MINIMUM_PACKET_SIZE 64 111 #define MP_PACKET_MINIMUN_HETERO_CONVERSION \ 112 ( sizeof( MP_packet_Prefix ) / sizeof( uint32_t ) ) MP_packet_Classes the_class
This field indicates the API class of the operation being performed.
Definition: mppkt.h:82
Constants and Structures Associated with the Object Handler.
Thread Priority Manipulation Routines.
The following record contains the prefix for every packet passed between nodes in an MP system...
Definition: mppkt.h:80
Priority_Control source_priority
This field is the priority of the originating thread.
Definition: mppkt.h:88
MP_packet_Classes
The following enumerated type defines the packet classes.
Definition: mppkt.h:51
Watchdog_Interval timeout
This field is the requested timeout for this operation.
Definition: mppkt.h:96
Constants and Structures Associated with Watchdog Timers.
Objects_Id source_tid
This field is the ID of the originating thread.
Definition: mppkt.h:86
Objects_Id id
This field is the id of the object to be acted upon.
Definition: mppkt.h:84
uint32_t Priority_Control
The following type defines the control block used to manage thread priorities.
Definition: score/include/rtems/score/priority.h:56
uint32_t to_convert
This field is the length of the data which required network conversion.
Definition: mppkt.h:94
uint32_t Watchdog_Interval
Type is used to specify the length of intervals.
Definition: watchdog.h:47
uint32_t length
This field is the length of the data following the prefix.
Definition: mppkt.h:92
uint32_t Objects_Id
The following type defines the control block used to manage object IDs.
Definition: score/include/rtems/score/object.h:122
uint32_t return_code
This field is where the status of the operation will be returned.
Definition: mppkt.h:90
