admin
rtems-admin.git
doxygen
builder
latest
rtems.git
libnetworking
sys
mount.h
1
2
* Copyright (c) 1989, 1991, 1993
3
* The Regents of the University of California. All rights reserved.
4
5
6
* modification, are permitted provided that the following conditions
7
* are met:
8
* 1. Redistributions of source code must retain the above copyright
9
* notice, this list of conditions and the following disclaimer.
10
* 2. Redistributions in binary form must reproduce the above copyright
11
* notice, this list of conditions and the following disclaimer in the
12
* documentation and/or other materials provided with the distribution.
13
* 4. Neither the name of the University nor the names of its contributors
14
* may be used to endorse or promote products derived from this software
15
* without specific prior written permission.
16
17
* THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
18
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
19
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20
* ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
21
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
22
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
23
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
24
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
25
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
26
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
27
* SUCH DAMAGE.
28
29
* @(#)mount.h 8.21 (Berkeley) 5/20/95
30
* $FreeBSD: src/sys/sys/mount.h,v 1.198 2005/08/06 01:42:04 ssouhlal Exp $
31
32
33
34
#ifndef _SYS_MOUNT_H_
35
#define _SYS_MOUNT_H_
36
37
#ifndef _KERNEL
38
sys/ucred.h
39
#endif
40
#include <sys/queue.h>
41
42
typedef
struct
fsid
{ int32_t val[2]; }
fsid_t
/* filesystem id type */
43
44
45
* File identifier.
46
* These are unique per filesystem on a single machine.
47
48
#define MAXFIDSZ 16
49
50
struct
fid
51
u_short fid_len;
/* length of data in bytes */
52
u_short fid_reserved;
/* force longword alignment */
53
char
fid_data[MAXFIDSZ];
/* data (variable length) */
54
55
56
57
* filesystem statistics
58
59
#define MFSNAMELEN 16
/* length of type name including null */
60
#define MNAMELEN 88
/* size of on/from name bufs */
61
62
63
* User specifiable flags.
64
65
#define MNT_RDONLY 0x00000001
/* read only filesystem */
66
#define MNT_SYNCHRONOUS 0x00000002
/* filesystem written synchronously */
67
#define MNT_NOEXEC 0x00000004
/* can't exec from filesystem */
68
#define MNT_NOSUID 0x00000008
/* don't honor setuid bits on fs */
69
#define MNT_NODEV 0x00000010
/* don't interpret special files */
70
#define MNT_UNION 0x00000020
/* union with underlying filesystem */
71
#define MNT_ASYNC 0x00000040
/* filesystem written asynchronously */
72
#define MNT_NOATIME 0x10000000
/* disable update of file access time */
73
74
75
* NFS export related mount flags.
76
77
#define MNT_EXRDONLY 0x00000080
/* exported read only */
78
#define MNT_EXPORTED 0x00000100
/* filesystem is exported */
79
#define MNT_DEFEXPORTED 0x00000200
/* exported to the world */
80
#define MNT_EXPORTANON 0x00000400
/* use anon uid mapping for everyone */
81
#define MNT_EXKERB 0x00000800
/* exported with Kerberos uid mapping */
82
#define MNT_EXPUBLIC 0x20000000
/* public export (WebNFS) */
83
84
85
* Flags set by internal operations,
86
* but visible to the user.
87
88
#define MNT_LOCAL 0x00001000
/* filesystem is stored locally */
89
#define MNT_QUOTA 0x00002000
/* quotas are enabled on filesystem */
90
#define MNT_ROOTFS 0x00004000
/* identifies the root filesystem */
91
#define MNT_USER 0x00008000
/* mounted by a user */
92
#define MNT_IGNORE 0x00800000
/* do not show entry in df */
93
94
95
* External filesystem command modifier flags.
96
* Unmount can use the MNT_FORCE flag.
97
98
#define MNT_UPDATE 0x00010000
/* not a real mount, just an update */
99
#define MNT_DELEXPORT 0x00020000
/* delete export host lists */
100
#define MNT_RELOAD 0x00040000
/* reload filesystem data */
101
#define MNT_FORCE 0x00080000
/* force unmount or readonly change */
102
103
104
* Generic file handle
105
106
struct
fhandle
107
fsid_t
fh_fsid;
/* Filesystem id of mount point */
108
struct
fid
fh_fid;
/* Filesys specific id */
109
110
typedef
struct
fhandle
fhandle_t;
111
112
#ifdef _KERNEL
113
114
#else
/* !_KERNEL */
115
116
#include <sys/cdefs.h>
117
118
#endif
/* _KERNEL */
119
120
#endif
/* !_SYS_MOUNT_H_ */
fsid
Definition:
mount.h:43
fhandle
Definition:
mount.h:107
ucred.h
fid
Definition:
mount.h:51
