rtems_id | rtems_monitor_id_fixup (rtems_id id, uint32_t default_node, rtems_monitor_object_type_t type) |
const rtems_monitor_object_info_t * | rtems_monitor_object_lookup (rtems_monitor_object_type_t type) |
rtems_id | rtems_monitor_object_canonical_next (const rtems_monitor_object_info_t *info, rtems_id id, void *canonical) |
rtems_id | rtems_monitor_object_canonical_get (rtems_monitor_object_type_t type, rtems_id id, void *canonical, size_t *size_p) |
void | rtems_monitor_object_cmd (int argc, char **argv, const rtems_monitor_command_arg_t *command_arg, bool verbose) |
