admin
rtems-admin.git
doxygen
builder
latest
rtems.git
score
cpu
mips
score
mips.h
1
14
15
* COPYRIGHT (c) 1989-2001.
16
* On-Line Applications Research Corporation (OAR).
17
18
* The license and distribution terms for this file may be
19
* found in the file LICENSE in this distribution or at
20
* http://www.rtems.org/license/LICENSE.
21
22
23
#ifndef _RTEMS_SCORE_MIPS_H
24
#define _RTEMS_SCORE_MIPS_H
25
34
#ifdef __cplusplus
35
extern
"C"
36
#endif
37
38
#ifndef ASM
39
rtems/mips/idtcpu.h
40
#endif
41
42
43
* SR bits that enable/disable interrupts
44
45
* NOTE: XXX what about SR_ERL?
46
47
48
#if (__mips == 3) || (__mips == 32)
49
#ifdef ASM
50
#define SR_INTERRUPT_ENABLE_BITS 0x01
51
#else
52
#define SR_INTERRUPT_ENABLE_BITS SR_IE
53
#endif
54
55
#elif __mips == 1
56
#define SR_INTERRUPT_ENABLE_BITS SR_IEC
57
58
#else
59
#error "mips interrupt enable bits: unknown architecture level!"
60
#endif
61
62
63
* This file contains the information required to build
64
* RTEMS for a particular member of the "no cpu"
65
* family when executing in protected mode. It does
66
* this by setting variables to indicate which implementation
67
* dependent features are present in a particular member
68
* of the family.
69
70
71
#if defined(__mips_soft_float)
72
#define MIPS_HAS_FPU 0
73
#else
74
#define MIPS_HAS_FPU 1
75
#endif
76
77
78
#if (__mips == 1)
79
#define CPU_MODEL_NAME "ISA Level 1 or 2"
80
#elif (__mips == 3) || (__mips == 32)
81
#if defined(__mips64)
82
#define CPU_MODEL_NAME "ISA Level 4"
83
#else
84
#define CPU_MODEL_NAME "ISA Level 3"
85
#endif
86
#else
87
#error "Unknown MIPS ISA level"
88
#endif
89
90
91
* Define the name of the CPU family.
92
93
94
#define CPU_NAME "MIPS"
95
96
97
* RTEMS Vector numbers for exception conditions. This is a direct
98
* map to the causes.
99
100
101
#define MIPS_EXCEPTION_BASE 0
102
103
#define MIPS_EXCEPTION_INT MIPS_EXCEPTION_BASE+0
104
#define MIPS_EXCEPTION_MOD MIPS_EXCEPTION_BASE+1
105
#define MIPS_EXCEPTION_TLBL MIPS_EXCEPTION_BASE+2
106
#define MIPS_EXCEPTION_TLBS MIPS_EXCEPTION_BASE+3
107
#define MIPS_EXCEPTION_ADEL MIPS_EXCEPTION_BASE+4
108
#define MIPS_EXCEPTION_ADES MIPS_EXCEPTION_BASE+5
109
#define MIPS_EXCEPTION_IBE MIPS_EXCEPTION_BASE+6
110
#define MIPS_EXCEPTION_DBE MIPS_EXCEPTION_BASE+7
111
#define MIPS_EXCEPTION_SYSCALL MIPS_EXCEPTION_BASE+8
112
#define MIPS_EXCEPTION_BREAK MIPS_EXCEPTION_BASE+9
113
#define MIPS_EXCEPTION_RI MIPS_EXCEPTION_BASE+10
114
#define MIPS_EXCEPTION_CPU MIPS_EXCEPTION_BASE+11
115
#define MIPS_EXCEPTION_OVERFLOW MIPS_EXCEPTION_BASE+12
116
#define MIPS_EXCEPTION_TRAP MIPS_EXCEPTION_BASE+13
117
#define MIPS_EXCEPTION_VCEI MIPS_EXCEPTION_BASE+14
118
/* FPE only on mips2 and higher */
119
#define MIPS_EXCEPTION_FPE MIPS_EXCEPTION_BASE+15
120
#define MIPS_EXCEPTION_C2E MIPS_EXCEPTION_BASE+16
121
/* 17-22 reserved */
122
#define MIPS_EXCEPTION_WATCH MIPS_EXCEPTION_BASE+23
123
/* 24-30 reserved */
124
#define MIPS_EXCEPTION_VCED MIPS_EXCEPTION_BASE+31
125
126
#define MIPS_INTERRUPT_BASE MIPS_EXCEPTION_BASE+32
127
128
129
* Some macros to access registers
130
131
132
#define mips_get_sr( _x ) \
133
do { \
134
__asm__ volatile( "mfc0 %0, $12; nop" : "=r" (_x) : ); \
135
} while (0)
136
137
#define mips_set_sr( _x ) \
138
do { \
139
register unsigned int __x = (_x); \
140
__asm__ volatile( "mtc0 %0, $12; nop" : : "r" (__x) ); \
141
} while (0)
142
143
144
145
* Access the Cause register
146
147
148
#define mips_get_cause( _x ) \
149
do { \
150
__asm__ volatile( "mfc0 %0, $13; nop" : "=r" (_x) : ); \
151
} while (0)
152
153
154
#define mips_set_cause( _x ) \
155
do { \
156
157
__asm__ volatile( "mtc0 %0, $13; nop" : : "r" (__x) ); \
158
} while (0)
159
160
161
162
163
164
* Access the Debug Cache Invalidate Control register
165
166
167
#define mips_get_dcic( _x ) \
168
do { \
169
__asm__ volatile( "mfc0 %0, $7; nop" : "=r" (_x) : ); \
170
} while (0)
171
172
173
#define mips_set_dcic( _x ) \
174
do { \
175
176
__asm__ volatile( "mtc0 %0, $7; nop" : : "r" (__x) ); \
177
} while (0)
178
179
180
181
182
183
* Access the Breakpoint Program Counter & Mask registers
184
* (_x for BPC, _y for mask)
185
186
187
#define mips_get_bpcrm( _x, _y ) \
188
do { \
189
__asm__ volatile( "mfc0 %0, $3; nop" : "=r" (_x) : ); \
190
__asm__ volatile( "mfc0 %0, $11; nop" : "=r" (_y) : ); \
191
} while (0)
192
193
194
#define mips_set_bpcrm( _x, _y ) \
195
do { \
196
197
register unsigned int __y = (_y); \
198
__asm__ volatile( "mtc0 %0, $11; nop" : : "r" (__y) ); \
199
__asm__ volatile( "mtc0 %0, $3; nop" : : "r" (__x) ); \
200
} while (0)
201
202
203
204
205
206
207
208
* Access the Breakpoint Data Address & Mask registers
209
* (_x for BDA, _y for mask)
210
211
212
#define mips_get_bdarm( _x, _y ) \
213
do { \
214
__asm__ volatile( "mfc0 %0, $5; nop" : "=r" (_x) : ); \
215
__asm__ volatile( "mfc0 %0, $9; nop" : "=r" (_y) : ); \
216
} while (0)
217
218
219
#define mips_set_bdarm( _x, _y ) \
220
do { \
221
222
223
__asm__ volatile( "mtc0 %0, $9; nop" : : "r" (__y) ); \
224
__asm__ volatile( "mtc0 %0, $5; nop" : : "r" (__x) ); \
225
} while (0)
226
227
228
229
230
231
232
233
234
* Access FCR31
235
236
237
#if ( MIPS_HAS_FPU == 1 )
238
239
#define mips_get_fcr31( _x ) \
240
do { \
241
__asm__ volatile( "cfc1 %0, $31; nop" : "=r" (_x) : ); \
242
} while(0)
243
244
245
#define mips_set_fcr31( _x ) \
246
do { \
247
248
__asm__ volatile( "ctc1 %0, $31; nop" : : "r" (__x) ); \
249
} while(0)
250
251
#else
252
253
254
255
256
#endif
257
258
259
* Manipulate interrupt mask
260
261
* mips_unmask_interrupt( _mask)
262
* enables interrupts - mask is positioned so it only needs to be or'ed
263
* into the status reg. This also does some other things !!!! Caution
264
* should be used if invoking this while in the middle of a debugging
265
* session where the client may have nested interrupts.
266
267
* mips_mask_interrupt( _mask )
268
* disable the interrupt - mask is the complement of the bits to be
269
* cleared - i.e. to clear ext int 5 the mask would be - 0xffff7fff
270
271
272
* NOTE: mips_mask_interrupt() used to be disable_int().
273
* mips_unmask_interrupt() used to be enable_int().
274
275
276
277
#define mips_enable_in_interrupt_mask( _mask ) \
278
do { \
279
unsigned int _sr; \
280
mips_get_sr( _sr ); \
281
_sr |= (_mask); \
282
mips_set_sr( _sr ); \
283
} while (0)
284
285
#define mips_disable_in_interrupt_mask( _mask ) \
286
do { \
287
unsigned int _sr; \
288
289
_sr &= ~(_mask); \
290
291
} while (0)
292
293
#ifdef __cplusplus
294
295
#endif
296
298
#endif
/* _RTEMS_SCORE_MIPS_H */
299
/* end of include file */
idtcpu.h
CPU Related Definitions.
