main_ping.c File Reference
#include <sys/cdefs.h>
#include <sys/param.h>
#include <sys/socket.h>
#include <sys/sysctl.h>
#include <sys/time.h>
#include <sys/uio.h>
#include <netinet/in.h>
#include <netinet/in_systm.h>
#include <netinet/ip.h>
#include <netinet/ip_icmp.h>
#include <netinet/ip_var.h>
#include <arpa/inet.h>
#include <ctype.h>
#include <math.h>
#include <netdb.h>
#include <signal.h>
#include <unistd.h>
#include "err.h"
#include "sysexits.h"
#include <sys/select.h>
Include dependency graph for main_ping.c:
struct  tv32
#define INADDR_LEN   ((int)sizeof(in_addr_t))
#define TIMEVAL_LEN   ((int)sizeof(struct tv32))
#define MASK_LEN   (ICMP_MASKLEN - ICMP_MINLEN)
#define TS_LEN   (ICMP_TSLEN - ICMP_MINLEN)
#define DEFDATALEN   56 /* default data length */
#define FLOOD_BACKOFF   20000 /* usecs to back off if F_FLOOD mode */
#define MAXIPLEN   (sizeof(struct ip) + MAX_IPOPTLEN)
#define MAXICMPLEN   (ICMP_ADVLENMIN + MAX_IPOPTLEN)
#define MAXWAIT   10000 /* max ms to wait for response */
#define MAXALARM   (60 * 60) /* max seconds for alarm timeout */
#define MAXTOS   255
#define A(bit)   rcvd_tbl[(bit)>>3] /* identify byte in array */
#define B(bit)   (1 << ((bit) & 0x07)) /* identify bit in byte */
#define SET(bit)   (A(bit) |= B(bit))
#define CLR(bit)   (A(bit) &= (~B(bit)))
#define TST(bit)   (A(bit) & B(bit))
#define F_FLOOD   0x0001
#define F_INTERVAL   0x0002
#define F_NUMERIC   0x0004
#define F_PINGFILLED   0x0008
#define F_QUIET   0x0010
#define F_RROUTE   0x0020
#define F_SO_DEBUG   0x0040
#define F_SO_DONTROUTE   0x0080
#define F_VERBOSE   0x0100
#define F_QUIET2   0x0200
#define F_NOLOOP   0x0400
#define F_MTTL   0x0800
#define F_MIF   0x1000
#define F_AUDIBLE   0x2000
#define F_TTL   0x8000
#define F_MISSED   0x10000
#define F_ONCE   0x20000
#define F_HDRINCL   0x40000
#define F_MASK   0x80000
#define F_TIME   0x100000
#define F_SWEEP   0x200000
#define F_WAITTIME   0x400000
#define MAX_DUP_CHK   (8 * 128)
#define SECOPT   ""
 __FBSDID ("$FreeBSD$")
void stopit (sig)
int options
int mx_dup_ck = MAX_DUP_CHK
char rcvd_tbl [MAX_DUP_CHK/8]
struct sockaddr_in whereto
int datalen = DEFDATALEN
int maxpayload
int s
u_char outpackhdr [IP_MAXPACKET]
u_char * outpack
char BBELL = '\a'
char BSPACE = '\b'
char DOT = '.'
char * hostname
char * shostname
int ident
int uid
u_char icmp_type = ICMP_ECHO
u_char icmp_type_rsp = ICMP_ECHOREPLY
int phdr_len = 0
int send_len
long nmissedmax
long npackets
long nreceived
long nrepeats
long ntransmitted
long snpackets
long snreceived
long sntransmitted
int sweepmax
int sweepmin = 0
int sweepincr = 1
int interval = 1000
int waittime = MAXWAIT
long nrcvtimeout = 0
int timing
double tmin = 999999999.0
double tmax = 0.0
double tsum = 0.0
double tsumsq = 0.0
volatile sig_atomic_t finish_up
volatile sig_atomic_t siginfo_p
