admin
rtems-admin.git
doxygen
builder
latest
rtems.git
score
cpu
m68k
m68k/rtems/asm.h
1
17
18
* COPYRIGHT:
19
20
* This file is based on similar code found in newlib available
21
* from ftp.cygnus.com. The file which was used had no copyright
22
* notice. This file is freely distributable as long as the source
23
* of the file is noted. This file is:
24
25
* COPYRIGHT (c) 1994-1997.
26
* On-Line Applications Research Corporation (OAR).
27
28
29
#ifndef _RTEMS_ASM_H
30
#define _RTEMS_ASM_H
31
32
33
* Indicate we are in an assembly file and get the basic CPU definitions.
34
35
36
#ifndef ASM
37
#define ASM
38
#endif
39
40
#include <rtems/score/cpu.h>
41
42
43
* Recent versions of GNU cpp define variables which indicate the
44
* need for underscores and percents. If not using GNU cpp or
45
* the version does not support this, then you will obviously
46
* have to define these as appropriate.
47
48
49
#ifndef __USER_LABEL_PREFIX__
50
#define __USER_LABEL_PREFIX__ _
51
#endif
52
53
#ifndef __REGISTER_PREFIX__
54
#define __REGISTER_PREFIX__
55
#endif
56
57
rtems/concat.h
58
59
/* Use the right prefix for global labels. */
60
61
#define SYM(x) CONCAT0 (__USER_LABEL_PREFIX__, x)
62
63
/* Use the right prefix for registers. */
64
65
#define REG(x) CONCAT0 (__REGISTER_PREFIX__, x)
66
67
#define d0 REG (d0)
68
#define d1 REG (d1)
69
#define d2 REG (d2)
70
#define d3 REG (d3)
71
#define d4 REG (d4)
72
#define d5 REG (d5)
73
#define d6 REG (d6)
74
#define d7 REG (d7)
75
#define a0 REG (a0)
76
#define a1 REG (a1)
77
#define a2 REG (a2)
78
#define a3 REG (a3)
79
#define a4 REG (a4)
80
#define a5 REG (a5)
81
#define a6 REG (a6)
82
#define a7 REG (a7)
83
#define sp REG (sp)
84
85
#define msp REG (msp)
86
#define usp REG (usp)
87
#define isp REG (isp)
88
#define sr REG (sr)
89
#define vbr REG (vbr)
90
#define dfc REG (dfc)
91
#define sfc REG (sfc)
92
93
/* mcf52xx special regs */
94
#define cacr REG (cacr)
95
#define acr0 REG (acr0)
96
#define acr1 REG (acr1)
97
#define rambar0 REG (rambar0)
98
#define mbar REG (mbar)
99
100
/* additional v4e special regs */
101
#define rambar1 REG (rambar1)
102
#define macsr REG (macsr)
103
#define acc0 REG (acc0)
104
#define acc1 REG (acc1)
105
#define acc2 REG (acc2)
106
#define acc3 REG (acc3)
107
#define accext01 REG (accext01)
108
#define accext23 REG (accext23)
109
#define mask REG (mask)
110
111
112
#define fp0 REG (fp0)
113
#define fp1 REG (fp1)
114
#define fp2 REG (fp2)
115
#define fp3 REG (fp3)
116
#define fp4 REG (fp4)
117
#define fp5 REG (fp5)
118
#define fp6 REG (fp6)
119
#define fp7 REG (fp7)
120
121
#define fpc REG (fpc)
122
#define fpi REG (fpi)
123
#define fps REG (fps)
124
#define fpsr REG (fpsr)
125
126
127
128
* Define macros to handle section beginning and ends.
129
130
131
132
#define BEGIN_CODE_DCL .text
133
#define END_CODE_DCL
134
#define BEGIN_DATA_DCL .data
135
#define END_DATA_DCL
136
#define BEGIN_CODE .text
137
#define END_CODE
138
#define BEGIN_DATA .data
139
#define END_DATA
140
#define BEGIN_BSS .bss
141
#define END_BSS
142
#define END
143
144
145
* Following must be tailor for a particular flavor of the C compiler.
146
* They may need to put underscores in front of the symbols.
147
148
149
#define PUBLIC(sym) .globl SYM (sym)
150
#define EXTERN(sym) .globl SYM (sym)
151
152
#endif
concat.h
This include file defines ANSI concatenation macros.
