admin
rtems-admin.git
doxygen
builder
latest
rtems.git
score
cpu
m32c
m32c/rtems/asm.h
1
17
18
* COPYRIGHT:
19
20
* This file is based on similar code found in newlib available
21
* from ftp.cygnus.com. The file which was used had no copyright
22
* notice. This file is freely distributable as long as the source
23
* of the file is noted. This file is:
24
25
* COPYRIGHT (c) 1994-2006.
26
* On-Line Applications Research Corporation (OAR).
27
28
29
#ifndef _RTEMS_ASM_H
30
#define _RTEMS_ASM_H
31
32
33
* Indicate we are in an assembly file and get the basic CPU definitions.
34
35
36
#ifndef ASM
37
#define ASM
38
#endif
39
40
rtems/score/m32c.h
41
42
#ifndef __USER_LABEL_PREFIX__
43
51
#define __USER_LABEL_PREFIX__ _
52
#endif
53
54
#ifndef __REGISTER_PREFIX__
55
60
#define __REGISTER_PREFIX__
61
#endif
62
63
rtems/concat.h
64
66
#define SYM(x) CONCAT1 (__USER_LABEL_PREFIX__, x)
67
69
#define REG(x) CONCAT1 (__REGISTER_PREFIX__, x)
70
71
72
* define macros for all of the registers on this CPU
73
74
* EXAMPLE: #define d0 REG (d0)
75
76
77
78
* Define macros to handle section beginning and ends.
79
80
81
83
#define BEGIN_CODE_DCL .text
84
85
#define END_CODE_DCL
86
89
#define BEGIN_DATA_DCL .data
90
91
#define END_DATA_DCL
92
93
#define BEGIN_CODE .text
94
95
#define END_CODE
96
97
#define BEGIN_DATA
98
99
#define END_DATA
100
103
#define BEGIN_BSS
104
105
#define END_BSS
106
107
#define END
108
115
#define PUBLIC(sym) .globl SYM (sym)
116
122
#define EXTERN(sym) .globl SYM (sym)
123
124
#endif
m32c.h
M32C Set up Basic CPU Dependency Settings Based on Compiler Settings.
concat.h
This include file defines ANSI concatenation macros.
