admin
rtems-admin.git
doxygen
builder
latest
rtems.git
score
cpu
avr
avr
lock.h
1
148
149
* Copyright (c) 2007, Atmel Corporation
150
* All rights reserved.
151
152
153
* modification, are permitted provided that the following conditions are met:
154
155
* * Redistributions of source code must retain the above copyright
156
* notice, this list of conditions and the following disclaimer.
157
158
* * Redistributions in binary form must reproduce the above copyright
159
* notice, this list of conditions and the following disclaimer in
160
* the documentation and/or other materials provided with the
161
* distribution.
162
163
* * Neither the name of the copyright holders nor the names of
164
* contributors may be used to endorse or promote products derived
165
* from this software without specific prior written permission.
166
167
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
168
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
169
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
170
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
171
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
172
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
173
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
174
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
175
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
176
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
177
* POSSIBILITY OF SUCH DAMAGE.
178
179
180
#ifndef _AVR_LOCK_H_
181
#define _AVR_LOCK_H_ 1
182
190
#ifndef __ASSEMBLER__
191
192
#ifndef LOCKMEM
193
#define LOCKMEM __attribute__((section (".lock")))
194
#endif
195
196
#ifndef LOCKBITS
197
#define LOCKBITS unsigned char __lock LOCKMEM
198
#endif
199
200
#endif
/* !__ASSEMBLER */
201
202
203
/* Lock Bit Modes */
204
#if defined(__LOCK_BITS_EXIST)
205
#define LB_MODE_1 (0xFF)
206
#define LB_MODE_2 (0xFE)
207
#define LB_MODE_3 (0xFC)
208
#endif
209
210
#if defined(__BOOT_LOCK_BITS_0_EXIST)
211
#define BLB0_MODE_1 (0xFF)
212
#define BLB0_MODE_2 (0xFB)
213
#define BLB0_MODE_3 (0xF3)
214
#define BLB0_MODE_4 (0xF7)
215
#endif
216
217
#if defined(__BOOT_LOCK_BITS_1_EXIST)
218
#define BLB1_MODE_1 (0xFF)
219
#define BLB1_MODE_2 (0xEF)
220
#define BLB1_MODE_3 (0xCF)
221
#define BLB1_MODE_4 (0xDF)
222
#endif
223
224
#if defined(__BOOT_LOCK_APPLICATION_TABLE_BITS_EXIST)
225
#define BLBAT0 ~_BV(2)
226
#define BLBAT1 ~_BV(3)
227
#endif
228
229
#if defined(__BOOT_LOCK_APPLICATION_BITS_EXIST)
230
#define BLBA0 ~_BV(4)
231
#define BLBA1 ~_BV(5)
232
#endif
233
234
#if defined(__BOOT_LOCK_BOOT_BITS_EXIST)
235
#define BLBB0 ~_BV(6)
236
#define BLBB1 ~_BV(7)
237
#endif
238
239
240
#define LOCKBITS_DEFAULT (0xFF)
241
243
#endif
/* _AVR_LOCK_H_ */
