admin
rtems-admin.git
doxygen
builder
latest
rtems.git
score
cpu
lm32
score
lm32.h
1
11
12
* COPYRIGHT (c) 1989-1999.
13
* On-Line Applications Research Corporation (OAR).
14
15
* The license and distribution terms for this file may be
16
* found in the file LICENSE in this distribution or at
17
* http://www.rtems.org/license/LICENSE.
18
19
* Jukka Pietarinen <jukka.pietarinen@mrf.fi>, 2008,
20
* Micro-Research Finland Oy
21
22
23
#ifndef _RTEMS_SCORE_LM32_H
24
#define _RTEMS_SCORE_LM32_H
25
26
#ifdef __cplusplus
27
extern
"C"
28
#endif
29
30
31
* This file contains the information required to build
32
* RTEMS for a particular member of the NO CPU family.
33
* It does this by setting variables to indicate which
34
* implementation dependent features are present in a particular
35
* member of the family.
36
37
* This is a good place to list all the known CPU models
38
* that this port supports and which RTEMS CPU model they correspond
39
* to.
40
41
42
#if defined(rtems_multilib)
43
44
* Figure out all CPU Model Feature Flags based upon compiler
45
* predefines.
46
47
48
#define CPU_MODEL_NAME "rtems_multilib"
49
#define LM32_HAS_FPU 0
50
51
#elif defined(__lm32__)
52
53
#define CPU_MODEL_NAME "lm32"
54
55
56
#else
57
58
#error "Unsupported CPU Model"
59
60
#endif
61
62
63
* Define the name of the CPU family.
64
65
66
#define CPU_NAME "LM32"
67
68
#ifdef __cplusplus
69
70
#endif
71
72
#define lm32_read_interrupts( _ip) \
73
__asm__ volatile ("rcsr %0, ip":"=r"(_ip));
74
75
#define lm32_disable_interrupts( _level ) \
76
do { register uint32_t ie; \
77
__asm__ volatile ("rcsr %0,ie":"=r"(ie)); \
78
(_level) = ie; \
79
ie &= (~0x0001); \
80
__asm__ volatile ("wcsr ie,%0"::"r"(ie)); \
81
} while (0)
82
83
#define lm32_enable_interrupts( _level ) \
84
__asm__ volatile ("wcsr ie,%0"::"r"(_level));
85
86
#define lm32_flash_interrupts( _level ) \
87
88
__asm__ volatile ("wcsr ie,%0"::"r"(_level)); \
89
ie = (_level) & (~0x0001); \
90
91
} while (0)
92
93
#define lm32_interrupt_unmask( _mask ) \
94
do { register uint32_t im; \
95
__asm__ volatile ("rcsr %0,im":"=r"(im)); \
96
im |= _mask; \
97
__asm__ volatile ("wcsr im,%0"::"r"(im)); \
98
} while (0)
99
100
#define lm32_interrupt_mask( _mask ) \
101
102
103
im &= ~(_mask); \
104
105
} while (0)
106
107
#define lm32_interrupt_ack( _mask ) \
108
do { register uint32_t ip = _mask; \
109
__asm__ volatile ("wcsr ip,%0"::"r"(ip)); \
110
} while (0)
111
112
#endif
/* _RTEMS_SCORE_LM32_H */
