Data Structures | Macros
libnetworking/sys/malloc.h File Reference
#include <rtems/rtems_bsdnet_internal.h>
Include dependency graph for libnetworking/sys/malloc.h:
struct  kmemstats
struct  kmemusage
struct  kmembuckets
#define KMEMSTATS
#define M_WAITOK   0x0000
#define M_NOWAIT   0x0001
#define M_KERNEL   0x0002
#define M_FREE   0 /* should be on free list */
#define M_MBUF   1 /* mbuf */
#define M_DEVBUF   2 /* device driver memory */
#define M_SOCKET   3 /* socket structure */
#define M_PCB   4 /* protocol control block */
#define M_RTABLE   5 /* routing tables */
#define M_HTABLE   6 /* IMP host tables */
#define M_FTABLE   7 /* fragment reassembly header */
#define M_ZOMBIE   8 /* zombie proc status */
#define M_IFADDR   9 /* interface address */
#define M_SOOPTS   10 /* socket options */
#define M_SONAME   11 /* socket name */
#define M_NAMEI   12 /* namei path name buffer */
#define M_GPROF   13 /* kernel profiling buffer */
#define M_IOCTLOPS   14 /* ioctl data buffer */
#define M_MAPMEM   15 /* mapped memory descriptors */
#define M_CRED   16 /* credentials */
#define M_PGRP   17 /* process group header */
#define M_SESSION   18 /* session header */
#define M_IOV   19 /* large iov's */
#define M_MOUNT   20 /* vfs mount struct */
#define M_FHANDLE   21 /* network file handle */
#define M_NFSREQ   22 /* NFS request header */
#define M_NFSMNT   23 /* NFS mount structure */
#define M_NFSNODE   24 /* NFS vnode private part */
#define M_VNODE   25 /* Dynamically allocated vnodes */
#define M_CACHE   26 /* Dynamically allocated cache entries */
#define M_DQUOT   27 /* UFS quota entries */
#define M_UFSMNT   28 /* UFS mount structure */
#define M_SHM   29 /* SVID compatible shared memory segments */
#define M_VMMAP   30 /* VM map structures */
#define M_VMMAPENT   31 /* VM map entry structures */
#define M_VMOBJ   32 /* VM object structure */
#define M_VMOBJHASH   33 /* VM object hash structure */
#define M_VMPMAP   34 /* VM pmap */
#define M_VMPVENT   35 /* VM phys-virt mapping entry */
#define M_VMPAGER   36 /* XXX: VM pager struct */
#define M_VMPGDATA   37 /* XXX: VM pager private data */
#define M_FILE   38 /* Open file structure */
#define M_FILEDESC   39 /* Open file descriptor table */
#define M_LOCKF   40 /* Byte-range locking structures */
#define M_PROC   41 /* Proc structures */
#define M_SUBPROC   42 /* Proc sub-structures */
#define M_SEGMENT   43 /* Segment for LFS */
#define M_LFSNODE   44 /* LFS vnode private part */
#define M_FFSNODE   45 /* FFS vnode private part */
#define M_MFSNODE   46 /* MFS vnode private part */
#define M_NQLEASE   47 /* Nqnfs lease */
#define M_NQMHOST   48 /* Nqnfs host address table */
#define M_NETADDR   49 /* Export host address structure */
#define M_NFSSVC   50 /* Nfs server structure */
#define M_NFSUID   51 /* Nfs uid mapping structure */
#define M_NFSD   52 /* Nfs server daemon structure */
#define M_IPMOPTS   53 /* internet multicast options */
#define M_IPMADDR   54 /* internet multicast address */
#define M_IFMADDR   55 /* link-level multicast address */
#define M_MRTABLE   56 /* multicast routing tables */
#define M_ISOFSMNT   57 /* ISOFS mount structure */
#define M_ISOFSNODE   58 /* ISOFS vnode private part */
#define M_NFSRVDESC   59 /* NFS server socket descriptor */
#define M_NFSDIROFF   60 /* NFS directory offset data */
#define M_NFSBIGFH   61 /* NFS version 3 file handle */
#define M_MSDOSFSMNT   67 /* MSDOSFS mount structure */
#define M_MSDOSFSNODE   68 /* MSDOSFS vnode private part */
#define M_MSDOSFSFAT   69 /* MSDOSFS file allocation table */
#define M_DEVFSMNT   70 /* DEVFS mount structure */
#define M_DEVFSBACK   71 /* DEVFS Back node */
#define M_DEVFSFRONT   72 /* DEVFS Front node */
#define M_DEVFSNODE   73 /* DEVFS node */
#define M_TEMP   74 /* misc temporary data buffers */
#define M_TTYS   75 /* tty data structures */
#define M_GZIP   76 /* Gzip trees */
#define M_IPFW   77 /* IpFw/IpAcct chain's */
#define M_DEVL   78 /* isa_device lists in userconfig() */
#define M_PKTCLASS   79 /* structures used in packet classifier */
#define M_SYSCTL   80 /* sysctl internal magic */
#define M_SECA   81 /* security associations, key management */
#define M_BIOBUF   82 /* BIO buffer */
#define M_KTRACE   83 /* KTRACE */
#define M_SELECT   84 /* select() buffer */
#define M_CFS   85 /* Coda */
#define M_LAST   86 /* Must be last type + 1 */
#define INITKMEMNAMES
#define ku_freecnt   ku_un.freecnt
#define ku_pagecnt   ku_un.pagecnt
