Functions | Variables
kern_mib.c File Reference
#include "opt_posix.h"
#include <sys/param.h>
#include <sys/kernel.h>
#include <sys/systm.h>
#include <sys/sysctl.h>
#include <sys/proc.h>
#include <sys/lock.h>
#include <sys/mutex.h>
#include <sys/jail.h>
#include <sys/smp.h>
#include <sys/unistd.h>
#include <sys/vnode.h>
#include <sys/conf.h>
#include <sys/bio.h>
#include <sys/buf.h>
#include <sys/user.h>
Include dependency graph for kern_mib.c:
 SYSCTL_NODE (, 0, sysctl, CTLFLAG_RW, 0, "Sysctl internal magic")
 SYSCTL_NODE (, CTL_KERN, kern, CTLFLAG_RW, 0, "High kernel, proc, limits &c")
 SYSCTL_NODE (, CTL_VM, vm, CTLFLAG_RW, 0, "Virtual memory")
 SYSCTL_NODE (, CTL_VFS, vfs, CTLFLAG_RW, 0, "File system")
 SYSCTL_NODE (, CTL_NET, net, CTLFLAG_RW, 0, "Network, (see socket.h)")
 SYSCTL_NODE (, CTL_DEBUG, debug, CTLFLAG_RW, 0, "Debugging")
 SYSCTL_NODE (_debug, OID_AUTO, sizeof, CTLFLAG_RW, 0, "Sizeof various things")
 SYSCTL_NODE (, CTL_HW, hw, CTLFLAG_RW, 0, "hardware")
 SYSCTL_NODE (, CTL_MACHDEP, machdep, CTLFLAG_RW, 0, "machine dependent")
 SYSCTL_NODE (, CTL_USER, user, CTLFLAG_RW, 0, "user-level")
 SYSCTL_NODE (, CTL_P1003_1B, p1003_1b, CTLFLAG_RW, 0, "p1003_1b, (see p1003_1b.h)")
 SYSCTL_NODE (, OID_AUTO, compat, CTLFLAG_RW, 0, "Compatibility code")
 SYSCTL_NODE (, OID_AUTO, security, CTLFLAG_RW, 0, "Security")
 SYSCTL_STRING (_kern, OID_AUTO, ident, CTLFLAG_RD, kern_ident, 0, "Kernel identifier")
 SYSCTL_STRING (_kern, KERN_OSRELEASE, osrelease, CTLFLAG_RD, osrelease, 0, "Operating system release")
 SYSCTL_INT (_kern, KERN_OSREV, osrevision, CTLFLAG_RD, 0, BSD, "Operating system revision")
 SYSCTL_STRING (_kern, KERN_VERSION, version, CTLFLAG_RD, version, 0, "Kernel version")
 SYSCTL_STRING (_kern, KERN_OSTYPE, ostype, CTLFLAG_RD, ostype, 0, "Operating system type")
 SYSCTL_INT (_kern, KERN_OSRELDATE, osreldate, CTLFLAG_RD, &osreldate, 0, "Operating system release date")
 SYSCTL_INT (_kern, KERN_MAXPROC, maxproc, CTLFLAG_RD, &maxproc, 0, "Maximum number of processes")
 SYSCTL_INT (_kern, KERN_MAXPROCPERUID, maxprocperuid, CTLFLAG_RW, &maxprocperuid, 0, "Maximum processes allowed per userid")
 SYSCTL_INT (_kern, OID_AUTO, maxusers, CTLFLAG_RD, &maxusers, 0, "Hint for kernel tuning")
 SYSCTL_INT (_kern, KERN_ARGMAX, argmax, CTLFLAG_RD, 0, ARG_MAX, "Maximum bytes of argument to execve(2)")
 SYSCTL_INT (_kern, KERN_POSIX1, posix1version, CTLFLAG_RD, 0, _POSIX_VERSION, "Version of POSIX attempting to comply to")
 SYSCTL_INT (_kern, KERN_NGROUPS, ngroups, CTLFLAG_RD, 0, NGROUPS_MAX, "Maximum number of groups a user can belong to")
 SYSCTL_INT (_kern, KERN_JOB_CONTROL, job_control, CTLFLAG_RD, 0, 1, "Whether job control is available")
 SYSCTL_INT (_kern, KERN_SAVED_IDS, saved_ids, CTLFLAG_RD, 0, 0, "Whether saved set-group/user ID is available")
 SYSCTL_STRING (_kern, KERN_BOOTFILE, bootfile, CTLFLAG_RW, kernelname, sizeof kernelname, "Name of kernel file booted")
 SYSCTL_INT (_hw, HW_NCPU, ncpu, CTLFLAG_RD, 0, 1, "Number of active CPUs")
 SYSCTL_INT (_hw, HW_BYTEORDER, byteorder, CTLFLAG_RD, 0, BYTE_ORDER, "System byte order")
 SYSCTL_INT (_hw, HW_PAGESIZE, pagesize, CTLFLAG_RD, 0, PAGE_SIZE, "System memory page size")
 SYSCTL_PROC (_hw, HW_PHYSMEM, physmem, CTLTYPE_ULONG|CTLFLAG_RD, 0, 0, sysctl_hw_physmem, "LU", "")
 SYSCTL_PROC (_hw, HW_USERMEM, usermem, CTLTYPE_ULONG|CTLFLAG_RD, 0, 0, sysctl_hw_usermem, "LU", "")
 SYSCTL_ULONG (_hw, OID_AUTO, availpages, CTLFLAG_RD, &physmem, 0, "")
 SYSCTL_STRING (_hw, HW_MACHINE_ARCH, machine_arch, CTLFLAG_RD, machine_arch, 0, "System architecture")
 SYSCTL_PROC (_kern, KERN_HOSTNAME, hostname, CTLTYPE_STRING|CTLFLAG_RW|CTLFLAG_PRISON, 0, 0, sysctl_hostname, "A", "Hostname")
 MTX_SYSINIT (securelevel_lock, &securelevel_mtx, "securelevel mutex lock", MTX_DEF)
 SYSCTL_PROC (_kern, KERN_SECURELVL, securelevel, CTLTYPE_INT|CTLFLAG_RW|CTLFLAG_PRISON, 0, 0, sysctl_kern_securelvl, "I", "Current secure level")
 SYSCTL_STRING (_kern, KERN_NISDOMAINNAME, domainname, CTLFLAG_RW, &domainname, sizeof(domainname), "Name of the current YP/NIS domain")
 SYSCTL_ULONG (_kern, KERN_HOSTID, hostid, CTLFLAG_RW, &hostid, 0, "Host ID")
 SYSCTL_STRING (_user, USER_CS_PATH, cs_path, CTLFLAG_RD, "", 0, "PATH that finds all the standard utilities")
 SYSCTL_INT (_user, USER_BC_BASE_MAX, bc_base_max, CTLFLAG_RD, 0, 0, "Max ibase/obase values in bc(1)")
 SYSCTL_INT (_user, USER_BC_DIM_MAX, bc_dim_max, CTLFLAG_RD, 0, 0, "Max array size in bc(1)")
 SYSCTL_INT (_user, USER_BC_SCALE_MAX, bc_scale_max, CTLFLAG_RD, 0, 0, "Max scale value in bc(1)")
 SYSCTL_INT (_user, USER_BC_STRING_MAX, bc_string_max, CTLFLAG_RD, 0, 0, "Max string length in bc(1)")
 SYSCTL_INT (_user, USER_COLL_WEIGHTS_MAX, coll_weights_max, CTLFLAG_RD, 0, 0, "Maximum number of weights assigned to an LC_COLLATE locale entry")
 SYSCTL_INT (_user, USER_EXPR_NEST_MAX, expr_nest_max, CTLFLAG_RD, 0, 0, "")
 SYSCTL_INT (_user, USER_LINE_MAX, line_max, CTLFLAG_RD, 0, 0, "Max length (bytes) of a text-processing utility's input line")
 SYSCTL_INT (_user, USER_RE_DUP_MAX, re_dup_max, CTLFLAG_RD, 0, 0, "Maximum number of repeats of a regexp permitted")
 SYSCTL_INT (_user, USER_POSIX2_VERSION, posix2_version, CTLFLAG_RD, 0, 0, "The version of POSIX 1003.2 with which the system attempts to comply")
 SYSCTL_INT (_user, USER_POSIX2_C_BIND, posix2_c_bind, CTLFLAG_RD, 0, 0, "Whether C development supports the C bindings option")
 SYSCTL_INT (_user, USER_POSIX2_C_DEV, posix2_c_dev, CTLFLAG_RD, 0, 0, "Whether system supports the C development utilities option")
 SYSCTL_INT (_user, USER_POSIX2_CHAR_TERM, posix2_char_term, CTLFLAG_RD, 0, 0, "")
 SYSCTL_INT (_user, USER_POSIX2_FORT_DEV, posix2_fort_dev, CTLFLAG_RD, 0, 0, "Whether system supports FORTRAN development utilities")
 SYSCTL_INT (_user, USER_POSIX2_FORT_RUN, posix2_fort_run, CTLFLAG_RD, 0, 0, "Whether system supports FORTRAN runtime utilities")
 SYSCTL_INT (_user, USER_POSIX2_LOCALEDEF, posix2_localedef, CTLFLAG_RD, 0, 0, "Whether system supports creation of locales")
 SYSCTL_INT (_user, USER_POSIX2_SW_DEV, posix2_sw_dev, CTLFLAG_RD, 0, 0, "Whether system supports software development utilities")
 SYSCTL_INT (_user, USER_POSIX2_UPE, posix2_upe, CTLFLAG_RD, 0, 0, "Whether system supports the user portability utilities")
 SYSCTL_INT (_user, USER_STREAM_MAX, stream_max, CTLFLAG_RD, 0, 0, "Min Maximum number of streams a process may have open at one time")
 SYSCTL_INT (_user, USER_TZNAME_MAX, tzname_max, CTLFLAG_RD, 0, 0, "Min Maximum number of types supported for timezone names")
 SYSCTL_INT (_debug_sizeof, OID_AUTO, vnode, CTLFLAG_RD, 0, sizeof(struct vnode), "sizeof(struct vnode)")
 SYSCTL_INT (_debug_sizeof, OID_AUTO, proc, CTLFLAG_RD, 0, sizeof(struct proc), "sizeof(struct proc)")
 SYSCTL_INT (_debug_sizeof, OID_AUTO, cdev, CTLFLAG_RD, 0, sizeof(struct cdev), "sizeof(struct cdev)")
 SYSCTL_INT (_debug_sizeof, OID_AUTO, bio, CTLFLAG_RD, 0, sizeof(struct bio), "sizeof(struct bio)")
 SYSCTL_INT (_debug_sizeof, OID_AUTO, buf, CTLFLAG_RD, 0, sizeof(struct buf), "sizeof(struct buf)")
 SYSCTL_INT (_debug_sizeof, OID_AUTO, kinfo_proc, CTLFLAG_RD, 0, sizeof(struct kinfo_proc), "sizeof(struct kinfo_proc)")
int osreldate
char kernelname [MAXPATHLEN] = "/kernel"
char hostname [MAXHOSTNAMELEN]
int securelevel = -1
struct mtx securelevel_mtx
char domainname [MAXHOSTNAMELEN]
u_long hostid
