admin
rtems-admin.git
doxygen
builder
latest
rtems.git
score
include
score
isrlock.h
1
9
10
* Copyright (c) 2013-2015 embedded brains GmbH. All rights reserved.
11
12
* embedded brains GmbH
13
* Dornierstr. 4
14
* 82178 Puchheim
15
* Germany
16
* <rtems@embedded-brains.de>
17
18
* The license and distribution terms for this file may be
19
* found in the file LICENSE in this distribution or at
20
* http://www.rtems.org/license/LICENSE.
21
22
23
#ifndef _RTEMS_SCORE_ISR_LOCK_H
24
#define _RTEMS_SCORE_ISR_LOCK_H
25
26
rtems/score/isrlevel.h
27
rtems/score/smplock.h
28
29
#ifdef __cplusplus
30
extern
"C"
31
#endif
32
56
typedef
struct
57
#if defined( RTEMS_SMP )
58
SMP_lock_Control Lock;
59
#endif
60
ISR_lock_Control
61
65
typedef
struct
66
67
SMP_lock_Context Lock_context;
68
#else
69
ISR_Level
isr_level;
70
#endif
71
#if defined( RTEMS_PROFILING )
72
75
CPU_Counter_ticks ISR_disable_instant;
76
#endif
77
ISR_lock_Context
78
86
87
#define ISR_LOCK_MEMBER( _designator ) ISR_lock_Control _designator;
88
#else
89
90
#endif
91
100
101
#define ISR_LOCK_DECLARE( _qualifier, _designator ) \
102
_qualifier ISR_lock_Control _designator;
103
#else
104
105
#endif
106
117
118
#define ISR_LOCK_DEFINE( _qualifier, _designator, _name ) \
119
_qualifier ISR_lock_Control _designator = { SMP_LOCK_INITIALIZER( _name ) };
120
#else
121
122
#endif
123
132
133
#define ISR_LOCK_REFERENCE( _designator, _target ) \
134
ISR_lock_Control *_designator = _target;
135
#else
136
137
#endif
138
145
146
#define ISR_LOCK_INITIALIZER( _name ) \
147
148
#else
149
150
151
#endif
152
163
164
#define _ISR_lock_Initialize( _lock, _name ) \
165
_SMP_lock_Initialize( &( _lock )->Lock, _name )
166
#else
167
168
#endif
169
177
178
#define _ISR_lock_Destroy( _lock ) \
179
_SMP_lock_Destroy( &( _lock )->Lock )
180
#else
181
182
#endif
183
198
199
#define _ISR_lock_ISR_disable_and_acquire( _lock, _context ) \
200
_SMP_lock_ISR_disable_and_acquire( \
201
&( _lock )->Lock, \
202
&( _context )->Lock_context \
203
204
#else
205
206
_ISR_Disable( ( _context )->isr_level )
207
#endif
208
223
224
#define _ISR_lock_Release_and_ISR_enable( _lock, _context ) \
225
_SMP_lock_Release_and_ISR_enable( \
226
&( _lock )->Lock, \
227
228
229
#else
230
231
_ISR_Enable( ( _context )->isr_level )
232
#endif
233
250
251
#define _ISR_lock_Acquire( _lock, _context ) \
252
_SMP_lock_Acquire( \
253
&( _lock )->Lock, \
254
255
256
#else
257
258
#endif
259
272
273
#define _ISR_lock_Release( _lock, _context ) \
274
_SMP_lock_Release( \
275
&( _lock )->Lock, \
276
277
278
#else
279
280
#endif
281
298
299
#define _ISR_lock_Flash( _lock, _context ) \
300
301
&( _lock )->Lock, \
302
303
304
305
&( _lock )->Lock, \
306
307
308
#else
309
310
_ISR_Flash( ( _context )->isr_level )
311
#endif
312
313
314
#define _ISR_lock_ISR_disable_profile( _context ) \
315
( _context )->ISR_disable_instant = _CPU_Counter_read();
316
#else
317
318
#endif
319
330
331
#define _ISR_lock_ISR_disable( _context ) \
332
do { \
333
_ISR_Disable_without_giant( ( _context )->Lock_context.isr_level ); \
334
335
} while ( 0 )
336
#else
337
338
do { \
339
_ISR_Disable( ( _context )->isr_level ); \
340
341
} while ( 0 )
342
#endif
343
354
355
#define _ISR_lock_ISR_enable( _context ) \
356
_ISR_Enable_without_giant( ( _context )->Lock_context.isr_level )
357
#else
358
359
360
#endif
361
364
#ifdef __cplusplus
365
366
#endif
367
368
#endif
/* _RTEMS_SCORE_ISR_LOCK_H */
isrlevel.h
ISR Level Type.
ISR_lock_Control
ISR lock control.
Definition:
isrlock.h:56
ISR_Level
uint32_t ISR_Level
The following type defines the control block used to manage the interrupt level portion of the status...
Definition:
isrlevel.h:42
smplock.h
SMP Lock API.
ISR_lock_Context
Local ISR lock context for acquire and release pairs.
Definition:
isrlock.h:65
