admin
rtems-admin.git
doxygen
builder
latest
rtems.git
score
cpu
avr
avr
iousbxx6_7.h
1
9
10
* Copyright (c) 2006, Anatoly Sokolov
11
* All rights reserved.
12
13
14
* modification, are permitted provided that the following conditions are met:
15
16
* * Redistributions of source code must retain the above copyright
17
* notice, this list of conditions and the following disclaimer.
18
19
* * Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in
21
* the documentation and/or other materials provided with the
22
* distribution.
23
24
* * Neither the name of the copyright holders nor the names of
25
* contributors may be used to endorse or promote products derived
26
* from this software without specific prior written permission.
27
28
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
29
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
30
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
31
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
32
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
33
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
34
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
35
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
36
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
37
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
38
* POSSIBILITY OF SUCH DAMAGE.
39
40
41
#ifndef _AVR_IOUSBXX6_7_H_
42
#define _AVR_IOUSBXX6_7_H_ 1
43
51
#ifndef _AVR_IO_H_
52
# error "Include <avr/io.h> instead of this file."
53
#endif
54
55
#ifndef _AVR_IOXXX_H_
56
# define _AVR_IOXXX_H_ "iousbxx6_7.h"
57
#else
58
# error "Attempt to include more than one <avr/ioXXX.h> file."
59
#endif
60
61
#if defined(__AVR_AT90USB646__) || defined(__AVR_AT90USB1286__)
62
# define __AT90USBxx6__ 1
63
#elif defined(__AVR_AT90USB647__) || defined(__AVR_AT90USB1287__)
64
# define __AT90USBxx7__ 1
65
#endif
66
67
/* Registers and associated bit numbers */
68
69
#define PINA _SFR_IO8(0X00)
70
#define PINA7 7
71
#define PINA6 6
72
#define PINA5 5
73
#define PINA4 4
74
#define PINA3 3
75
#define PINA2 2
76
#define PINA1 1
77
#define PINA0 0
78
79
#define DDRA _SFR_IO8(0X01)
80
#define DDA7 7
81
#define DDA6 6
82
#define DDA5 5
83
#define DDA4 4
84
#define DDA3 3
85
#define DDA2 2
86
#define DDA1 1
87
#define DDA0 0
88
89
#define PORTA _SFR_IO8(0X02)
90
#define PA7 7
91
#define PA6 6
92
#define PA5 5
93
#define PA4 4
94
#define PA3 3
95
#define PA2 2
96
#define PA1 1
97
#define PA0 0
98
99
#define PINB _SFR_IO8(0X03)
100
#define PINB7 7
101
#define PINB6 6
102
#define PINB5 5
103
#define PINB4 4
104
#define PINB3 3
105
#define PINB2 2
106
#define PINB1 1
107
#define PINB0 0
108
109
#define DDRB _SFR_IO8(0x04)
110
#define DDB7 7
111
#define DDB6 6
112
#define DDB5 5
113
#define DDB4 4
114
#define DDB3 3
115
#define DDB2 2
116
#define DDB1 1
117
#define DDB0 0
118
119
#define PORTB _SFR_IO8(0x05)
120
#define PB7 7
121
#define PB6 6
122
#define PB5 5
123
#define PB4 4
124
#define PB3 3
125
#define PB2 2
126
#define PB1 1
127
#define PB0 0
128
129
#define PINC _SFR_IO8(0x06)
130
#define PINC7 7
131
#define PINC6 6
132
#define PINC5 5
133
#define PINC4 4
134
#define PINC3 3
135
#define PINC2 2
136
#define PINC1 1
137
#define PINC0 0
138
139
#define DDRC _SFR_IO8(0x07)
140
#define DDC7 7
141
#define DDC6 6
142
#define DDC5 5
143
#define DDC4 4
144
#define DDC3 3
145
#define DDC2 2
146
#define DDC1 1
147
#define DDC0 0
148
149
#define PORTC _SFR_IO8(0x08)
150
#define PC7 7
151
#define PC6 6
152
#define PC5 5
153
#define PC4 4
154
#define PC3 3
155
#define PC2 2
156
#define PC1 1
157
#define PC0 0
158
159
#define PIND _SFR_IO8(0x09)
160
#define PIND7 7
161
#define PIND6 6
162
#define PIND5 5
163
#define PIND4 4
164
#define PIND3 3
165
#define PIND2 2
166
#define PIND1 1
167
#define PIND0 0
168
169
#define DDRD _SFR_IO8(0x0A)
170
#define DDD7 7
171
#define DDD6 6
172
#define DDD5 5
173
#define DDD4 4
174
#define DDD3 3
175
#define DDD2 2
176
#define DDD1 1
177
#define DDD0 0
178
179
#define PORTD _SFR_IO8(0x0B)
180
#define PD7 7
181
#define PD6 6
182
#define PD5 5
183
#define PD4 4
184
#define PD3 3
185
#define PD2 2
186
#define PD1 1
187
#define PD0 0
188
189
#define PINE _SFR_IO8(0x0C)
190
#define PINE7 7
191
#define PINE6 6
192
#define PINE5 5
193
#define PINE4 4
194
#define PINE3 3
195
#define PINE2 2
196
#define PINE1 1
197
#define PINE0 0
198
199
#define DDRE _SFR_IO8(0x0D)
200
#define DDE7 7
201
#define DDE6 6
202
#define DDE5 5
203
#define DDE4 4
204
#define DDE3 3
205
#define DDE2 2
206
#define DDE1 1
207
#define DDE0 0
208
209
#define PORTE _SFR_IO8(0x0E)
210
#define PE7 7
211
#define PE6 6
212
#define PE5 5
213
#define PE4 4
214
#define PE3 3
215
#define PE2 2
216
#define PE1 1
217
#define PE0 0
218
219
#define PINF _SFR_IO8(0x0F)
220
#define PINF7 7
221
#define PINF6 6
222
#define PINF5 5
223
#define PINF4 4
224
#define PINF3 3
225
#define PINF2 2
226
#define PINF1 1
227
#define PINF0 0
228
229
#define DDRF _SFR_IO8(0x10)
230
#define DDF7 7
231
#define DDF6 6
232
#define DDF5 5
233
#define DDF4 4
234
#define DDF3 3
235
#define DDF2 2
236
#define DDF1 1
237
#define DDF0 0
238
239
#define PORTF _SFR_IO8(0x11)
240
#define PF7 7
241
#define PF6 6
242
#define PF5 5
243
#define PF4 4
244
#define PF3 3
245
#define PF2 2
246
#define PF1 1
247
#define PF0 0
248
249
/* Reserved [0x12..0x14] */
250
251
#define TIFR0 _SFR_IO8(0x15)
252
#define OCF0B 2
253
#define OCF0A 1
254
#define TOV0 0
255
256
#define TIFR1 _SFR_IO8(0x16)
257
#define ICF1 5
258
#define OCF1C 3
259
#define OCF1B 2
260
#define OCF1A 1
261
#define TOV1 0
262
263
#define TIFR2 _SFR_IO8(0x17)
264
#define OCF2B 2
265
#define OCF2A 1
266
#define TOV2 0
267
268
#define TIFR3 _SFR_IO8(0x18)
269
#define ICF3 5
270
#define OCF3C 3
271
#define OCF3B 2
272
#define OCF3A 1
273
#define TOV3 0
274
275
/* Reserved [0x19..0x1A] */
276
277
#define PCIFR _SFR_IO8(0x1B)
278
#define PCIF0 0
279
280
#define EIFR _SFR_IO8(0x1C)
281
#define INTF7 7
282
#define INTF6 6
283
#define INTF5 5
284
#define INTF4 4
285
#define INTF3 3
286
#define INTF2 2
287
#define INTF1 1
288
#define INTF0 0
289
290
#define EIMSK _SFR_IO8(0x1D)
291
#define INT7 7
292
#define INT6 6
293
#define INT5 5
294
#define INT4 4
295
#define INT3 3
296
#define INT2 2
297
#define INT1 1
298
#define INT0 0
299
300
#define GPIOR0 _SFR_IO8(0x1E)
301
302
#define EECR _SFR_IO8(0x1F)
303
#define EEPM1 5
304
#define EEPM0 4
305
#define EERIE 3
306
#define EEMPE 2
307
#define EEPE 1
308
#define EERE 0
309
310
#define EEDR _SFR_IO8(0x20)
311
312
#define EEAR _SFR_IO16(0x21)
313
#define EEARL _SFR_IO8(0x21)
314
#define EEARH _SFR_IO8(0x22)
315
316
/* 6-char sequence denoting where to find the EEPROM registers in memory space.
317
Adresses denoted in hex syntax with uppercase letters. Used by the EEPROM
318
subroutines.
319
First two letters: EECR address.
320
Second two letters: EEDR address.
321
Last two letters: EEAR address. */
322
#define __EEPROM_REG_LOCATIONS__ 1F2021
323
324
#define GTCCR _SFR_IO8(0x23)
325
#define TSM 7
326
#define PSRASY 1
327
#define PSRSYNC 0
328
329
#define TCCR0A _SFR_IO8(0x24)
330
#define COM0A1 7
331
#define COM0A0 6
332
#define COM0B1 5
333
#define COM0B0 4
334
#define WGM01 1
335
#define WGM00 0
336
337
#define TCCR0B _SFR_IO8(0x25)
338
#define FOC0A 7
339
#define FOC0B 6
340
#define WGM02 3
341
#define CS02 2
342
#define CS01 1
343
#define CS00 0
344
345
#define TCNT0 _SFR_IO8(0X26)
346
347
#define OCR0A _SFR_IO8(0x27)
348
349
#define OCR0B _SFR_IO8(0X28)
350
351
#define PLLCSR _SFR_IO8(0x29)
352
#define PLLP2 4
353
#define PLLP1 3
354
#define PLLP0 2
355
#define PLLE 1
356
#define PLOCK 0
357
358
#define GPIOR1 _SFR_IO8(0x2A)
359
360
#define GPIOR2 _SFR_IO8(0x2B)
361
362
#define SPCR _SFR_IO8(0x2C)
363
#define SPIE 7
364
#define SPE 6
365
#define DORD 5
366
#define MSTR 4
367
#define CPOL 3
368
#define CPHA 2
369
#define SPR1 1
370
#define SPR0 0
371
372
#define SPSR _SFR_IO8(0x2D)
373
#define SPIF 7
374
#define WCOL 6
375
#define SPI2X 0
376
377
#define SPDR _SFR_IO8(0x2E)
378
379
/* Reserved [0x2F] */
380
381
#define ACSR _SFR_IO8(0x30)
382
#define ACD 7
383
#define ACBG 6
384
#define ACO 5
385
#define ACI 4
386
#define ACIE 3
387
#define ACIC 2
388
#define ACIS1 1
389
#define ACIS0 0
390
391
#define MONDR _SFR_IO8(0x31)
392
#define OCDR _SFR_IO8(0x31)
393
#define IDRD 7
394
#define OCDR7 7
395
#define OCDR6 6
396
#define OCDR5 5
397
#define OCDR4 4
398
#define OCDR3 3
399
#define OCDR2 2
400
#define OCDR1 1
401
#define OCDR0 0
402
403
/* Reserved [0x32] */
404
405
#define SMCR _SFR_IO8(0x33)
406
#define SM2 3
407
#define SM1 2
408
#define SM0 1
409
#define SE 0
410
411
#define MCUSR _SFR_IO8(0x34)
412
#define JTRF 4
413
#define WDRF 3
414
#define BORF 2
415
#define EXTRF 1
416
#define PORF 0
417
418
#define MCUCR _SFR_IO8(0x35)
419
#define JTD 7
420
#define PUD 4
421
#define IVSEL 1
422
#define IVCE 0
423
424
/* Reserved [0x36] */
425
426
#define SPMCSR _SFR_IO8(0x37)
427
#define SPMIE 7
428
#define RWWSB 6
429
#define SIGRD 5
430
#define RWWSRE 4
431
#define BLBSET 3
432
#define PGWRT 2
433
#define PGERS 1
434
#define SPMEN 0
435
436
/* Reserved [0x38..0x3A] */
437
438
#if defined(__AVR_AT90USB1286__) || defined(__AVR_AT90USB1287__)
439
#define RAMPZ _SFR_IO8(0x3B)
440
#endif
441
442
/* Reserved [0x3C] */
443
444
/* SP [0x3D..0x3E] */
445
/* SREG [0x3F] */
446
447
#define WDTCSR _SFR_MEM8(0x60)
448
#define WDIF 7
449
#define WDIE 6
450
#define WDP3 5
451
#define WDCE 4
452
#define WDE 3
453
#define WDP2 2
454
#define WDP1 1
455
#define WDP0 0
456
457
#define CLKPR _SFR_MEM8(0x61)
458
#define CLKPCE 7
459
#define CLKPS3 3
460
#define CLKPS2 2
461
#define CLKPS1 1
462
#define CLKPS0 0
463
464
/* Reserved [0x62..0x63] */
465
466
#define PRR0 _SFR_MEM8(0x64)
467
#define PRTWI 7
468
#define PRTIM2 6
469
#define PRTIM0 5
470
#define PRTIM1 3
471
#define PRSPI 2
472
#define PRADC 0
473
474
#define PRR1 _SFR_MEM8(0x65)
475
#define PRUSB 7
476
#define PRTIM3 3
477
#define PRUSART1 0
478
479
#define OSCCAL _SFR_MEM8(0x66)
480
481
/* Reserved [0x67] */
482
483
#define PCICR _SFR_MEM8(0x68)
484
#define PCIE0 0
485
486
#define EICRA _SFR_MEM8(0x69)
487
#define ISC31 7
488
#define ISC30 6
489
#define ISC21 5
490
#define ISC20 4
491
#define ISC11 3
492
#define ISC10 2
493
#define ISC01 1
494
#define ISC00 0
495
496
#define EICRB _SFR_MEM8(0x6A)
497
#define ISC71 7
498
#define ISC70 6
499
#define ISC61 5
500
#define ISC60 4
501
#define ISC51 3
502
#define ISC50 2
503
#define ISC41 1
504
#define ISC40 0
505
506
#define PCMSK0 _SFR_MEM8(0x6B)
507
#define PCINT7 7
508
#define PCINT6 6
509
#define PCINT5 5
510
#define PCINT4 4
511
#define PCINT3 3
512
#define PCINT2 2
513
#define PCINT1 1
514
#define PCINT0 0
515
516
/* Reserved [0x6C..0x6D] */
517
518
#define TIMSK0 _SFR_MEM8(0x6E)
519
#define OCIE0B 2
520
#define OCIE0A 1
521
#define TOIE0 0
522
523
#define TIMSK1 _SFR_MEM8(0x6F)
524
#define ICIE1 5
525
#define OCIE1C 3
526
#define OCIE1B 2
527
#define OCIE1A 1
528
#define TOIE1 0
529
530
#define TIMSK2 _SFR_MEM8(0x70)
531
#define OCIE2B 2
532
#define OCIE2A 1
533
#define TOIE2 0
534
535
#define TIMSK3 _SFR_MEM8(0x71)
536
#define ICIE3 5
537
#define OCIE3C 3
538
#define OCIE3B 2
539
#define OCIE3A 1
540
#define TOIE3 0
541
542
/* Reserved [0x72..0x73] */
543
544
#define XMCRA _SFR_MEM8(0x74)
545
#define SRE 7
546
#define SRL2 6
547
#define SRL1 5
548
#define SRL0 4
549
#define SRW11 3
550
#define SRW10 2
551
#define SRW01 1
552
#define SRW00 0
553
554
#define XMCRB _SFR_MEM8(0x75)
555
#define XMBK 7
556
#define XMM2 2
557
#define XMM1 1
558
#define XMM0 0
559
560
/* Reserved [0x76..0x77] */
561
562
/* RegDef: ADC Data Register */
563
#ifndef __ASSEMBLER__
564
#define ADC _SFR_MEM16(0x78)
565
#endif
566
#define ADCW _SFR_MEM16(0x78)
567
#define ADCL _SFR_MEM8(0x78)
568
#define ADCH _SFR_MEM8(0x79)
569
570
#define ADCSRA _SFR_MEM8(0x7A)
571
#define ADEN 7
572
#define ADSC 6
573
#define ADATE 5
574
#define ADIF 4
575
#define ADIE 3
576
#define ADPS2 2
577
#define ADPS1 1
578
#define ADPS0 0
579
580
#define ADCSRB _SFR_MEM8(0x7B)
581
#define ACME 6
582
#define ADTS2 2
583
#define ADTS1 1
584
#define ADTS0 0
585
586
#define ADMUX _SFR_MEM8(0x7C)
587
#define REFS1 7
588
#define REFS0 6
589
#define ADLAR 5
590
#define MUX4 4
591
#define MUX3 3
592
#define MUX2 2
593
#define MUX1 1
594
#define MUX0 0
595
596
/* Reserved [0x7D] */
597
598
#define DIDR0 _SFR_MEM8(0x7E)
599
#define ADC7D 7
600
#define ADC6D 6
601
#define ADC5D 5
602
#define ADC4D 4
603
#define ADC3D 3
604
#define ADC2D 2
605
#define ADC1D 1
606
#define ADC0D 0
607
608
#define DIDR1 _SFR_MEM8(0x7F)
609
#define AIN1D 1
610
#define AIN0D 0
611
612
#define TCCR1A _SFR_MEM8(0x80)
613
#define COM1A1 7
614
#define COM1A0 6
615
#define COM1B1 5
616
#define COM1B0 4
617
#define COM1C1 3
618
#define COM1C0 2
619
#define WGM11 1
620
#define WGM10 0
621
622
#define TCCR1B _SFR_MEM8(0x81)
623
#define ICNC1 7
624
#define ICES1 6
625
#define WGM13 4
626
#define WGM12 3
627
#define CS12 2
628
#define CS11 1
629
#define CS10 0
630
631
#define TCCR1C _SFR_MEM8(0x82)
632
#define FOC1A 7
633
#define FOC1B 6
634
#define FOC1C 5
635
636
/* Reserved [0x83] */
637
638
/* Combine TCNT1L and TCNT1H */
639
#define TCNT1 _SFR_MEM16(0x84)
640
641
#define TCNT1L _SFR_MEM8(0x84)
642
#define TCNT1H _SFR_MEM8(0x85)
643
644
/* Combine ICR1L and ICR1H */
645
#define ICR1 _SFR_MEM16(0x86)
646
647
#define ICR1L _SFR_MEM8(0x86)
648
#define ICR1H _SFR_MEM8(0x87)
649
650
/* Combine OCR1AL and OCR1AH */
651
#define OCR1A _SFR_MEM16(0x88)
652
653
#define OCR1AL _SFR_MEM8(0x88)
654
#define OCR1AH _SFR_MEM8(0x89)
655
656
/* Combine OCR1BL and OCR1BH */
657
#define OCR1B _SFR_MEM16(0x8A)
658
659
#define OCR1BL _SFR_MEM8(0x8A)
660
#define OCR1BH _SFR_MEM8(0x8B)
661
662
/* Combine OCR1CL and OCR1CH */
663
#define OCR1C _SFR_MEM16(0x8C)
664
665
#define OCR1CL _SFR_MEM8(0x8C)
666
#define OCR1CH _SFR_MEM8(0x8D)
667
668
/* Reserved [0x8E..0x8F] */
669
670
#define TCCR3A _SFR_MEM8(0x90)
671
#define COM3A1 7
672
#define COM3A0 6
673
#define COM3B1 5
674
#define COM3B0 4
675
#define COM3C1 3
676
#define COM3C0 2
677
#define WGM31 1
678
#define WGM30 0
679
680
#define TCCR3B _SFR_MEM8(0x91)
681
#define ICNC3 7
682
#define ICES3 6
683
#define WGM33 4
684
#define WGM32 3
685
#define CS32 2
686
#define CS31 1
687
#define CS30 0
688
689
#define TCCR3C _SFR_MEM8(0x92)
690
#define FOC3A 7
691
#define FOC3B 6
692
#define FOC3C 5
693
694
/* Reserved [0x93] */
695
696
/* Combine TCNT3L and TCNT3H */
697
#define TCNT3 _SFR_MEM16(0x94)
698
699
#define TCNT3L _SFR_MEM8(0x94)
700
#define TCNT3H _SFR_MEM8(0x95)
701
702
/* Combine ICR3L and ICR3H */
703
#define ICR3 _SFR_MEM16(0x96)
704
705
#define ICR3L _SFR_MEM8(0x96)
706
#define ICR3H _SFR_MEM8(0x97)
707
708
/* Combine OCR3AL and OCR3AH */
709
#define OCR3A _SFR_MEM16(0x98)
710
711
#define OCR3AL _SFR_MEM8(0x98)
712
#define OCR3AH _SFR_MEM8(0x99)
713
714
/* Combine OCR3BL and OCR3BH */
715
#define OCR3B _SFR_MEM16(0x9A)
716
717
#define OCR3BL _SFR_MEM8(0x9A)
718
#define OCR3BH _SFR_MEM8(0x9B)
719
720
/* Combine OCR3CL and OCR3CH */
721
#define OCR3C _SFR_MEM16(0x9C)
722
723
#define OCR3CL _SFR_MEM8(0x9C)
724
#define OCR3CH _SFR_MEM8(0x9D)
725
726
#if defined(__AT90USBxx7__)
727
728
#define UHCON _SFR_MEM8(0x9E)
729
#define RESUME 2
730
#define RESET 1
731
#define SOFEN 0
732
733
#define UHINT _SFR_MEM8(0x9F)
734
#define HWUPI 6
735
#define HSOFI 5
736
#define RXRSMI 4
737
#define RSMEDI 3
738
#define RSTI 2
739
#define DDISCI 1
740
#define DCONNI 0
741
742
#define UHIEN _SFR_MEM8(0xA0)
743
#define HWUPE 6
744
#define HSOFE 5
745
#define RXRSME 4
746
#define RSMEDE 3
747
#define RSTE 2
748
#define DDISCE 1
749
#define DCONNE 0
750
751
#define UHADDR _SFR_MEM8(0xA1)
752
753
/* Combine UHFNUML and UHFNUMH */
754
#define UHFNUM _SFR_MEM16(0xA2)
755
756
#define UHFNUML _SFR_MEM8(0xA2)
757
#define UHFNUMH _SFR_MEM8(0xA3)
758
759
#define UHFLEN _SFR_MEM8(0xA4)
760
761
#define UPINRQX _SFR_MEM8(0xA5)
762
763
#define UPINTX _SFR_MEM8(0xA6)
764
#define FIFOCON 7
765
#define NAKEDI 6
766
#define RWAL 5
767
#define PERRI 4
768
#define TXSTPI 3
769
#define TXOUTI 2
770
#define RXSTALLI 1
771
#define RXINI 0
772
773
#define UPNUM _SFR_MEM8(0xA7)
774
775
#define UPRST _SFR_MEM8(0xA8)
776
#define PRST6 6
777
#define PRST5 5
778
#define PRST4 4
779
#define PRST3 3
780
#define PRST2 2
781
#define PRST1 1
782
#define PRST0 0
783
784
#define UPCONX _SFR_MEM8(0xA9)
785
#define PFREEZE 6
786
#define INMODE 5
787
/* #define AUTOSW 4 */
/* Reserved */
788
#define RSTDT 3
789
#define PEN 0
790
791
#define UPCFG0X _SFR_MEM8(0XAA)
792
#define PTYPE1 7
793
#define PTYPE0 6
794
#define PTOKEN1 5
795
#define PTOKEN0 4
796
#define PEPNUM3 3
797
#define PEPNUM2 2
798
#define PEPNUM1 1
799
#define PEPNUM0 0
800
801
#define UPCFG1X _SFR_MEM8(0XAB)
802
#define PSIZE2 6
803
#define PSIZE1 5
804
#define PSIZE0 4
805
#define PBK1 3
806
#define PBK0 2
807
#define ALLOC 1
808
809
#define UPSTAX _SFR_MEM8(0XAC)
810
#define CFGOK 7
811
#define OVERFI 6
812
#define UNDERFI 5
813
#define DTSEQ1 3
814
#define DTSEQ0 2
815
#define NBUSYBK1 1
816
#define NBUSYBK0 0
817
818
#define UPCFG2X _SFR_MEM8(0XAD)
819
820
#define UPIENX _SFR_MEM8(0XAE)
821
#define FLERRE 7
822
#define NAKEDE 6
823
#define PERRE 4
824
#define TXSTPE 3
825
#define TXOUTE 2
826
#define RXSTALLE 1
827
#define RXINE 0
828
829
#define UPDATX _SFR_MEM8(0XAF)
830
831
#endif
/* __AT90USBxx7__ */
832
833
#define TCCR2A _SFR_MEM8(0xB0)
834
#define COM2A1 7
835
#define COM2A0 6
836
#define COM2B1 5
837
#define COM2B0 4
838
#define WGM21 1
839
#define WGM20 0
840
841
#define TCCR2B _SFR_MEM8(0xB1)
842
#define FOC2A 7
843
#define FOC2B 6
844
#define WGM22 3
845
#define CS22 2
846
#define CS21 1
847
#define CS20 0
848
849
#define TCNT2 _SFR_MEM8(0xB2)
850
851
#define OCR2A _SFR_MEM8(0xB3)
852
853
#define OCR2B _SFR_MEM8(0xB4)
854
855
/* Reserved [0xB5] */
856
857
#define ASSR _SFR_MEM8(0xB6)
858
#define EXCLK 6
859
#define AS2 5
860
#define TCN2UB 4
861
#define OCR2AUB 3
862
#define OCR2BUB 2
863
#define TCR2AUB 1
864
#define TCR2BUB 0
865
866
/* Reserved [0xB7] */
867
868
#define TWBR _SFR_MEM8(0xB8)
869
870
#define TWSR _SFR_MEM8(0xB9)
871
#define TWS7 7
872
#define TWS6 6
873
#define TWS5 5
874
#define TWS4 4
875
#define TWS3 3
876
#define TWPS1 1
877
#define TWPS0 0
878
879
#define TWAR _SFR_MEM8(0xBA)
880
#define TWA6 7
881
#define TWA5 6
882
#define TWA4 5
883
#define TWA3 4
884
#define TWA2 3
885
#define TWA1 2
886
#define TWA0 1
887
#define TWGCE 0
888
889
#define TWDR _SFR_MEM8(0xBB)
890
891
#define TWCR _SFR_MEM8(0xBC)
892
#define TWINT 7
893
#define TWEA 6
894
#define TWSTA 5
895
#define TWSTO 4
896
#define TWWC 3
897
#define TWEN 2
898
#define TWIE 0
899
900
#define TWAMR _SFR_MEM8(0xBD)
901
#define TWAM6 7
902
#define TWAM5 6
903
#define TWAM4 5
904
#define TWAM3 4
905
#define TWAM2 3
906
#define TWAM1 2
907
#define TWAM0 1
908
909
/* Reserved [0xBE..0xC7] */
910
911
#define UCSR1A _SFR_MEM8(0xC8)
912
#define RXC1 7
913
#define TXC1 6
914
#define UDRE1 5
915
#define FE1 4
916
#define DOR1 3
917
#define UPE1 2
918
#define U2X1 1
919
#define MPCM1 0
920
921
#define UCSR1B _SFR_MEM8(0XC9)
922
#define RXCIE1 7
923
#define TXCIE1 6
924
#define UDRIE1 5
925
#define RXEN1 4
926
#define TXEN1 3
927
#define UCSZ12 2
928
#define RXB81 1
929
#define TXB81 0
930
931
#define UCSR1C _SFR_MEM8(0xCA)
932
#define UMSEL11 7
933
#define UMSEL10 6
934
#define UPM11 5
935
#define UPM10 4
936
#define USBS1 3
937
#define UCSZ11 2
938
#define UCSZ10 1
939
#define UCPOL1 0
940
941
/* Reserved [0xCB] */
942
943
/* Combine UBRR1L and UBRR1H */
944
#define UBRR1 _SFR_MEM16(0xCC)
945
946
#define UBRR1L _SFR_MEM8(0xCC)
947
#define UBRR1H _SFR_MEM8(0xCD)
948
949
#define UDR1 _SFR_MEM8(0XCE)
950
951
/* Reserved [0xCF..0xD6] */
952
953
#define UHWCON _SFR_MEM8(0XD7)
954
#define UIMOD 7
955
#define UIDE 6
956
#define UVCONE 4
957
#define UVREGE 0
958
959
#define USBCON _SFR_MEM8(0XD8)
960
#define USBE 7
961
#define HOST 6
962
#define FRZCLK 5
963
#define OTGPADE 4
964
#define IDTE 1
965
#define VBUSTE 0
966
967
#define USBSTA _SFR_MEM8(0XD9)
968
#define SPEED 3
969
#define ID 1
970
#define VBUS 0
971
972
#define USBINT _SFR_MEM8(0XDA)
973
#define IDTI 1
974
#define VBUSTI 0
975
976
/* Combine UDPADDL and UDPADDH */
977
#define UDPADD _SFR_MEM16(0xDB)
978
979
#define UDPADDL _SFR_MEM8(0xDB)
980
#define UDPADDH _SFR_MEM8(0xDC)
981
#define DPACC 7
982
983
984
985
#define OTGCON _SFR_MEM8(0XDD)
986
#define HNPREQ 5
987
#define SRPREQ 4
988
#define SRPSEL 3
989
#define VBUSHWC 2
990
#define VBUSREQ 1
991
#define VBUSRQC 0
992
993
#define OTGIEN _SFR_MEM8(0XDE)
994
#define STOE 5
995
#define HNPERRE 4
996
#define ROLEEXE 3
997
#define BCERRE 2
998
#define VBERRE 1
999
#define SRPE 0
1000
1001
#define OTGINT _SFR_MEM8(0XDF)
1002
#define STOI 5
1003
#define HNPERRI 4
1004
#define ROLEEXI 3
1005
#define BCERRI 2
1006
#define VBERRI 1
1007
#define SRPI 0
1008
1009
#endif
1010
1011
#define UDCON _SFR_MEM8(0XE0)
1012
#define LSM 2
1013
#define RMWKUP 1
1014
#define DETACH 0
1015
1016
#define UDINT _SFR_MEM8(0XE1)
1017
#define UPRSMI 6
1018
#define EORSMI 5
1019
#define WAKEUPI 4
1020
#define EORSTI 3
1021
#define SOFI 2
1022
/* #define MSOFI 1 */
/* Reserved */
1023
#define SUSPI 0
1024
1025
#define UDIEN _SFR_MEM8(0XE2)
1026
#define UPRSME 6
1027
#define EORSME 5
1028
#define WAKEUPE 4
1029
#define EORSTE 3
1030
#define SOFE 2
1031
/* #define MSOFE 1 */
/* Reserved */
1032
#define SUSPE 0
1033
1034
#define UDADDR _SFR_MEM8(0XE3)
1035
#define ADDEN 7
1036
1037
/* Combine UDFNUML and UDFNUMH */
1038
#define UDFNUM _SFR_MEM16(0xE4)
1039
1040
#define UDFNUML _SFR_MEM8(0xE4)
1041
#define UDFNUMH _SFR_MEM8(0xE5)
1042
1043
#define UDMFN _SFR_MEM8(0XE6)
1044
#define FNCERR 4
1045
1046
#define UDTST _SFR_MEM8(0XE7)
1047
#define OPMODE2 5
1048
#define TSTPCKT 4
1049
#define TSTK 3
1050
#define TSTJ 2
1051
1052
#define UEINTX _SFR_MEM8(0XE8)
1053
#define FIFOCON 7
1054
#define NAKINI 6
1055
#define RWAL 5
1056
#define NAKOUTI 4
1057
#define RXSTPI 3
1058
#define RXOUTI 2
1059
#define STALLEDI 1
1060
#define TXINI 0
1061
1062
#define UENUM _SFR_MEM8(0XE9)
1063
1064
#define UERST _SFR_MEM8(0XEA)
1065
#define EPRST6 6
1066
#define EPRST5 5
1067
#define EPRST4 4
1068
#define EPRST3 3
1069
#define EPRST2 2
1070
#define EPRST1 1
1071
#define EPRST0 0
1072
1073
#define UECONX _SFR_MEM8(0XEB)
1074
#define STALLRQ 5
1075
#define STALLRQC 4
1076
#define RSTDT 3
1077
#define EPEN 0
1078
1079
#define UECFG0X _SFR_MEM8(0XEC)
1080
#define EPTYPE1 7
1081
#define EPTYPE0 6
1082
/* #define ISOSW 3 */
/* Reserved */
1083
/* #define AUTOSW 2 */
/* Reserved */
1084
/* #define NYETSDIS 1 */
/* Reserved */
1085
#define EPDIR 0
1086
1087
#define UECFG1X _SFR_MEM8(0XED)
1088
#define EPSIZE2 6
1089
#define EPSIZE1 5
1090
#define EPSIZE0 4
1091
#define EPBK1 3
1092
#define EPBK0 2
1093
#define ALLOC 1
1094
1095
#define UESTA0X _SFR_MEM8(0XEE)
1096
#define CFGOK 7
1097
#define OVERFI 6
1098
#define UNDERFI 5
1099
#define ZLPSEEN 4
1100
#define DTSEQ1 3
1101
#define DTSEQ0 2
1102
#define NBUSYBK1 1
1103
#define NBUSYBK0 0
1104
1105
#define UESTA1X _SFR_MEM8(0XEF)
1106
#define CTRLDIR 2
1107
#define CURRBK1 1
1108
#define CURRBK0 0
1109
1110
#define UEIENX _SFR_MEM8(0XF0)
1111
#define FLERRE 7
1112
#define NAKINE 6
1113
#define NAKOUTE 4
1114
#define RXSTPE 3
1115
#define RXOUTE 2
1116
#define STALLEDE 1
1117
#define TXINE 0
1118
1119
#define UEDATX _SFR_MEM8(0XF1)
1120
1121
/* Combine UEBCLX and UEBCHX */
1122
#define UEBCX _SFR_MEM16(0xF2)
1123
1124
#define UEBCLX _SFR_MEM8(0xF2)
1125
#define UEBCHX _SFR_MEM8(0xF3)
1126
1127
#define UEINT _SFR_MEM8(0XF4)
1128
#define EPINT6 6
1129
#define EPINT5 5
1130
#define EPINT4 4
1131
#define EPINT3 3
1132
#define EPINT2 2
1133
#define EPINT1 1
1134
#define EPINT0 0
1135
1136
1137
1138
#define UPERRX _SFR_MEM8(0XF5)
1139
#define COUNTER1 6
1140
#define COUNTER0 5
1141
#define CRC16 4
1142
#define TIMEOUT 3
1143
#define PID 2
1144
#define DATAPID 1
1145
#define DATATGL 0
1146
1147
/* Combine UPBCLX and UPBCHX */
1148
#define UPBCX _SFR_MEM16(0xF6)
1149
1150
#define UPBCLX _SFR_MEM8(0xF6)
1151
#define UPBCHX _SFR_MEM8(0xF7)
1152
1153
#define UPINT _SFR_MEM8(0XF8)
1154
#define PINT6 6
1155
#define PINT5 5
1156
#define PINT4 4
1157
#define PINT3 3
1158
#define PINT2 2
1159
#define PINT1 1
1160
#define PINT0 0
1161
1162
#define OTGTCON _SFR_MEM8(0XF9)
1163
#define PAGE1 6
1164
#define PAGE0 5
1165
#define VALUE1 1
1166
#define VALUE0 0
1167
1168
#endif
1169
1170
/* Reserved [0xFA..0xFF] */
1171
1172
/* Interrupt vectors */
1173
1174
/* External Interrupt Request 0 */
1175
#define INT0_vect _VECTOR(1)
1176
1177
/* External Interrupt Request 1 */
1178
#define INT1_vect _VECTOR(2)
1179
1180
/* External Interrupt Request 2 */
1181
#define INT2_vect _VECTOR(3)
1182
1183
/* External Interrupt Request 3 */
1184
#define INT3_vect _VECTOR(4)
1185
1186
/* External Interrupt Request 4 */
1187
#define INT4_vect _VECTOR(5)
1188
1189
/* External Interrupt Request 5 */
1190
#define INT5_vect _VECTOR(6)
1191
1192
/* External Interrupt Request 6 */
1193
#define INT6_vect _VECTOR(7)
1194
1195
/* External Interrupt Request 7 */
1196
#define INT7_vect _VECTOR(8)
1197
1198
/* Pin Change Interrupt Request 0 */
1199
#define PCINT0_vect _VECTOR(9)
1200
1201
/* USB General Interrupt Request */
1202
#define USB_GEN_vect _VECTOR(10)
1203
1204
/* USB Endpoint/Pipe Interrupt Communication Request */
1205
#define USB_COM_vect _VECTOR(11)
1206
1207
/* Watchdog Time-out Interrupt */
1208
#define WDT_vect _VECTOR(12)
1209
1210
/* Timer/Counter2 Compare Match A */
1211
#define TIMER2_COMPA_vect _VECTOR(13)
1212
1213
/* Timer/Counter2 Compare Match B */
1214
#define TIMER2_COMPB_vect _VECTOR(14)
1215
1216
/* Timer/Counter2 Overflow */
1217
#define TIMER2_OVF_vect _VECTOR(15)
1218
1219
/* Timer/Counter1 Capture Event */
1220
#define TIMER1_CAPT_vect _VECTOR(16)
1221
1222
/* Timer/Counter1 Compare Match A */
1223
#define TIMER1_COMPA_vect _VECTOR(17)
1224
1225
/* Timer/Counter1 Compare Match B */
1226
#define TIMER1_COMPB_vect _VECTOR(18)
1227
1228
/* Timer/Counter1 Compare Match C */
1229
#define TIMER1_COMPC_vect _VECTOR(19)
1230
1231
/* Timer/Counter1 Overflow */
1232
#define TIMER1_OVF_vect _VECTOR(20)
1233
1234
/* Timer/Counter0 Compare Match A */
1235
#define TIMER0_COMPA_vect _VECTOR(21)
1236
1237
/* Timer/Counter0 Compare Match B */
1238
#define TIMER0_COMPB_vect _VECTOR(22)
1239
1240
/* Timer/Counter0 Overflow */
1241
#define TIMER0_OVF_vect _VECTOR(23)
1242
1243
/* SPI Serial Transfer Complete */
1244
#define SPI_STC_vect _VECTOR(24)
1245
1246
/* USART1, Rx Complete */
1247
#define USART1_RX_vect _VECTOR(25)
1248
1249
/* USART1 Data register Empty */
1250
#define USART1_UDRE_vect _VECTOR(26)
1251
1252
/* USART1, Tx Complete */
1253
#define USART1_TX_vect _VECTOR(27)
1254
1255
/* Analog Comparator */
1256
#define ANALOG_COMP_vect _VECTOR(28)
1257
1258
/* ADC Conversion Complete */
1259
#define ADC_vect _VECTOR(29)
1260
1261
/* EEPROM Ready */
1262
#define EE_READY_vect _VECTOR(30)
1263
1264
/* Timer/Counter3 Capture Event */
1265
#define TIMER3_CAPT_vect _VECTOR(31)
1266
1267
/* Timer/Counter3 Compare Match A */
1268
#define TIMER3_COMPA_vect _VECTOR(32)
1269
1270
/* Timer/Counter3 Compare Match B */
1271
#define TIMER3_COMPB_vect _VECTOR(33)
1272
1273
/* Timer/Counter3 Compare Match C */
1274
#define TIMER3_COMPC_vect _VECTOR(34)
1275
1276
/* Timer/Counter3 Overflow */
1277
#define TIMER3_OVF_vect _VECTOR(35)
1278
1279
/* 2-wire Serial Interface */
1280
#define TWI_vect _VECTOR(36)
1281
1282
/* Store Program Memory Read */
1283
#define SPM_READY_vect _VECTOR(37)
1284
1285
#define _VECTORS_SIZE 152
1286
1287
#if defined(__AT90USBxx6__)
1288
# undef __AT90USBxx6__
1289
#endif
/* __AT90USBxx6__ */
1290
1291
1292
# undef __AT90USBxx7__
1293
#endif
1294
1296
#endif
/* _AVR_IOUSBXX6_7_H_ */
