admin
rtems-admin.git
doxygen
builder
latest
rtems.git
score
cpu
avr
avr
iotn28.h
1
9
/* Copyright (c) 2002, Marek Michalkiewicz
10
All rights reserved.
11
12
Redistribution and use in source and binary forms, with or without
13
modification, are permitted provided that the following conditions are met:
14
15
* Redistributions of source code must retain the above copyright
16
notice, this list of conditions and the following disclaimer.
17
18
* Redistributions in binary form must reproduce the above copyright
19
notice, this list of conditions and the following disclaimer in
20
the documentation and/or other materials provided with the
21
distribution.
22
23
* Neither the name of the copyright holders nor the names of
24
contributors may be used to endorse or promote products derived
25
from this software without specific prior written permission.
26
27
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
28
AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
29
IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
30
ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
31
LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
32
CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
33
SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
34
INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
35
CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
36
ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
37
POSSIBILITY OF SUCH DAMAGE. */
38
39
40
/* avr/iotn28.h - definitions for ATtiny28 */
41
42
#ifndef _AVR_IOTN28_H_
43
#define _AVR_IOTN28_H_ 1
44
45
/* This file should only be included from <avr/io.h>, never directly. */
46
47
#ifndef _AVR_IO_H_
48
# error "Include <avr/io.h> instead of this file."
49
#endif
50
51
#ifndef _AVR_IOXXX_H_
52
# define _AVR_IOXXX_H_ "iotn28.h"
53
#else
54
# error "Attempt to include more than one <avr/ioXXX.h> file."
55
#endif
56
57
#ifndef __ASSEMBLER__
58
# warning "MCU not supported by the C compiler"
59
#endif
60
69
/* I/O registers */
70
71
#define OSCCAL _SFR_IO8(0x00)
72
73
#define WDTCR _SFR_IO8(0x01)
74
75
#define MODCR _SFR_IO8(0x02)
76
77
#define TCNT0 _SFR_IO8(0x03)
78
#define TCCR0 _SFR_IO8(0x04)
79
80
#define IFR _SFR_IO8(0x05)
81
#define ICR _SFR_IO8(0x06)
82
83
#define MCUCS _SFR_IO8(0x07)
84
85
#define ACSR _SFR_IO8(0x08)
86
87
/* 0x09..0x0F reserved */
88
89
#define PIND _SFR_IO8(0x10)
90
#define DDRD _SFR_IO8(0x11)
91
#define PORTD _SFR_IO8(0x12)
92
93
/* 0x13..0x15 reserved */
94
95
#define PINB _SFR_IO8(0x16)
96
97
/* 0x17..0x18 reserved */
98
99
#define PINA _SFR_IO8(0x19)
100
#define PACR _SFR_IO8(0x1A)
101
#define PORTA _SFR_IO8(0x1B)
102
103
/* 0x1C..0x3E reserved */
104
105
/* 0x3F SREG */
106
107
/* Interrupt vectors */
108
109
/* External Interrupt 0 */
110
#define INT0_vect _VECTOR(1)
111
#define SIG_INTERRUPT0 _VECTOR(1)
112
113
/* External Interrupt 1 */
114
#define INT1_vect _VECTOR(2)
115
#define SIG_INTERRUPT1 _VECTOR(2)
116
117
/* Low-level Input on Port B */
118
#define LOWLEVEL_IO_PINS_vect _VECTOR(3)
119
#define SIG_PIN _VECTOR(3)
120
121
/* Timer/Counter0 Overflow */
122
#define TIMER0_OVF_vect _VECTOR(4)
123
#define SIG_OVERFLOW0 _VECTOR(4)
124
125
/* Analog Comparator */
126
#define ANA_COMP_vect _VECTOR(5)
127
#define SIG_COMPARATOR _VECTOR(5)
128
129
#define _VECTORS_SIZE 12
130
131
132
/* Bit numbers */
133
134
/* ICR */
135
#define INT1 7
136
#define INT0 6
137
#define LLIE 5
138
#define TOIE0 4
139
#define ISC11 3
140
#define ISC10 2
141
#define ISC01 1
142
#define ISC00
143
144
/* IFR */
145
#define INTF1 7
146
#define INTF0 6
147
#define TOV0 4
148
149
/* MCUCS */
150
#define PLUPB 7
151
#define SE 5
152
#define SM 4
153
#define WDRF 3
154
#define EXTRF 1
155
#define PORF 0
156
157
/* TCCR0 */
158
#define FOV0 7
159
#define OOM01 4
160
#define OOM00 3
161
#define CS02 2
162
#define CS01 1
163
#define CS00 0
164
165
/* MODCR */
166
#define ONTIM4 7
167
#define ONTIM3 6
168
#define ONTIM2 5
169
#define ONTIM1 4
170
#define ONTIM0 3
171
#define MCONF2 2
172
#define MCONF1 1
173
#define MCONF0 0
174
175
/* WDTCR */
176
#define WDTOE 4
177
#define WDE 3
178
#define WDP2 2
179
#define WDP1 1
180
#define WDP0 0
181
182
183
PA2 = IR
184
185
186
/* PORTA */
187
#define PA3 3
188
#define PA2 2
189
#define PA1 1
190
#define PA0 0
191
192
/* PACR */
193
#define DDA3 3
194
#define PA2HC 2
195
#define DDA1 1
196
#define DDA0 0
197
198
/* PINA */
199
#define PINA3 3
200
#define PINA1 1
201
#define PINA0 0
202
203
204
PB4 = INT1
205
PB3 = INT0
206
PB2 = T0
207
PB1 = AIN1
208
PB0 = AIN0
209
210
211
/* PINB */
212
#define PINB7 7
213
#define PINB6 6
214
#define PINB5 5
215
#define PINB4 4
216
#define PINB3 3
217
#define PINB2 2
218
#define PINB1 1
219
#define PINB0 0
220
221
/* PORTD */
222
#define PD7 7
223
#define PD6 6
224
#define PD5 5
225
#define PD4 4
226
#define PD3 3
227
#define PD2 2
228
#define PD1 1
229
#define PD0 0
230
231
/* DDRD */
232
#define DDD7 7
233
#define DDD6 6
234
#define DDD5 5
235
#define DDD4 4
236
#define DDD3 3
237
#define DDD2 2
238
#define DDD1 1
239
#define DDD0 0
240
241
/* PIND */
242
#define PIND7 7
243
#define PIND6 6
244
#define PIND5 5
245
#define PIND4 4
246
#define PIND3 3
247
#define PIND2 2
248
#define PIND1 1
249
#define PIND0 0
250
251
/* ACSR */
252
#define ACD 7
253
#define ACO 5
254
#define ACI 4
255
#define ACIE 3
256
#define ACIS1 1
257
#define ACIS0 0
258
259
/* Last memory addresses */
260
#define RAMEND 0x1F
261
#define XRAMEND 0x0
262
#define E2END 0x0
263
#define E2PAGESIZE 0
264
#define FLASHEND 0x7FF
265
266
267
/* Fuses */
268
269
#define FUSE_MEMORY_SIZE 1
270
271
/* Fuse Byte */
272
#define FUSE_CKSEL0 (unsigned char)~_BV(0)
273
#define FUSE_CKSEL1 (unsigned char)~_BV(1)
274
#define FUSE_CKSEL2 (unsigned char)~_BV(2)
275
#define FUSE_CKSEL3 (unsigned char)~_BV(3)
276
#define FUSE_INTCAP (unsigned char)~_BV(4)
277
#define FUSE_DEFAULT (FUSE_CKSEL0 & FUSE_CKSEL2 & FUSE_CKSEL3)
278
279
280
/* Lock Bits */
281
#define __LOCK_BITS_EXIST
282
283
284
/* Signature */
285
#define SIGNATURE_0 0x1E
286
#define SIGNATURE_1 0x91
287
#define SIGNATURE_2 0x07
288
291
#endif
/* _AVR_IOTN28_H_ */
