admin
rtems-admin.git
doxygen
builder
latest
rtems.git
score
cpu
avr
avr
iom165.h
1
9
/* Copyright (c) 2004,2005,2006 Eric B. Weddington
10
All rights reserved.
11
12
Redistribution and use in source and binary forms, with or without
13
modification, are permitted provided that the following conditions are met:
14
15
* Redistributions of source code must retain the above copyright
16
notice, this list of conditions and the following disclaimer.
17
18
* Redistributions in binary form must reproduce the above copyright
19
notice, this list of conditions and the following disclaimer in
20
the documentation and/or other materials provided with the
21
distribution.
22
23
* Neither the name of the copyright holders nor the names of
24
contributors may be used to endorse or promote products derived
25
from this software without specific prior written permission.
26
27
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
28
AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
29
IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
30
ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
31
LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
32
CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
33
SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
34
INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
35
CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
36
ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
37
POSSIBILITY OF SUCH DAMAGE. */
38
39
40
/* avr/iom165.h - definitions for ATmega165 */
41
42
#ifndef _AVR_IOM165_H_
43
#define _AVR_IOM165_H_ 1
44
45
/* This file should only be included from <avr/io.h>, never directly. */
46
47
#ifndef _AVR_IO_H_
48
# error "Include <avr/io.h> instead of this file."
49
#endif
50
51
#ifndef _AVR_IOXXX_H_
52
# define _AVR_IOXXX_H_ "iom165.h"
53
#else
54
# error "Attempt to include more than one <avr/ioXXX.h> file."
55
#endif
56
65
/* Registers and associated bit numbers */
66
67
#define PINA _SFR_IO8(0x00)
68
#define PINA7 7
69
#define PINA6 6
70
#define PINA5 5
71
#define PINA4 4
72
#define PINA3 3
73
#define PINA2 2
74
#define PINA1 1
75
#define PINA0 0
76
77
#define DDRA _SFR_IO8(0x01)
78
#define DDA7 7
79
#define DDA6 6
80
#define DDA5 5
81
#define DDA4 4
82
#define DDA3 3
83
#define DDA2 2
84
#define DDA1 1
85
#define DDA0 0
86
87
#define PORTA _SFR_IO8(0x02)
88
#define PA7 7
89
#define PA6 6
90
#define PA5 5
91
#define PA4 4
92
#define PA3 3
93
#define PA2 2
94
#define PA1 1
95
#define PA0 0
96
97
#define PINB _SFR_IO8(0x03)
98
#define PINB7 7
99
#define PINB6 6
100
#define PINB5 5
101
#define PINB4 4
102
#define PINB3 3
103
#define PINB2 2
104
#define PINB1 1
105
#define PINB0 0
106
107
#define DDRB _SFR_IO8(0x04)
108
#define DDB7 7
109
#define DDB6 6
110
#define DDB5 5
111
#define DDB4 4
112
#define DDB3 3
113
#define DDB2 2
114
#define DDB1 1
115
#define DDB0 0
116
117
#define PORTB _SFR_IO8(0x05)
118
#define PB7 7
119
#define PB6 6
120
#define PB5 5
121
#define PB4 4
122
#define PB3 3
123
#define PB2 2
124
#define PB1 1
125
#define PB0 0
126
127
#define PINC _SFR_IO8(0x06)
128
#define PINC7 7
129
#define PINC6 6
130
#define PINC5 5
131
#define PINC4 4
132
#define PINC3 3
133
#define PINC2 2
134
#define PINC1 1
135
#define PINC0 0
136
137
#define DDRC _SFR_IO8(0x07)
138
#define DDC7 7
139
#define DDC6 6
140
#define DDC5 5
141
#define DDC4 4
142
#define DDC3 3
143
#define DDC2 2
144
#define DDC1 1
145
#define DDC0 0
146
147
#define PORTC _SFR_IO8(0x08)
148
#define PC7 7
149
#define PC6 6
150
#define PC5 5
151
#define PC4 4
152
#define PC3 3
153
#define PC2 2
154
#define PC1 1
155
#define PC0 0
156
157
#define PIND _SFR_IO8(0x09)
158
#define PIND7 7
159
#define PIND6 6
160
#define PIND5 5
161
#define PIND4 4
162
#define PIND3 3
163
#define PIND2 2
164
#define PIND1 1
165
#define PIND0 0
166
167
#define DDRD _SFR_IO8(0x0A)
168
#define DDD7 7
169
#define DDD6 6
170
#define DDD5 5
171
#define DDD4 4
172
#define DDD3 3
173
#define DDD2 2
174
#define DDD1 1
175
#define DDD0 0
176
177
#define PORTD _SFR_IO8(0x0B)
178
#define PD7 7
179
#define PD6 6
180
#define PD5 5
181
#define PD4 4
182
#define PD3 3
183
#define PD2 2
184
#define PD1 1
185
#define PD0 0
186
187
#define PINE _SFR_IO8(0x0C)
188
#define PINE7 7
189
#define PINE6 6
190
#define PINE5 5
191
#define PINE4 4
192
#define PINE3 3
193
#define PINE2 2
194
#define PINE1 1
195
#define PINE0 0
196
197
#define DDRE _SFR_IO8(0x0D)
198
#define DDE7 7
199
#define DDE6 6
200
#define DDE5 5
201
#define DDE4 4
202
#define DDE3 3
203
#define DDE2 2
204
#define DDE1 1
205
#define DDE0 0
206
207
#define PORTE _SFR_IO8(0x0E)
208
#define PE7 7
209
#define PE6 6
210
#define PE5 5
211
#define PE4 4
212
#define PE3 3
213
#define PE2 2
214
#define PE1 1
215
#define PE0 0
216
217
#define PINF _SFR_IO8(0x0F)
218
#define PINF7 7
219
#define PINF6 6
220
#define PINF5 5
221
#define PINF4 4
222
#define PINF3 3
223
#define PINF2 2
224
#define PINF1 1
225
#define PINF0 0
226
227
#define DDRF _SFR_IO8(0x10)
228
#define DDF7 7
229
#define DDF6 6
230
#define DDF5 5
231
#define DDF4 4
232
#define DDF3 3
233
#define DDF2 2
234
#define DDF1 1
235
#define DDF0 0
236
237
#define PORTF _SFR_IO8(0x11)
238
#define PF7 7
239
#define PF6 6
240
#define PF5 5
241
#define PF4 4
242
#define PF3 3
243
#define PF2 2
244
#define PF1 1
245
#define PF0 0
246
247
#define PING _SFR_IO8(0x12)
248
#define PING4 4
249
#define PING3 3
250
#define PING2 2
251
#define PING1 1
252
#define PING0 0
253
254
#define DDRG _SFR_IO8(0x13)
255
#define DDG4 4
256
#define DDG3 3
257
#define DDG2 2
258
#define DDG1 1
259
#define DDG0 0
260
261
#define PORTG _SFR_IO8(0x14)
262
#define PG4 4
263
#define PG3 3
264
#define PG2 2
265
#define PG1 1
266
#define PG0 0
267
268
#define TIFR0 _SFR_IO8(0x15)
269
#define TOV0 0
270
#define OCF0A 1
271
272
#define TIFR1 _SFR_IO8(0x16)
273
#define TOV1 0
274
#define OCF1A 1
275
#define OCF1B 2
276
#define ICF1 5
277
278
#define TIFR2 _SFR_IO8(0x17)
279
#define TOV2 0
280
#define OCF2A 1
281
282
/* Reserved [0x18..0x1B] */
283
284
#define EIFR _SFR_IO8(0x1C)
285
#define INTF0 0
286
#define PCIF0 6
287
#define PCIF1 7
288
289
#define EIMSK _SFR_IO8(0x1D)
290
#define INT0 0
291
#define PCIE0 6
292
#define PCIE1 7
293
294
#define GPIOR0 _SFR_IO8(0x1E)
295
296
#define EECR _SFR_IO8(0x1F)
297
#define EERE 0
298
#define EEWE 1
299
#define EEMWE 2
300
#define EERIE 3
301
302
#define EEDR _SFR_IO8(0X20)
303
304
/* Combine EEARL and EEARH */
305
#define EEAR _SFR_IO16(0x21)
306
#define EEARL _SFR_IO8(0x21)
307
#define EEARH _SFR_IO8(0X22)
308
309
/* 6-char sequence denoting where to find the EEPROM registers in memory space.
310
Adresses denoted in hex syntax with uppercase letters. Used by the EEPROM
311
subroutines.
312
First two letters: EECR address.
313
Second two letters: EEDR address.
314
Last two letters: EEAR address. */
315
#define __EEPROM_REG_LOCATIONS__ 1F2021
316
317
#define GTCCR _SFR_IO8(0x23)
318
#define PSR10 0
319
#define PSR2 1
320
#define TSM 7
321
322
#define TCCR0A _SFR_IO8(0x24)
323
#define CS00 0
324
#define CS01 1
325
#define CS02 2
326
#define WGM01 3
327
#define COM0A0 4
328
#define COM0A1 5
329
#define WGM00 6
330
#define FOC0A 7
331
332
/* Reserved [0x25] */
333
334
#define TCNT0 _SFR_IO8(0X26)
335
336
#define OCR0A _SFR_IO8(0X27)
337
338
/* Reserved [0x28..0x29] */
339
340
#define GPIOR1 _SFR_IO8(0x2A)
341
342
#define GPIOR2 _SFR_IO8(0x2B)
343
344
#define SPCR _SFR_IO8(0x2C)
345
#define SPR0 0
346
#define SPR1 1
347
#define CPHA 2
348
#define CPOL 3
349
#define MSTR 4
350
#define DORD 5
351
#define SPE 6
352
#define SPIE 7
353
354
#define SPSR _SFR_IO8(0x2D)
355
#define SPI2X 0
356
#define WCOL 6
357
#define SPIF 7
358
359
#define SPDR _SFR_IO8(0X2E)
360
361
/* Reserved [0x2F] */
362
363
#define ACSR _SFR_IO8(0x30)
364
#define ACIS0 0
365
#define ACIS1 1
366
#define ACIC 2
367
#define ACIE 3
368
#define ACI 4
369
#define ACO 5
370
#define ACBG 6
371
#define ACD 7
372
373
#define OCDR _SFR_IO8(0x31)
374
#define OCDR0 0
375
#define OCDR1 1
376
#define OCDR2 2
377
#define OCDR3 3
378
#define OCDR4 4
379
#define OCDR5 5
380
#define OCDR6 6
381
#define OCD 7 // The datasheet defines this but IMO it should be OCDR7.
382
#define OCDR7 7
383
#define IDRD 7
384
385
/* Reserved [0x32] */
386
387
#define SMCR _SFR_IO8(0x33)
388
#define SE 0
389
#define SM0 1
390
#define SM1 2
391
#define SM2 3
392
393
#define MCUSR _SFR_IO8(0x34)
394
#define PORF 0
395
#define EXTRF 1
396
#define BORF 2
397
#define WDRF 3
398
#define JTRF 4
399
400
#define MCUCR _SFR_IO8(0X35)
401
#define IVCE 0
402
#define IVSEL 1
403
#define PUD 4
404
#define JTD 7
405
406
/* Reserved [0x36] */
407
408
#define SPMCSR _SFR_IO8(0x37)
409
#define SPMEN 0
410
#define PGERS 1
411
#define PGWRT 2
412
#define BLBSET 3
413
#define RWWSRE 4
414
#define RWWSB 6
415
#define SPMIE 7
416
417
/* Reserved [0x38..0x3C] */
418
419
/* SP [0x3D..0x3E] */
420
/* SREG [0x3F] */
421
422
#define WDTCR _SFR_MEM8(0x60)
423
#define WDP0 0
424
#define WDP1 1
425
#define WDP2 2
426
#define WDE 3
427
#define WDCE 4
428
429
#define CLKPR _SFR_MEM8(0x61)
430
#define CLKPS0 0
431
#define CLKPS1 1
432
#define CLKPS2 2
433
#define CLKPS3 3
434
#define CLKPCE 7
435
436
/* Reserved [0x62..0x63] */
437
438
#define PRR _SFR_MEM8(0x64)
439
#define PRADC 0
440
#define PRUSART0 1
441
#define PRSPI 2
442
#define PRTIM1 3
443
444
/* Reserved [0x65] */
445
446
#define OSCCAL _SFR_MEM8(0x66)
447
448
/* Reserved [0x67..0x68] */
449
450
#define EICRA _SFR_MEM8(0x69)
451
#define ISC00 0
452
#define ISC01 1
453
454
/* Reserved [0x6A] */
455
456
/* Combine PCMSK0 and PCMSK1 */
457
#define PCMSK _SFR_MEM16(0x6B)
458
459
#define PCMSK0 _SFR_MEM8(0x6B)
460
#define PCINT0 0
461
#define PCINT1 1
462
#define PCINT2 2
463
#define PCINT3 3
464
#define PCINT4 4
465
#define PCINT5 5
466
#define PCINT6 6
467
#define PCINT7 7
468
469
#define PCMSK1 _SFR_MEM8(0x6C)
470
#define PCINT8 0
471
#define PCINT9 1
472
#define PCINT10 2
473
#define PCINT11 3
474
#define PCINT12 4
475
#define PCINT13 5
476
#define PCINT14 6
477
#define PCINT15 7
478
479
/* Reserved [0x6D] */
480
481
#define TIMSK0 _SFR_MEM8(0x6E)
482
#define TOIE0 0
483
#define OCIE0A 1
484
485
#define TIMSK1 _SFR_MEM8(0x6F)
486
#define TOIE1 0
487
#define OCIE1A 1
488
#define OCIE1B 2
489
#define ICIE1 5
490
491
#define TIMSK2 _SFR_MEM8(0x70)
492
#define TOIE2 0
493
#define OCIE2A 1
494
495
/* Reserved [0x71..0x77] */
496
497
/* Combine ADCL and ADCH */
498
#ifndef __ASSEMBLER__
499
#define ADC _SFR_MEM16(0x78)
500
#endif
501
#define ADCW _SFR_MEM16(0x78)
502
#define ADCL _SFR_MEM8(0x78)
503
#define ADCH _SFR_MEM8(0x79)
504
505
#define ADCSRA _SFR_MEM8(0x7A)
506
#define ADPS0 0
507
#define ADPS1 1
508
#define ADPS2 2
509
#define ADIE 3
510
#define ADIF 4
511
#define ADATE 5
512
#define ADSC 6
513
#define ADEN 7
514
515
#define ADCSRB _SFR_MEM8(0x7B)
516
#define ADTS0 0
517
#define ADTS1 1
518
#define ADTS2 2
519
#define ACME 6
520
521
#define ADMUX _SFR_MEM8(0x7C)
522
#define MUX0 0
523
#define MUX1 1
524
#define MUX2 2
525
#define MUX3 3
526
#define MUX4 4
527
#define ADLAR 5
528
#define REFS0 6
529
#define REFS1 7
530
531
/* Reserved [0x7D] */
532
533
#define DIDR0 _SFR_MEM8(0x7E)
534
#define ADC0D 0
535
#define ADC1D 1
536
#define ADC2D 2
537
#define ADC3D 3
538
#define ADC4D 4
539
#define ADC5D 5
540
#define ADC6D 6
541
#define ADC7D 7
542
543
#define DIDR1 _SFR_MEM8(0x7F)
544
#define AIN0D 0
545
#define AIN1D 1
546
547
#define TCCR1A _SFR_MEM8(0X80)
548
#define WGM10 0
549
#define WGM11 1
550
#define COM1B0 4
551
#define COM1B1 5
552
#define COM1A0 6
553
#define COM1A1 7
554
555
#define TCCR1B _SFR_MEM8(0X81)
556
#define CS10 0
557
#define CS11 1
558
#define CS12 2
559
#define WGM12 3
560
#define WGM13 4
561
#define ICES1 6
562
#define ICNC1 7
563
564
#define TCCR1C _SFR_MEM8(0x82)
565
#define FOC1B 6
566
#define FOC1A 7
567
568
/* Reserved [0x83] */
569
570
/* Combine TCNT1L and TCNT1H */
571
#define TCNT1 _SFR_MEM16(0x84)
572
573
#define TCNT1L _SFR_MEM8(0x84)
574
#define TCNT1H _SFR_MEM8(0x85)
575
576
/* Combine ICR1L and ICR1H */
577
#define ICR1 _SFR_MEM16(0x86)
578
579
#define ICR1L _SFR_MEM8(0x86)
580
#define ICR1H _SFR_MEM8(0x87)
581
582
/* Combine OCR1AL and OCR1AH */
583
#define OCR1A _SFR_MEM16(0x88)
584
585
#define OCR1AL _SFR_MEM8(0x88)
586
#define OCR1AH _SFR_MEM8(0x89)
587
588
/* Combine OCR1BL and OCR1BH */
589
#define OCR1B _SFR_MEM16(0x8A)
590
591
#define OCR1BL _SFR_MEM8(0x8A)
592
#define OCR1BH _SFR_MEM8(0x8B)
593
594
/* Reserved [0x8C..0xAF] */
595
596
#define TCCR2A _SFR_MEM8(0xB0)
597
#define CS20 0
598
#define CS21 1
599
#define CS22 2
600
#define WGM21 3
601
#define COM2A0 4
602
#define COM2A1 5
603
#define WGM20 6
604
#define FOC2A 7
605
606
/* Reserved [0xB1] */
607
608
#define TCNT2 _SFR_MEM8(0xB2)
609
610
#define OCR2A _SFR_MEM8(0xB3)
611
612
/* Reserved [0xB4..0xB5] */
613
614
#define ASSR _SFR_MEM8(0xB6)
615
#define TCR2UB 0
616
#define OCR2UB 1
617
#define TCN2UB 2
618
#define AS2 3
619
#define EXCLK 4
620
621
/* Reserved [0xB7] */
622
623
#define USICR _SFR_MEM8(0xB8)
624
#define USITC 0
625
#define USICLK 1
626
#define USICS0 2
627
#define USICS1 3
628
#define USIWM0 4
629
#define USIWM1 5
630
#define USIOIE 6
631
#define USISIE 7
632
633
#define USISR _SFR_MEM8(0xB9)
634
#define USICNT0 0
635
#define USICNT1 1
636
#define USICNT2 2
637
#define USICNT3 3
638
#define USIDC 4
639
#define USIPF 5
640
#define USIOIF 6
641
#define USISIF 7
642
643
#define USIDR _SFR_MEM8(0xBA)
644
645
/* Reserved [0xBB..0xBF] */
646
647
#define UCSRA _SFR_MEM8(0xC0)
648
#define MPCM 0
649
#define U2X 1
650
#define UPE 2
651
#define DOR 3
652
#define FE 4
653
#define UDRE 5
654
#define TXC 6
655
#define RXC 7
656
657
#define UCSRB _SFR_MEM8(0XC1)
658
#define TXB8 0
659
#define RXB8 1
660
#define UCSZ2 2
661
#define TXEN 3
662
#define RXEN 4
663
#define UDRIE 5
664
#define TXCIE 6
665
#define RXCIE 7
666
667
#define UCSRC _SFR_MEM8(0xC2)
668
#define UCPOL 0
669
#define UCSZ0 1
670
#define UCSZ1 2
671
#define USBS 3
672
#define UPM0 4
673
#define UPM1 5
674
#define UMSEL 6
675
676
/* Reserved [0xC3] */
677
678
/* Combine UBRRL and UBRRH */
679
#define UBRR _SFR_MEM16(0xC4)
680
681
#define UBRRL _SFR_MEM8(0xC4)
682
#define UBRRH _SFR_MEM8(0xC5)
683
684
#define UDR _SFR_MEM8(0XC6)
685
686
/* Reserved [0xC7..0xFF] */
687
688
689
/* Interrupt vectors */
690
/* Vector 0 is the reset vector */
691
/* External Interrupt Request 0 */
692
#define INT0_vect _VECTOR(1)
693
#define SIG_INTERRUPT0 _VECTOR(1)
694
695
/* Pin Change Interrupt Request 0 */
696
#define PCINT0_vect _VECTOR(2)
697
#define SIG_PIN_CHANGE0 _VECTOR(2)
698
699
/* Pin Change Interrupt Request 1 */
700
#define PCINT1_vect _VECTOR(3)
701
#define SIG_PIN_CHANGE1 _VECTOR(3)
702
703
/* Timer/Counter2 Compare Match */
704
#define TIMER2_COMP_vect _VECTOR(4)
705
#define SIG_OUTPUT_COMPARE2 _VECTOR(4)
706
707
/* Timer/Counter2 Overflow */
708
#define TIMER2_OVF_vect _VECTOR(5)
709
#define SIG_OVERFLOW2 _VECTOR(5)
710
711
/* Timer/Counter1 Capture Event */
712
#define TIMER1_CAPT_vect _VECTOR(6)
713
#define SIG_INPUT_CAPTURE1 _VECTOR(6)
714
715
/* Timer/Counter1 Compare Match A */
716
#define TIMER1_COMPA_vect _VECTOR(7)
717
#define SIG_OUTPUT_COMPARE1A _VECTOR(7)
718
719
/* Timer/Counter Compare Match B */
720
#define TIMER1_COMPB_vect _VECTOR(8)
721
#define SIG_OUTPUT_COMPARE1B _VECTOR(8)
722
723
/* Timer/Counter1 Overflow */
724
#define TIMER1_OVF_vect _VECTOR(9)
725
#define SIG_OVERFLOW1 _VECTOR(9)
726
727
/* Timer/Counter0 Compare Match */
728
#define TIMER0_COMP_vect _VECTOR(10)
729
#define SIG_OUTPUT_COMPARE0 _VECTOR(10)
730
731
/* Timer/Counter0 Overflow */
732
#define TIMER0_OVF_vect _VECTOR(11)
733
#define SIG_OVERFLOW0 _VECTOR(11)
734
735
/* SPI Serial Transfer Complete */
736
#define SPI_STC_vect _VECTOR(12)
737
#define SIG_SPI _VECTOR(12)
738
739
/* USART0, Rx Complete */
740
#define USART0_RX_vect _VECTOR(13)
741
#define USART_RX_vect _VECTOR(13)
/* Alias */
742
#define SIG_UART_RECV _VECTOR(13)
743
744
/* USART0 Data register Empty */
745
#define USART0_UDRE_vect _VECTOR(14)
746
#define USART_UDRE_vect _VECTOR(14)
/* Alias */
747
#define SIG_UART_DATA _VECTOR(14)
748
749
/* USART0, Tx Complete */
750
#define USART0_TX_vect _VECTOR(15)
751
#define USART_TX_vect _VECTOR(15)
/* Alias */
752
#define SIG_UART_TRANS _VECTOR(15)
753
754
/* USI Start Condition */
755
#define USI_START_vect _VECTOR(16)
756
#define SIG_USI_START _VECTOR(16)
757
758
/* USI Overflow */
759
#define USI_OVERFLOW_vect _VECTOR(17)
760
#define SIG_USI_OVERFLOW _VECTOR(17)
761
762
/* Analog Comparator */
763
#define ANALOG_COMP_vect _VECTOR(18)
764
#define SIG_COMPARATOR _VECTOR(18)
765
766
/* ADC Conversion Complete */
767
#define ADC_vect _VECTOR(19)
768
#define SIG_ADC _VECTOR(19)
769
770
/* EEPROM Ready */
771
#define EE_READY_vect _VECTOR(20)
772
#define SIG_EEPROM_READY _VECTOR(20)
773
774
/* Store Program Memory Read */
775
#define SPM_READY_vect _VECTOR(21)
776
#define SIG_SPM_READY _VECTOR(21)
777
778
#define _VECTORS_SIZE 88
779
780
781
/* Constants */
782
#define SPM_PAGESIZE 128
783
#define RAMEND 0x4FF
784
#define XRAMEND RAMEND
785
#define E2END 0x1FF
786
#define E2PAGESIZE 4
787
#define FLASHEND 0x3FFF
788
789
790
/* Fuses */
791
792
#define FUSE_MEMORY_SIZE 3
793
794
/* Low Fuse Byte */
795
#define FUSE_CKSEL0 (unsigned char)~_BV(0)
796
#define FUSE_CKSEL1 (unsigned char)~_BV(1)
797
#define FUSE_CKSEL2 (unsigned char)~_BV(2)
798
#define FUSE_CKSEL3 (unsigned char)~_BV(3)
799
#define FUSE_SUT0 (unsigned char)~_BV(4)
800
#define FUSE_SUT1 (unsigned char)~_BV(5)
801
#define FUSE_CKOUT (unsigned char)~_BV(6)
802
#define FUSE_CKDIV8 (unsigned char)~_BV(7)
803
#define LFUSE_DEFAULT (FUSE_CKSEL0 & FUSE_CKSEL2 & FUSE_CKSEL3 & FUSE_SUT0 & FUSE_CKDIV8)
804
805
/* High Fuse Byte */
806
#define FUSE_BOOTRST (unsigned char)~_BV(0)
807
#define FUSE_BOOTSZ0 (unsigned char)~_BV(1)
808
#define FUSE_BOOTSZ1 (unsigned char)~_BV(2)
809
#define FUSE_EESAVE (unsigned char)~_BV(3)
810
#define FUSE_WDTON (unsigned char)~_BV(4)
811
#define FUSE_SPIEN (unsigned char)~_BV(5)
812
#define FUSE_JTAGEN (unsigned char)~_BV(6)
813
#define FUSE_OCDEN (unsigned char)~_BV(7)
814
#define HFUSE_DEFAULT (FUSE_BOOTSZ0 & FUSE_BOOTSZ1 & FUSE_SPIEN & FUSE_JTAGEN)
815
816
/* Extended Fuse Byte */
817
#define FUSE_BODLEVEL0 (unsigned char)~_BV(1)
818
#define FUSE_BODLEVEL1 (unsigned char)~_BV(2)
819
#define FUSE_BODLEVEL2 (unsigned char)~_BV(3)
820
#define EFUSE_DEFAULT (0xFF)
821
822
823
/* Lock Bits */
824
#define __LOCK_BITS_EXIST
825
#define __BOOT_LOCK_BITS_0_EXIST
826
#define __BOOT_LOCK_BITS_1_EXIST
827
828
829
/* Signature */
830
#define SIGNATURE_0 0x1E
831
#define SIGNATURE_1 0x94
832
#define SIGNATURE_2 0x07
833
836
#endif
/* _AVR_IOM165_H_ */
