admin
rtems-admin.git
doxygen
builder
latest
rtems.git
score
cpu
avr
avr
iom163.h
1
9
10
* Copyright (c) 2007 Anatoly Sokolov
11
* All rights reserved.
12
13
14
* modification, are permitted provided that the following conditions are met:
15
16
* * Redistributions of source code must retain the above copyright
17
* notice, this list of conditions and the following disclaimer.
18
19
* * Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in
21
* the documentation and/or other materials provided with the
22
* distribution.
23
24
* * Neither the name of the copyright holders nor the names of
25
* contributors may be used to endorse or promote products derived
26
* from this software without specific prior written permission.
27
28
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
29
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
30
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
31
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
32
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
33
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
34
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
35
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
36
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
37
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
38
* POSSIBILITY OF SUCH DAMAGE.
39
40
41
#ifndef _AVR_IOM163_H_
42
#define _AVR_IOM163_H_ 1
43
51
#ifndef _AVR_IO_H_
52
# error "Include <avr/io.h> instead of this file."
53
#endif
54
55
#ifndef _AVR_IOXXX_H_
56
# define _AVR_IOXXX_H_ "iom163.h"
57
#else
58
# error "Attempt to include more than one <avr/ioXXX.h> file."
59
#endif
60
61
/* I/O registers */
62
63
#define TWBR _SFR_IO8(0x00)
64
#define TWSR _SFR_IO8(0x01)
65
#define TWAR _SFR_IO8(0x02)
66
#define TWDR _SFR_IO8(0x03)
67
68
/* ADC */
69
#ifndef __ASSEMBLER__
70
#define ADC _SFR_IO16(0x04)
71
#endif
72
#define ADCW _SFR_IO16(0x04)
73
#define ADCL _SFR_IO8(0x04)
74
#define ADCH _SFR_IO8(0x05)
75
#define ADCSR _SFR_IO8(0x06)
76
#define ADMUX _SFR_IO8(0x07)
77
78
/* analog comparator */
79
#define ACSR _SFR_IO8(0x08)
80
81
/* UART */
82
#define UBRR _SFR_IO8(0x09)
83
#define UCSRB _SFR_IO8(0x0A)
84
#define UCSRA _SFR_IO8(0x0B)
85
#define UDR _SFR_IO8(0x0C)
86
87
/* SPI */
88
#define SPCR _SFR_IO8(0x0D)
89
#define SPSR _SFR_IO8(0x0E)
90
#define SPDR _SFR_IO8(0x0F)
91
92
/* Port D */
93
#define PIND _SFR_IO8(0x10)
94
#define DDRD _SFR_IO8(0x11)
95
#define PORTD _SFR_IO8(0x12)
96
97
/* Port C */
98
#define PINC _SFR_IO8(0x13)
99
#define DDRC _SFR_IO8(0x14)
100
#define PORTC _SFR_IO8(0x15)
101
102
/* Port B */
103
#define PINB _SFR_IO8(0x16)
104
#define DDRB _SFR_IO8(0x17)
105
#define PORTB _SFR_IO8(0x18)
106
107
/* Port A */
108
#define PINA _SFR_IO8(0x19)
109
#define DDRA _SFR_IO8(0x1A)
110
#define PORTA _SFR_IO8(0x1B)
111
112
/* EEPROM Control Register */
113
#define EECR _SFR_IO8(0x1C)
114
115
/* EEPROM Data Register */
116
#define EEDR _SFR_IO8(0x1D)
117
118
/* EEPROM Address Register */
119
#define EEAR _SFR_IO16(0x1E)
120
#define EEARL _SFR_IO8(0x1E)
121
#define EEARH _SFR_IO8(0x1F)
122
123
#define UBRRHI _SFR_IO8(0x20)
124
125
#define WDTCR _SFR_IO8(0x21)
126
127
#define ASSR _SFR_IO8(0x22)
128
129
/* Timer 2 */
130
#define OCR2 _SFR_IO8(0x23)
131
#define TCNT2 _SFR_IO8(0x24)
132
#define TCCR2 _SFR_IO8(0x25)
133
134
/* Timer 1 */
135
#define ICR1 _SFR_IO16(0x26)
136
#define ICR1L _SFR_IO8(0x26)
137
#define ICR1H _SFR_IO8(0x27)
138
#define OCR1B _SFR_IO16(0x28)
139
#define OCR1BL _SFR_IO8(0x28)
140
#define OCR1BH _SFR_IO8(0x29)
141
#define OCR1A _SFR_IO16(0x2A)
142
#define OCR1AL _SFR_IO8(0x2A)
143
#define OCR1AH _SFR_IO8(0x2B)
144
#define TCNT1 _SFR_IO16(0x2C)
145
#define TCNT1L _SFR_IO8(0x2C)
146
#define TCNT1H _SFR_IO8(0x2D)
147
#define TCCR1B _SFR_IO8(0x2E)
148
#define TCCR1A _SFR_IO8(0x2F)
149
150
#define SFIOR _SFR_IO8(0x30)
151
152
#define OSCCAL _SFR_IO8(0x31)
153
154
/* Timer 0 */
155
#define TCNT0 _SFR_IO8(0x32)
156
#define TCCR0 _SFR_IO8(0x33)
157
158
#define MCUSR _SFR_IO8(0x34)
159
#define MCUCR _SFR_IO8(0x35)
160
161
#define TWCR _SFR_IO8(0x36)
162
163
#define SPMCR _SFR_IO8(0x37)
164
165
#define TIFR _SFR_IO8(0x38)
166
#define TIMSK _SFR_IO8(0x39)
167
168
#define GIFR _SFR_IO8(0x3A)
169
#define GIMSK _SFR_IO8(0x3B)
170
171
/* 0x3C reserved */
172
173
/* 0x3D..0x3E SP */
174
175
/* 0x3F SREG */
176
177
/* Interrupt vectors */
178
179
/* External Interrupt 0 */
180
#define INT0_vect _VECTOR(1)
181
#define SIG_INTERRUPT0 _VECTOR(1)
182
183
/* External Interrupt 1 */
184
#define INT1_vect _VECTOR(2)
185
#define SIG_INTERRUPT1 _VECTOR(2)
186
187
/* Timer/Counter2 Compare Match */
188
#define TIMER2_COMP_vect _VECTOR(3)
189
#define SIG_OUTPUT_COMPARE2 _VECTOR(3)
190
191
/* Timer/Counter2 Overflow */
192
#define TIMER2_OVF_vect _VECTOR(4)
193
#define SIG_OVERFLOW2 _VECTOR(4)
194
195
/* Timer/Counter1 Capture Event */
196
#define TIMER1_CAPT_vect _VECTOR(5)
197
#define SIG_INPUT_CAPTURE1 _VECTOR(5)
198
199
/* Timer/Counter1 Compare Match A */
200
#define TIMER1_COMPA_vect _VECTOR(6)
201
#define SIG_OUTPUT_COMPARE1A _VECTOR(6)
202
203
/* Timer/Counter1 Compare Match B */
204
#define TIMER1_COMPB_vect _VECTOR(7)
205
#define SIG_OUTPUT_COMPARE1B _VECTOR(7)
206
207
/* Timer/Counter1 Overflow */
208
#define TIMER1_OVF_vect _VECTOR(8)
209
#define SIG_OVERFLOW1 _VECTOR(8)
210
211
/* Timer/Counter0 Overflow */
212
#define TIMER0_OVF_vect _VECTOR(9)
213
#define SIG_OVERFLOW0 _VECTOR(9)
214
215
/* SPI Serial Transfer Complete */
216
#define SPI_STC_vect _VECTOR(10)
217
#define SIG_SPI _VECTOR(10)
218
219
/* UART, RX Complete */
220
#define UART_RX_vect _VECTOR(11)
221
#define SIG_UART_RECV _VECTOR(11)
222
223
/* UART Data Register Empty */
224
#define UART_UDRE_vect _VECTOR(12)
225
#define SIG_UART_DATA _VECTOR(12)
226
227
/* UART, TX Complete */
228
#define UART_TX_vect _VECTOR(13)
229
#define SIG_UART_TRANS _VECTOR(13)
230
231
/* ADC Conversion Complete */
232
#define ADC_vect _VECTOR(14)
233
#define SIG_ADC _VECTOR(14)
234
235
/* EEPROM Ready */
236
#define EE_RDY_vect _VECTOR(15)
237
#define SIG_EEPROM_READY _VECTOR(15)
238
239
/* Analog Comparator */
240
#define ANA_COMP_vect _VECTOR(16)
241
#define SIG_COMPARATOR _VECTOR(16)
242
243
/* 2-Wire Serial Interface */
244
#define TWI_vect _VECTOR(17)
245
#define SIG_2WIRE_SERIAL _VECTOR(17)
246
247
#define _VECTORS_SIZE 72
248
249
/* Bit numbers */
250
251
/* GIMSK */
252
#define INT1 7
253
#define INT0 6
254
/* bit 5 reserved, undefined */
255
/* bits 4-0 reserved */
256
257
/* GIFR */
258
#define INTF1 7
259
#define INTF0 6
260
/* bits 5-0 reserved */
261
262
/* TIMSK */
263
#define OCIE2 7
264
#define TOIE2 6
265
#define TICIE1 5
266
#define OCIE1A 4
267
#define OCIE1B 3
268
#define TOIE1 2
269
/* bit 1 reserved */
270
#define TOIE0 0
271
272
/* TIFR */
273
#define OCF2 7
274
#define TOV2 6
275
#define ICF1 5
276
#define OCF1A 4
277
#define OCF1B 3
278
#define TOV1 2
279
/* bit 1 reserved, undefined */
280
#define TOV0 0
281
282
/* SPMCR */
283
/* bit 7 reserved */
284
#define ASB 6
285
/* bit 5 reserved */
286
#define ASRE 4
287
#define BLBSET 3
288
#define PGWRT 2
289
#define PGERS 1
290
#define SPMEN 0
291
292
/* TWCR */
293
#define TWINT 7
294
#define TWEA 6
295
#define TWSTA 5
296
#define TWSTO 4
297
#define TWWC 3
298
#define TWEN 2
299
300
#define TWIE 0
301
302
/* TWAR */
303
#define TWGCE 0
304
305
/* TWSR */
306
#define TWS7 7
307
#define TWS6 6
308
#define TWS5 5
309
#define TWS4 4
310
#define TWS3 3
311
/* bits 2-0 reserved */
312
313
/* MCUCR */
314
315
#define SE 6
316
#define SM1 5
317
#define SM0 4
318
#define ISC11 3
319
#define ISC10 2
320
#define ISC01 1
321
#define ISC00 0
322
323
/* MCUSR */
324
/* bits 7-4 reserved */
325
#define WDRF 3
326
#define BORF 2
327
#define EXTRF 1
328
#define PORF 0
329
330
/* SFIOR */
331
332
#define ACME 3
333
#define PUD 2
334
#define PSR2 1
335
#define PSR10 0
336
337
/* TCCR0 */
338
/* bits 7-3 reserved */
339
#define CS02 2
340
#define CS01 1
341
#define CS00 0
342
343
/* TCCR2 */
344
#define FOC2 7
345
#define PWM2 6
346
#define COM21 5
347
#define COM20 4
348
#define CTC2 3
349
#define CS22 2
350
#define CS21 1
351
#define CS20 0
352
353
/* ASSR */
354
355
#define AS2 3
356
#define TCN2UB 2
357
#define OCR2UB 1
358
#define TCR2UB 0
359
360
/* TCCR1A */
361
#define COM1A1 7
362
#define COM1A0 6
363
#define COM1B1 5
364
#define COM1B0 4
365
#define FOC1A 3
366
#define FOC1B 2
367
#define PWM11 1
368
#define PWM10 0
369
370
/* TCCR1B */
371
#define ICNC1 7
372
#define ICES1 6
373
/* bits 5-4 reserved */
374
#define CTC1 3
375
#define CS12 2
376
#define CS11 1
377
#define CS10 0
378
379
/* WDTCR */
380
/* bits 7-5 reserved */
381
#define WDTOE 4
382
#define WDE 3
383
#define WDP2 2
384
#define WDP1 1
385
#define WDP0 0
386
387
/* PA7-PA0 = ADC7-ADC0 */
388
/* PORTA */
389
#define PA7 7
390
#define PA6 6
391
#define PA5 5
392
#define PA4 4
393
#define PA3 3
394
#define PA2 2
395
#define PA1 1
396
#define PA0 0
397
398
/* DDRA */
399
#define DDA7 7
400
#define DDA6 6
401
#define DDA5 5
402
#define DDA4 4
403
#define DDA3 3
404
#define DDA2 2
405
#define DDA1 1
406
#define DDA0 0
407
408
/* PINA */
409
#define PINA7 7
410
#define PINA6 6
411
#define PINA5 5
412
#define PINA4 4
413
#define PINA3 3
414
#define PINA2 2
415
#define PINA1 1
416
#define PINA0 0
417
418
419
PB7 = SCK
420
PB6 = MISO
421
PB5 = MOSI
422
PB4 = SS#
423
PB3 = AIN1
424
PB2 = AIN0
425
PB1 = T1
426
PB0 = T0
427
428
429
/* PORTB */
430
#define PB7 7
431
#define PB6 6
432
#define PB5 5
433
#define PB4 4
434
#define PB3 3
435
#define PB2 2
436
#define PB1 1
437
#define PB0 0
438
439
/* DDRB */
440
#define DDB7 7
441
#define DDB6 6
442
#define DDB5 5
443
#define DDB4 4
444
#define DDB3 3
445
#define DDB2 2
446
#define DDB1 1
447
#define DDB0 0
448
449
/* PINB */
450
#define PINB7 7
451
#define PINB6 6
452
#define PINB5 5
453
#define PINB4 4
454
#define PINB3 3
455
#define PINB2 2
456
#define PINB1 1
457
#define PINB0 0
458
459
460
PC7 = TOSC2
461
PC6 = TOSC1
462
PC1 = SDA
463
PC0 = SCL
464
465
/* PORTC */
466
#define PC7 7
467
#define PC6 6
468
#define PC5 5
469
#define PC4 4
470
#define PC3 3
471
#define PC2 2
472
#define PC1 1
473
#define PC0 0
474
475
/* DDRC */
476
#define DDC7 7
477
#define DDC6 6
478
#define DDC5 5
479
#define DDC4 4
480
#define DDC3 3
481
#define DDC2 2
482
#define DDC1 1
483
#define DDC0 0
484
485
/* PINC */
486
#define PINC7 7
487
#define PINC6 6
488
#define PINC5 5
489
#define PINC4 4
490
#define PINC3 3
491
#define PINC2 2
492
#define PINC1 1
493
#define PINC0 0
494
495
496
PD7 = OC2
497
PD6 = ICP
498
PD5 = OC1A
499
PD4 = OC1B
500
PD3 = INT1
501
PD2 = INT0
502
PD1 = TXD
503
PD0 = RXD
504
505
506
/* PORTD */
507
#define PD7 7
508
#define PD6 6
509
#define PD5 5
510
#define PD4 4
511
#define PD3 3
512
#define PD2 2
513
#define PD1 1
514
#define PD0 0
515
516
/* DDRD */
517
#define DDD7 7
518
#define DDD6 6
519
#define DDD5 5
520
#define DDD4 4
521
#define DDD3 3
522
#define DDD2 2
523
#define DDD1 1
524
#define DDD0 0
525
526
/* PIND */
527
#define PIND7 7
528
#define PIND6 6
529
#define PIND5 5
530
#define PIND4 4
531
#define PIND3 3
532
#define PIND2 2
533
#define PIND1 1
534
#define PIND0 0
535
536
/* SPSR */
537
#define SPIF 7
538
#define WCOL 6
539
/* bits 5-1 reserved */
540
#define SPI2X 0
541
542
/* SPCR */
543
#define SPIE 7
544
#define SPE 6
545
#define DORD 5
546
#define MSTR 4
547
#define CPOL 3
548
#define CPHA 2
549
#define SPR1 1
550
#define SPR0 0
551
552
/* UCSRA */
553
#define RXC 7
554
#define TXC 6
555
#define UDRE 5
556
#define FE 4
557
#define DOR 3
558
/* bit 2 reserved */
559
#define U2X 1
560
#define MPCM 0
561
562
/* UCSRB */
563
#define RXCIE 7
564
#define TXCIE 6
565
#define UDRIE 5
566
#define RXEN 4
567
#define TXEN 3
568
#define CHR9 2
569
#define RXB8 1
570
#define TXB8 0
571
572
/* ACSR */
573
#define ACD 7
574
#define AINBG 6
575
#define ACO 5
576
#define ACI 4
577
#define ACIE 3
578
#define ACIC 2
579
#define ACIS1 1
580
#define ACIS0 0
581
582
/* ADCSR */
583
#define ADEN 7
584
#define ADSC 6
585
#define ADFR 5
586
#define ADIF 4
587
#define ADIE 3
588
#define ADPS2 2
589
#define ADPS1 1
590
#define ADPS0 0
591
592
/* ADMUX */
593
#define REFS1 7
594
#define REFS0 6
595
#define ADLAR 5
596
#define MUX4 4
597
#define MUX3 3
598
#define MUX2 2
599
#define MUX1 1
600
#define MUX0 0
601
602
603
#define EERIE 3
604
#define EEMWE 2
605
#define EEWE 1
606
#define EERE 0
607
608
/* Constants */
609
#define SPM_PAGESIZE 128
610
#define RAMEND 0x45F
611
#define XRAMEND RAMEND
612
#define E2END 0x1FF
613
#define E2PAGESIZE 0
614
#define FLASHEND 0x3FFF
615
616
617
/* Fuses */
618
619
#define FUSE_MEMORY_SIZE 2
620
621
/* Low Fuse Byte */
622
#define FUSE_CKSEL0 (unsigned char)~_BV(0)
623
#define FUSE_CKSEL1 (unsigned char)~_BV(1)
624
#define FUSE_CKSEL2 (unsigned char)~_BV(2)
625
#define FUSE_CKSEL3 (unsigned char)~_BV(3)
626
#define FUSE_SPIEN (unsigned char)~_BV(5)
627
#define FUSE_BODEN (unsigned char)~_BV(6)
628
#define FUSE_BODLEVEL (unsigned char)~_BV(7)
629
#define LFUSE_DEFAULT (FUSE_CKSEL0 & FUSE_CKSEL2 & FUSE_CKSEL3 & FUSE_SPIEN)
630
631
/* High Fuse Byte */
632
#define FUSE_BOOTRST (unsigned char)~_BV(0)
633
#define FUSE_BOOTSZ0 (unsigned char)~_BV(1)
634
#define FUSE_BOOTSZ1 (unsigned char)~_BV(2)
635
#define HFUSE_DEFAULT (0xFF)
636
637
638
/* Lock Bits */
639
#define __LOCK_BITS_EXIST
640
#define __BOOT_LOCK_BITS_0_EXIST
641
#define __BOOT_LOCK_BITS_1_EXIST
642
643
644
/* Signature */
645
#define SIGNATURE_0 0x1E
646
#define SIGNATURE_1 0x94
647
#define SIGNATURE_2 0x02
648
649
651
#endif
/* _AVR_IOM163_H_ */
