admin
rtems-admin.git
doxygen
builder
latest
rtems.git
score
cpu
avr
avr
ioat94k.h
1
9
10
* Copyright (c) 2002 Marek Michalkiewicz
11
* All rights reserved.
12
13
14
* modification, are permitted provided that the following conditions are met:
15
16
* * Redistributions of source code must retain the above copyright
17
* notice, this list of conditions and the following disclaimer.
18
19
* * Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in
21
* the documentation and/or other materials provided with the
22
* distribution.
23
24
* * Neither the name of the copyright holders nor the names of
25
* contributors may be used to endorse or promote products derived
26
* from this software without specific prior written permission.
27
28
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
29
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
30
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
31
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
32
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
33
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
34
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
35
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
36
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
37
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
38
* POSSIBILITY OF SUCH DAMAGE.
39
40
41
#ifndef _AVR_IOAT94K_H_
42
#define _AVR_IOAT94K_H_ 1
43
44
#ifndef _AVR_IO_H_
45
# error "Include <avr/io.h> instead of this file."
46
#endif
47
48
#ifndef _AVR_IOXXX_H_
49
# define _AVR_IOXXX_H_ "ioat94k.h"
50
#else
51
# error "Attempt to include more than one <avr/ioXXX.h> file."
52
#endif
53
61
/* I/O registers */
62
63
/* UART1 Baud Rate Register */
64
#define UBRR1 _SFR_IO8(0x00)
65
66
/* UART1 Control and Status Registers */
67
#define UCSR1B _SFR_IO8(0x01)
68
#define UCSR1A _SFR_IO8(0x02)
69
70
/* UART1 I/O Data Register */
71
#define UDR1 _SFR_IO8(0x03)
72
73
/* 0x04 reserved */
74
75
/* Input Pins, Port E */
76
#define PINE _SFR_IO8(0x05)
77
78
/* Data Direction Register, Port E */
79
#define DDRE _SFR_IO8(0x06)
80
81
/* Data Register, Port E */
82
#define PORTE _SFR_IO8(0x07)
83
84
/* On Chip Debug Register (reserved) */
85
#define OCDR _SFR_IO8(0x08)
86
87
/* UART0 Baud Rate Register */
88
#define UBRR0 _SFR_IO8(0x09)
89
90
/* UART0 Control and Status Registers */
91
#define UCSR0B _SFR_IO8(0x0A)
92
#define UCSR0A _SFR_IO8(0x0B)
93
94
/* UART0 I/O Data Register */
95
#define UDR0 _SFR_IO8(0x0C)
96
97
/* 0x0D..0x0F reserved */
98
99
/* Input Pins, Port D */
100
#define PIND _SFR_IO8(0x10)
101
102
/* Data Direction Register, Port D */
103
#define DDRD _SFR_IO8(0x11)
104
105
/* Data Register, Port D */
106
#define PORTD _SFR_IO8(0x12)
107
108
/* FPGA I/O Select Control Register */
109
#define FISCR _SFR_IO8(0x13)
110
111
/* FPGA I/O Select Registers A, B, C, D */
112
#define FISUA _SFR_IO8(0x14)
113
#define FISUB _SFR_IO8(0x15)
114
#define FISUC _SFR_IO8(0x16)
115
#define FISUD _SFR_IO8(0x17)
116
117
/* FPGA Cache Logic(R) registers (top secret, under NDA) */
118
#define FPGAX _SFR_IO8(0x18)
119
#define FPGAY _SFR_IO8(0x19)
120
#define FPGAZ _SFR_IO8(0x1A)
121
#define FPGAD _SFR_IO8(0x1B)
122
123
/* TWI stands for "Two Wire Interface" or "TWI Was I2C(tm)" */
124
125
/* 2-wire Serial Bit Rate Register */
126
#define TWBR _SFR_IO8(0x1C)
127
128
/* 2-wire Serial Status Register */
129
#define TWSR _SFR_IO8(0x1D)
130
131
/* 2-wire Serial (Slave) Address Register */
132
#define TWAR _SFR_IO8(0x1E)
133
134
/* 2-wire Serial Data Register */
135
#define TWDR _SFR_IO8(0x1F)
136
137
/* UART Baud Register High */
138
#define UBRRH _SFR_IO8(0x20)
139
#define UBRRHI UBRRH
/* New name in datasheet (1138F-FPSLI-06/02) */
140
141
/* Watchdog Timer Control Register */
142
#define WDTCR _SFR_IO8(0x21)
143
144
/* Timer/Counter2 Output Compare Register */
145
#define OCR2 _SFR_IO8(0x22)
146
147
/* Timer/Counter2 (8-bit) */
148
#define TCNT2 _SFR_IO8(0x23)
149
150
/* Timer/Counter1 Input Capture Register */
151
#define ICR1 _SFR_IO16(0x24)
152
#define ICR1L _SFR_IO8(0x24)
153
#define ICR1H _SFR_IO8(0x25)
154
155
/* Asynchronous mode StatuS Register */
156
#define ASSR _SFR_IO8(0x26)
157
158
/* Timer/Counter2 Control Register */
159
#define TCCR2 _SFR_IO8(0x27)
160
161
/* Timer/Counter1 Output Compare RegisterB */
162
#define OCR1B _SFR_IO16(0x28)
163
#define OCR1BL _SFR_IO8(0x28)
164
#define OCR1BH _SFR_IO8(0x29)
165
166
/* Timer/Counter1 Output Compare RegisterA */
167
#define OCR1A _SFR_IO16(0x2A)
168
#define OCR1AL _SFR_IO8(0x2A)
169
#define OCR1AH _SFR_IO8(0x2B)
170
171
/* Timer/Counter1 */
172
#define TCNT1 _SFR_IO16(0x2C)
173
#define TCNT1L _SFR_IO8(0x2C)
174
#define TCNT1H _SFR_IO8(0x2D)
175
176
/* Timer/Counter1 Control Register B */
177
#define TCCR1B _SFR_IO8(0x2E)
178
179
/* Timer/Counter1 Control Register A */
180
#define TCCR1A _SFR_IO8(0x2F)
181
182
/* Special Function IO Register */
183
#define SFIOR _SFR_IO8(0x30)
184
185
/* Timer/Counter0 Output Compare Register */
186
#define OCR0 _SFR_IO8(0x31)
187
188
/* Timer/Counter0 (8-bit) */
189
#define TCNT0 _SFR_IO8(0x32)
190
191
/* Timer/Counter0 Control Register */
192
#define TCCR0 _SFR_IO8(0x33)
193
194
/* 0x34 reserved */
195
196
/* MCU Control/Status Register */
197
#define MCUR _SFR_IO8(0x35)
198
199
/* 2-wire Serial Control Register */
200
#define TWCR _SFR_IO8(0x36)
201
202
/* 0x37 reserved */
203
204
/* Timer/Counter Interrupt Flag Register */
205
#define TIFR _SFR_IO8(0x38)
206
207
/* Timer/Counter Interrupt MaSK Register */
208
#define TIMSK _SFR_IO8(0x39)
209
210
/* Software Control Register */
211
#define SFTCR _SFR_IO8(0x3A)
212
213
/* External Interrupt Mask/Flag Register */
214
#define EIMF _SFR_IO8(0x3B)
215
216
/* 0x3C reserved */
217
218
/* 0x3D..0x3E SP */
219
220
/* 0x3F SREG */
221
222
/* Interrupt vectors */
223
224
#define SIG_FPGA_INTERRUPT0 _VECTOR(1)
/* FPGA_INT0 */
225
#define SIG_INTERRUPT0 _VECTOR(2)
/* EXT_INT0 */
226
#define SIG_FPGA_INTERRUPT1 _VECTOR(3)
/* FPGA_INT1 */
227
#define SIG_INTERRUPT1 _VECTOR(4)
/* EXT_INT1 */
228
#define SIG_FPGA_INTERRUPT2 _VECTOR(5)
/* FPGA_INT2 */
229
#define SIG_INTERRUPT2 _VECTOR(6)
/* EXT_INT2 */
230
#define SIG_FPGA_INTERRUPT3 _VECTOR(7)
/* FPGA_INT3 */
231
#define SIG_INTERRUPT3 _VECTOR(8)
/* EXT_INT3 */
232
#define SIG_OUTPUT_COMPARE2 _VECTOR(9)
/* TIM2_COMP */
233
#define SIG_OVERFLOW2 _VECTOR(10)
/* TIM2_OVF */
234
#define SIG_INPUT_CAPTURE1 _VECTOR(11)
/* TIM1_CAPT */
235
#define SIG_OUTPUT_COMPARE1A _VECTOR(12)
/* TIM1_COMPA */
236
#define SIG_OUTPUT_COMPARE1B _VECTOR(13)
/* TIM1_COMPB */
237
#define SIG_OVERFLOW1 _VECTOR(14)
/* TIM1_OVF */
238
#define SIG_OUTPUT_COMPARE0 _VECTOR(15)
/* TIM0_COMP */
239
#define SIG_OVERFLOW0 _VECTOR(16)
/* TIM0_OVF */
240
#define SIG_FPGA_INTERRUPT4 _VECTOR(17)
/* FPGA_INT4 */
241
#define SIG_FPGA_INTERRUPT5 _VECTOR(18)
/* FPGA_INT5 */
242
#define SIG_FPGA_INTERRUPT6 _VECTOR(19)
/* FPGA_INT6 */
243
#define SIG_FPGA_INTERRUPT7 _VECTOR(20)
/* FPGA_INT7 */
244
#define SIG_UART0_RECV _VECTOR(21)
/* UART0_RXC */
245
#define SIG_UART0_DATA _VECTOR(22)
/* UART0_DRE */
246
#define SIG_UART0_TRANS _VECTOR(23)
/* UART0_TXC */
247
#define SIG_FPGA_INTERRUPT8 _VECTOR(24)
/* FPGA_INT8 */
248
#define SIG_FPGA_INTERRUPT9 _VECTOR(25)
/* FPGA_INT9 */
249
#define SIG_FPGA_INTERRUPT10 _VECTOR(26)
/* FPGA_INT10 */
250
#define SIG_FPGA_INTERRUPT11 _VECTOR(27)
/* FPGA_INT11 */
251
#define SIG_UART1_RECV _VECTOR(28)
/* UART1_RXC */
252
#define SIG_UART1_DATA _VECTOR(29)
/* UART1_DRE */
253
#define SIG_UART1_TRANS _VECTOR(30)
/* UART1_TXC */
254
#define SIG_FPGA_INTERRUPT12 _VECTOR(31)
/* FPGA_INT12 */
255
#define SIG_FPGA_INTERRUPT13 _VECTOR(32)
/* FPGA_INT13 */
256
#define SIG_FPGA_INTERRUPT14 _VECTOR(33)
/* FPGA_INT14 */
257
#define SIG_FPGA_INTERRUPT15 _VECTOR(34)
/* FPGA_INT15 */
258
#define SIG_2WIRE_SERIAL _VECTOR(35)
/* TWS_INT */
259
260
#define _VECTORS_SIZE 144
261
262
/* Bit numbers (SFRs alphabetically sorted) */
263
264
/* ASSR */
265
#define AS2 3
266
#define TCN2UB 2
267
#define OCR2UB 1
268
#define TCR2UB 0
269
270
/* DDRD */
271
#define DDD7 7
272
#define DDD6 6
273
#define DDD5 5
274
#define DDD4 4
275
#define DDD3 3
276
#define DDD2 2
277
#define DDD1 1
278
#define DDD0 0
279
280
/* DDRE */
281
#define DDE7 7
282
#define DDE6 6
283
#define DDE5 5
284
#define DDE4 4
285
#define DDE3 3
286
#define DDE2 2
287
#define DDE1 1
288
#define DDE0 0
289
290
/* EIMF */
291
#define INTF3 7
292
#define INTF2 6
293
#define INTF1 5
294
#define INTF0 4
295
#define INT3 3
296
#define INT2 2
297
#define INT1 1
298
#define INT0 0
299
300
/* FISCR */
301
#define FIADR 7
302
#define XFIS1 1
303
#define XFIS0 0
304
305
/* FISUA */
306
#define FIF3 7
307
#define FIF2 6
308
#define FIF1 5
309
#define FIF0 4
310
#define FINT3 3
311
#define FINT2 2
312
#define FINT1 1
313
#define FINT0 0
314
315
/* FISUB */
316
#define FIF7 7
317
#define FIF6 6
318
#define FIF5 5
319
#define FIF4 4
320
#define FINT7 3
321
#define FINT6 2
322
#define FINT5 1
323
#define FINT4 0
324
325
/* FISUC */
326
#define FIF11 7
327
#define FIF10 6
328
#define FIF9 5
329
#define FIF8 4
330
#define FINT11 3
331
#define FINT10 2
332
#define FINT9 1
333
#define FINT8 0
334
335
/* FISUD */
336
#define FIF15 7
337
#define FIF14 6
338
#define FIF13 5
339
#define FIF12 4
340
#define FINT15 3
341
#define FINT14 2
342
#define FINT13 1
343
#define FINT12 0
344
345
/* MCUR */
346
#define JTRF 7
347
#define JTD 6
348
#define SE 5
349
#define SM1 4
350
#define SM0 3
351
#define PORF 2
352
#define WDRF 1
353
#define EXTRF 0
354
355
/* OCDR (reserved) */
356
#define IDRD 7
357
358
/* PIND */
359
#define PIND7 7
360
#define PIND6 6
361
#define PIND5 5
362
#define PIND4 4
363
#define PIND3 3
364
#define PIND2 2
365
#define PIND1 1
366
#define PIND0 0
367
368
/* PINE */
369
#define PINE7 7
370
#define PINE6 6
371
#define PINE5 5
372
#define PINE4 4
373
#define PINE3 3
374
#define PINE2 2
375
#define PINE1 1
376
#define PINE0 0
377
378
/* PORTD */
379
#define PD7 7
380
#define PD6 6
381
#define PD5 5
382
#define PD4 4
383
#define PD3 3
384
#define PD2 2
385
#define PD1 1
386
#define PD0 0
387
388
/* PORTE */
389
390
PE7 = IC1 / INT3 (alternate)
391
PE6 = OC1A / INT2 (alternate)
392
PE5 = OC1B / INT1 (alternate)
393
PE4 = ET11 / INT0 (alternate)
394
PE3 = OC2 / RX1 (alternate)
395
PE2 = / TX1 (alternate)
396
PE1 = OC0 / RX0 (alternate)
397
PE0 = ET0 / TX0 (alternate)
398
399
#define PE7 7
400
#define PE6 6
401
#define PE5 5
402
#define PE4 4
403
#define PE3 3
404
#define PE2 2
405
#define PE1 1
406
#define PE0 0
407
408
/* SFIOR */
409
#define PSR2 1
410
#define PSR10 0
411
412
/* SFTCR */
413
#define FMXOR 3
414
#define WDTS 2
415
#define DBG 1
416
#define SRST 0
417
418
/* TCCR0 */
419
#define FOC0 7
420
#define PWM0 6
421
#define COM01 5
422
#define COM00 4
423
#define CTC0 3
424
#define CS02 2
425
#define CS01 1
426
#define CS00 0
427
428
/* TCCR1A */
429
#define COM1A1 7
430
#define COM1A0 6
431
#define COM1B1 5
432
#define COM1B0 4
433
#define FOC1A 3
434
#define FOC1B 2
435
#define PWM11 1
436
#define PWM10 0
437
438
/* TCCR1B */
439
#define ICNC1 7
440
#define ICES1 6
441
#define ICPE 5
442
#define CTC1 3
443
#define CS12 2
444
#define CS11 1
445
#define CS10 0
446
447
/* TCCR2 */
448
#define FOC2 7
449
#define PWM2 6
450
#define COM21 5
451
#define COM20 4
452
#define CTC2 3
453
#define CS22 2
454
#define CS21 1
455
#define CS20 0
456
457
/* TIFR */
458
#define TOV1 7
459
#define OCF1A 6
460
#define OCF1B 5
461
#define TOV2 4
462
#define ICF1 3
463
#define OCF2 2
464
#define TOV0 1
465
#define OCF0 0
466
467
/* TIMSK */
468
#define TOIE1 7
469
#define OCIE1A 6
470
#define OCIE1B 5
471
#define TOIE2 4
472
#define TICIE1 3
473
#define OCIE2 2
474
#define TOIE0 1
475
#define OCIE0 0
476
477
/* TWAR */
478
/* #define TWA 1 */
/* TWA is bits 7:1 */
479
#define TWGCE 0
480
481
/* TWCR */
482
#define TWINT 7
483
#define TWEA 6
484
#define TWSTA 5
485
#define TWSTO 4
486
#define TWWC 3
487
#define TWEN 2
488
#define TWIE 0
489
490
/* TWSR */
491
#define TWS7 7
492
#define TWS6 6
493
#define TWS5 5
494
#define TWS4 4
495
#define TWS3 3
496
497
/* UBRRHI
498
Bits 11..8 of UART1 are bits 7..4 of UBRRHI.
499
Bits 11..8 of UART0 are bits 3..0 of UBRRHI. */
500
/* #define UBRRHI1 4 */
501
/* #define UBRRHI0 0 */
502
503
/* UCSR0A */
504
#define RXC0 7
505
#define TXC0 6
506
#define UDRE0 5
507
#define FE0 4
508
#define OR0 3
509
#define U2X0 1
510
#define MPCM0 0
511
512
/* UCSR0B */
513
#define RXCIE0 7
514
#define TXCIE0 6
515
#define UDRIE0 5
516
#define RXEN0 4
517
#define TXEN0 3
518
#define CHR90 2
519
#define RXB80 1
520
#define TXB80 0
521
522
/* UCSR1A */
523
#define RXC1 7
524
#define TXC1 6
525
#define UDRE1 5
526
#define FE1 4
527
#define OR1 3
528
#define U2X1 1
529
#define MPCM1 0
530
531
/* UCSR1B */
532
#define RXCIE1 7
533
#define TXCIE1 6
534
#define UDRIE1 5
535
#define RXEN1 4
536
#define TXEN1 3
537
#define CHR91 2
538
#define RXB81 1
539
#define TXB81 0
540
541
/* WDTCR */
542
#define WDTOE 4
543
#define WDE 3
544
#define WDP2 2
545
#define WDP1 1
546
#define WDP0 0
547
548
549
Last memory addresses - depending on configuration, it is possible
550
to have 20K-32K of program memory and 4K-16K of data memory
551
(all in the same 36K total of SRAM, loaded from external EEPROM).
552
553
554
#ifndef RAMEND
555
#define RAMEND 0x0FFF
556
#endif
557
558
#ifndef XRAMEND
559
#define XRAMEND RAMEND
560
#endif
561
562
#define E2END 0
563
564
#ifndef FLASHEND
565
#define FLASHEND 0x7FFF
566
#endif
567
569
#endif
/* _AVR_IOAT94K_H_ */
