admin
rtems-admin.git
doxygen
builder
latest
rtems.git
score
cpu
avr
avr
io86r401.h
1
9
10
* Copyright (c) 2002, Colin O'Flynn
11
* All rights reserved.
12
13
14
* modification, are permitted provided that the following conditions are met:
15
16
* * Redistributions of source code must retain the above copyright
17
* notice, this list of conditions and the following disclaimer.
18
19
* * Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in
21
* the documentation and/or other materials provided with the
22
* distribution.
23
24
* * Neither the name of the copyright holders nor the names of
25
* contributors may be used to endorse or promote products derived
26
* from this software without specific prior written permission.
27
28
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
29
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
30
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
31
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
32
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
33
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
34
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
35
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
36
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
37
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
38
* POSSIBILITY OF SUCH DAMAGE.
39
40
41
#ifndef _AVR_IO86RF401_H_
42
#define _AVR_IO86RF401_H_ 1
43
51
#ifndef _AVR_IO_H_
52
# error "Include <avr/io.h> instead of this file."
53
#endif
54
55
#ifndef _AVR_IOXXX_H_
56
# define _AVR_IOXXX_H_ "io86r401.h"
57
#else
58
# error "Attempt to include more than one <avr/ioXXX.h> file."
59
#endif
60
61
avr/sfr_defs.h
62
63
/* Status REGister */
64
#define SREG _SFR_IO8(0x3F)
65
66
/* Stack Pointer */
67
#define SP _SFR_IO16(0x3D)
68
#define SPH _SFR_IO8(0x3E)
69
#define SPL _SFR_IO8(0x3D)
70
71
/*Battery low configeration register */
72
#define BL_CONFIG _SFR_IO8(0x35)
73
74
/*Button detect register*/
75
#define B_DET _SFR_IO8(0x34)
76
77
/*AVR Configeration register*/
78
#define AVR_CONFIG _SFR_IO8(0x33)
79
80
/* I/O registers */
81
82
/*Data in register */
83
#define IO_DATIN _SFR_IO8(0x32)
84
85
/*Data out register */
86
#define IO_DATOUT _SFR_IO8(0x31)
87
88
/*IO Enable register */
89
#define IO_ENAB _SFR_IO8(0x30)
90
91
/* Watchdog Timer Control Register */
92
#define WDTCR _SFR_IO8(0x22)
93
94
/* Bit Timer Control Register */
95
#define BTCR _SFR_IO8(0x21)
96
97
#define BTCNT _SFR_IO8(0x20)
98
99
100
NOTE: EEPROM name's changed to have D in front on them, per datasheet, but
101
you may want to remove the leading D.
102
103
/* EEPROM Control Register */
104
105
/* EEPROM Address Register */
106
#define DEEAR _SFR_IO8(0x1E)
107
#define DEEARL _SFR_IO8(0x1E)
108
109
/* EEPROM Data Register */
110
#define DEEDR _SFR_IO8(0x1D)
111
112
#define DEECR _SFR_IO8(0x1C)
113
114
/* Lock Detector Configuration Register 2 */
115
#define LOCKDET2 _SFR_IO8(0x17)
116
117
/* VCO Tuning Register*/
118
#define VCOTUNE _SFR_IO8(0x16)
119
120
/* Power Attenuation Control Register */
121
#define PWR_ATTEN _SFR_IO8(0x14)
122
123
/* Transmitter Control Register */
124
#define TX_CNTL _SFR_IO8(0x12)
125
126
/* Lock Detector Configuration Register 1 */
127
#define LOCKDET1 _SFR_IO8(0x10)
128
129
130
/* Interrupt vectors */
131
132
/* Transmission Done, Bit Timer Flag 2 Interrupt */
133
#define TXDONE_vect _VECTOR(1)
134
#define SIG_TXDONE _VECTOR(1)
135
136
/* Transmit Buffer Empty, Bit Itmer Flag 0 Interrupt */
137
#define TXEMPTY_vect _VECTOR(2)
138
#define SIG_TXBE _VECTOR(2)
139
140
#define _VECTORS_SIZE 12
141
142
143
* The Register Bit names are represented by their bit number (0-7).
144
145
146
/* Lock Detector Configuration Register 1 - LOCKDET1 */
147
#define UPOK 4
148
#define ENKO 3
149
#define BOD 2
150
#define CS1 1
151
#define CS0 0
152
153
/* Transmit Control Register - TX_CNTL */
154
#define TXE 5
155
#define TXK 4
156
#define LOC 2
157
158
/* Power Attenuation Control Register - PWR_ATTEN */
159
#define PCC2 5
160
#define PCC1 4
161
#define PCC0 3
162
#define PCF2 2
163
#define PCF1 1
164
#define PCF0 0
165
166
/* VCO Tuning Register 6 - VCOTUNE --NOTE: [] removed from names*/
167
#define VCOVDET1 7
168
#define VCOVDET0 6
169
#define VCOTUNE4 4
170
#define VCOTUNE3 3
171
#define VCOTUNE2 2
172
#define VCOTUNE1 1
173
#define VCOTUNE0 0
174
175
/* Lock Detector Configuration Register 2 - LOCKDET2 --NOTE: [] removed from names*/
176
#define EUD 7
177
#define LAT 6
178
#define ULC2 5
179
#define ULC1 4
180
#define ULC0 3
181
#define LC2 2
182
#define LC1 1
183
#define LC0 0
184
185
/* Data EEPROM Control Register - DEECR */
186
#define BSY 3
187
#define EEU 2
188
#define EEL 1
189
#define EER 0
190
191
/* Data EEPROM Data Register - DEEDR */
192
#define ED7 7
193
#define ED6 6
194
#define ED5 5
195
#define ED4 4
196
#define ED3 3
197
#define ED2 2
198
#define ED1 1
199
#define ED0 0
200
201
/* Data EEPROM Address Register - DEEAR */
202
#define PA6 6
203
#define PA5 5
204
#define PA4 4
205
#define PA3 3
206
#define BA2 2
/* B is not a typo! */
207
#define BA1 1
208
#define BA0 0
209
210
/* Bit Timer Count Register - BTCNT */
211
#define C7 7
212
#define C6 6
213
#define C5 5
214
#define C4 4
215
#define C3 3
216
#define C2 2
217
#define C1 1
218
#define C0 0
219
220
/* Bit Timer Control Register - BTCR */
221
#define C9 7
222
#define C8 6
223
#define M1 5
224
#define M0 4
225
#define IE 3
226
#define F2 2
227
#define DATA 1
228
#define F0 0
229
230
/* Watchdog Timer Control Register - WDTCR */
231
#define WDTOE 4
232
#define WDE 3
233
#define WDP2 2
234
#define WDP1 1
235
#define WDP0 0
236
237
/* I/O Enable Register - IO_ENAB */
238
#define BOHYST 6
239
#define IOE5 5
240
#define IOE4 4
241
#define IOE3 3
242
#define IOE2 2
243
#define IOE1 1
244
#define IOE0 0
245
246
/* Note: No PORTB or whatever, this is the equivalent. */
247
/* I/O Data Out Register - IO_DATOUT */
248
#define IOO5 5
249
#define IOO4 4
250
#define IOO3 3
251
#define IOO2 2
252
#define IOO1 1
253
#define IOO0 0
254
255
/* Note: No PINB or whatever, this is the equivalent. */
256
/* I/O Data In Register - IO_DATIN */
257
#define IOI5 5
258
#define IOI4 4
259
#define IOI3 3
260
#define IOI2 2
261
#define IOI1 1
262
#define IOI0 0
263
264
/* AVR Configuration Register - AVR_CONFIG */
265
#define ACS1 6
266
#define ACS0 5
267
#define TM 4
268
#define BD 3
269
#define BLI 2
270
#define SLEEP 1
271
#define BBM 0
272
273
/* Button Detect Register - B_DET */
274
#define BD5 5
275
#define BD4 4
276
#define BD3 3
277
#define BD2 2
278
#define BD1 1
279
#define BD0 0
280
281
/* Battery Low Configuration Register - BL_CONFIG */
282
#define BL 7
283
#define BLV 6
284
#define BL5 5
285
#define BL4 4
286
#define BL3 3
287
#define BL2 2
288
#define BL1 1
289
#define BL0 0
290
291
/* Pointer definition */
292
#define XL r26
293
#define XH r27
294
#define YL r28
295
#define YH r29
296
#define ZL r30
297
#define ZH r31
298
299
/* Constants */
300
#define RAMEND 0xDF
301
#define XRAMEND RAMEND
302
#define E2END 0x7F
303
#define E2PAGESIZE 0
304
#define FLASHEND 0x07FF
305
306
307
/* Fuses */
308
#define FUSE_MEMORY_SIZE 0
309
310
311
/* Lock Bits */
312
#define __LOCK_BITS_EXIST
313
314
315
/* Signature */
316
#define SIGNATURE_0 0x1E
317
#define SIGNATURE_1 0x91
318
#define SIGNATURE_2 0x81
319
321
#endif
/* _AVR_IO86RF401_H_ */
sfr_defs.h
Macros for Accessing AVR Special Function Registers.
