admin
rtems-admin.git
doxygen
builder
latest
rtems.git
score
cpu
avr
avr
io2313.h
1
/* Copyright (c) 2002, Marek Michalkiewicz
2
All rights reserved.
3
4
Redistribution and use in source and binary forms, with or without
5
modification, are permitted provided that the following conditions are met:
6
7
* Redistributions of source code must retain the above copyright
8
notice, this list of conditions and the following disclaimer.
9
10
* Redistributions in binary form must reproduce the above copyright
11
notice, this list of conditions and the following disclaimer in
12
the documentation and/or other materials provided with the
13
distribution.
14
15
* Neither the name of the copyright holders nor the names of
16
contributors may be used to endorse or promote products derived
17
from this software without specific prior written permission.
18
19
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
20
AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
21
IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
22
ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
23
LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
24
CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
25
SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
26
INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
27
CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
28
ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
29
POSSIBILITY OF SUCH DAMAGE. */
30
31
32
/* avr/io2313.h - definitions for AT90S2313 */
33
34
#ifndef _AVR_IO2313_H_
35
#define _AVR_IO2313_H_ 1
36
37
/* This file should only be included from <avr/io.h>, never directly. */
38
39
#ifndef _AVR_IO_H_
40
# error "Include <avr/io.h> instead of this file."
41
#endif
42
43
#ifndef _AVR_IOXXX_H_
44
# define _AVR_IOXXX_H_ "io2313.h"
45
#else
46
# error "Attempt to include more than one <avr/ioXXX.h> file."
47
#endif
48
49
/* I/O registers */
50
51
/* Analog Comparator Control and Status Register */
52
#define ACSR _SFR_IO8(0x08)
53
54
/* UART Baud Rate Register */
55
#define UBRR _SFR_IO8(0x09)
56
57
/* UART Control Register */
58
#define UCR _SFR_IO8(0x0A)
59
60
/* UART Status Register */
61
#define USR _SFR_IO8(0x0B)
62
63
/* UART I/O Data Register */
64
#define UDR _SFR_IO8(0x0C)
65
66
/* Input Pins, Port D */
67
#define PIND _SFR_IO8(0x10)
68
69
/* Data Direction Register, Port D */
70
#define DDRD _SFR_IO8(0x11)
71
72
/* Data Register, Port D */
73
#define PORTD _SFR_IO8(0x12)
74
75
/* Input Pins, Port B */
76
#define PINB _SFR_IO8(0x16)
77
78
/* Data Direction Register, Port B */
79
#define DDRB _SFR_IO8(0x17)
80
81
/* Data Register, Port B */
82
#define PORTB _SFR_IO8(0x18)
83
84
/* EEPROM Control Register */
85
#define EECR _SFR_IO8(0x1C)
86
87
/* EEPROM Data Register */
88
#define EEDR _SFR_IO8(0x1D)
89
90
/* EEPROM Address Register */
91
#define EEAR _SFR_IO8(0x1E)
92
#define EEARL _SFR_IO8(0x1E)
93
94
/* Watchdog Timer Control Register */
95
#define WDTCR _SFR_IO8(0x21)
96
97
/* T/C 1 Input Capture Register */
98
#define ICR1 _SFR_IO16(0x24)
99
#define ICR1L _SFR_IO8(0x24)
100
#define ICR1H _SFR_IO8(0x25)
101
102
/* Output Compare Register 1 */
103
#define OCR1 _SFR_IO16(0x2A)
104
#define OCR1L _SFR_IO8(0x2A)
105
#define OCR1H _SFR_IO8(0x2B)
106
#define OCR1A _SFR_IO16(0x2A)
107
#define OCR1AL _SFR_IO8(0x2A)
108
#define OCR1AH _SFR_IO8(0x2B)
109
110
/* Timer/Counter 1 */
111
#define TCNT1 _SFR_IO16(0x2C)
112
#define TCNT1L _SFR_IO8(0x2C)
113
#define TCNT1H _SFR_IO8(0x2D)
114
115
/* Timer/Counter 1 Control and Status Register */
116
#define TCCR1B _SFR_IO8(0x2E)
117
118
/* Timer/Counter 1 Control Register */
119
#define TCCR1A _SFR_IO8(0x2F)
120
121
/* Timer/Counter 0 */
122
#define TCNT0 _SFR_IO8(0x32)
123
124
/* Timer/Counter 0 Control Register */
125
#define TCCR0 _SFR_IO8(0x33)
126
127
/* MCU general Control Register */
128
#define MCUCR _SFR_IO8(0x35)
129
130
/* Timer/Counter Interrupt Flag register */
131
#define TIFR _SFR_IO8(0x38)
132
133
/* Timer/Counter Interrupt MaSK register */
134
#define TIMSK _SFR_IO8(0x39)
135
136
/* General Interrupt Flag Register */
137
#define GIFR _SFR_IO8(0x3A)
138
139
/* General Interrupt MaSK register */
140
#define GIMSK _SFR_IO8(0x3B)
141
142
/* 0x3C..0x3D SP */
143
144
/* 0x3F SREG */
145
146
/* Interrupt vectors */
147
148
/* External Interrupt Request 0 */
149
#define INT0_vect _VECTOR(1)
150
#define SIG_INTERRUPT0 _VECTOR(1)
151
152
/* External Interrupt Request 1 */
153
#define INT1_vect _VECTOR(2)
154
#define SIG_INTERRUPT1 _VECTOR(2)
155
156
/* Timer/Counter1 Capture Event */
157
#define TIMER1_CAPT1_vect _VECTOR(3)
158
#define SIG_INPUT_CAPTURE1 _VECTOR(3)
159
160
/* Timer/Counter1 Compare Match */
161
#define TIMER1_COMP1_vect _VECTOR(4)
162
#define SIG_OUTPUT_COMPARE1A _VECTOR(4)
163
164
/* Timer/Counter1 Overflow */
165
#define TIMER1_OVF1_vect _VECTOR(5)
166
#define SIG_OVERFLOW1 _VECTOR(5)
167
168
/* Timer/Counter0 Overflow */
169
#define TIMER0_OVF0_vect _VECTOR(6)
170
#define SIG_OVERFLOW0 _VECTOR(6)
171
172
/* UART, Rx Complete */
173
#define UART_RX_vect _VECTOR(7)
174
#define SIG_UART_RECV _VECTOR(7)
175
176
/* UART Data Register Empty */
177
#define UART_UDRE_vect _VECTOR(8)
178
#define SIG_UART_DATA _VECTOR(8)
179
180
/* UART, Tx Complete */
181
#define UART_TX_vect _VECTOR(9)
182
#define SIG_UART_TRANS _VECTOR(9)
183
184
/* Analog Comparator */
185
#define ANA_COMP_vect _VECTOR(10)
186
#define SIG_COMPARATOR _VECTOR(10)
187
188
#define _VECTORS_SIZE 22
189
190
191
* The Register Bit names are represented by their bit number (0-7).
192
193
194
195
#define INT1 7
196
#define INT0 6
197
198
199
#define INTF1 7
200
#define INTF0 6
201
202
203
#define TOIE1 7
204
#define OCIE1A 6
205
#define TICIE 3
/* old name */
206
#define TICIE1 3
207
#define TOIE0 1
208
209
210
#define TOV1 7
211
#define OCF1A 6
212
#define ICF1 3
213
#define TOV0 1
214
215
216
#define SE 5
217
#define SM 4
218
#define ISC11 3
219
#define ISC10 2
220
#define ISC01 1
221
#define ISC00 0
222
223
224
#define CS02 2
225
#define CS01 1
226
#define CS00 0
227
228
229
#define COM1A1 7
230
#define COM1A0 6
231
#define PWM11 1
232
#define PWM10 0
233
234
235
#define ICNC1 7
236
#define ICES1 6
237
#define CTC1 3
238
#define CS12 2
239
#define CS11 1
240
#define CS10 0
241
242
243
#define WDTOE 4
244
#define WDE 3
245
#define WDP2 2
246
#define WDP1 1
247
#define WDP0 0
248
249
250
#define EEMWE 2
251
#define EEWE 1
252
#define EERE 0
253
254
255
#define PB7 7
256
#define PB6 6
257
#define PB5 5
258
#define PB4 4
259
#define PB3 3
260
#define PB2 2
261
#define PB1 1
262
#define PB0 0
263
264
265
#define DDB7 7
266
#define DDB6 6
267
#define DDB5 5
268
#define DDB4 4
269
#define DDB3 3
270
#define DDB2 2
271
#define DDB1 1
272
#define DDB0 0
273
274
275
#define PINB7 7
276
#define PINB6 6
277
#define PINB5 5
278
#define PINB4 4
279
#define PINB3 3
280
#define PINB2 2
281
#define PINB1 1
282
#define PINB0 0
283
284
285
#define PD6 6
286
#define PD5 5
287
#define PD4 4
288
#define PD3 3
289
#define PD2 2
290
#define PD1 1
291
#define PD0 0
292
293
294
#define DDD6 6
295
#define DDD5 5
296
#define DDD4 4
297
#define DDD3 3
298
#define DDD2 2
299
#define DDD1 1
300
#define DDD0 0
301
302
303
#define PIND6 6
304
#define PIND5 5
305
#define PIND4 4
306
#define PIND3 3
307
#define PIND2 2
308
#define PIND1 1
309
#define PIND0 0
310
311
312
#define RXC 7
313
#define TXC 6
314
#define UDRE 5
315
#define FE 4
316
#define DOR 3
317
318
319
#define RXCIE 7
320
#define TXCIE 6
321
#define UDRIE 5
322
#define RXEN 4
323
#define TXEN 3
324
#define CHR9 2
325
#define RXB8 1
326
#define TXB8 0
327
328
329
#define ACD 7
330
#define ACO 5
331
#define ACI 4
332
#define ACIE 3
333
#define ACIC 2
334
#define ACIS1 1
335
#define ACIS0 0
336
337
338
#define EERIE 3
339
#define EEMWE 2
340
#define EEWE 1
341
#define EERE 0
342
343
/* Constants */
344
#define RAMEND 0xDF
345
#define XRAMEND RAMEND
346
#define E2END 0x7F
347
#define E2PAGESIZE 0
348
#define FLASHEND 0x07FF
349
350
351
/* Fuses */
352
#define FUSE_MEMORY_SIZE 1
353
354
/* Low Fuse Byte */
355
#define FUSE_FSTRT (unsigned char)~_BV(0)
356
#define FUSE_SPIEN (unsigned char)~_BV(5)
357
#define LFUSE_DEFAULT (0xFF)
358
359
360
/* Lock Bits */
361
#define __LOCK_BITS_EXIST
362
363
364
/* Signature */
365
#define SIGNATURE_0 0x1E
366
#define SIGNATURE_1 0x91
367
#define SIGNATURE_2 0x01
368
369
370
#endif
/* _AVR_IO2313_H_ */
