admin
rtems-admin.git
doxygen
builder
latest
rtems.git
zlib
inflate.h
1
/* inflate.h -- internal inflate state definition
2
* Copyright (C) 1995-2009 Mark Adler
3
* For conditions of distribution and use, see copyright notice in zlib.h
4
5
6
/* WARNING: this file should *not* be used by applications. It is
7
part of the implementation of the compression library and is
8
subject to change. Applications should only use zlib.h.
9
10
11
/* define NO_GZIP when compiling if you want to disable gzip header and
12
trailer decoding by inflate(). NO_GZIP would be used to avoid linking in
13
the crc code when it is not needed. For shared libraries, gzip decoding
14
should be left enabled. */
15
#ifndef NO_GZIP
16
# define GUNZIP
17
#endif
18
19
/* Possible inflate modes between inflate() calls */
20
typedef
enum
21
HEAD,
/* i: waiting for magic header */
22
FLAGS,
/* i: waiting for method and flags (gzip) */
23
TIME,
/* i: waiting for modification time (gzip) */
24
OS,
/* i: waiting for extra flags and operating system (gzip) */
25
EXLEN,
/* i: waiting for extra length (gzip) */
26
EXTRA,
/* i: waiting for extra bytes (gzip) */
27
NAME,
/* i: waiting for end of file name (gzip) */
28
COMMENT,
/* i: waiting for end of comment (gzip) */
29
HCRC,
/* i: waiting for header crc (gzip) */
30
DICTID,
/* i: waiting for dictionary check value */
31
DICT,
/* waiting for inflateSetDictionary() call */
32
TYPE,
/* i: waiting for type bits, including last-flag bit */
33
TYPEDO,
/* i: same, but skip check to exit inflate on new block */
34
STORED,
/* i: waiting for stored size (length and complement) */
35
COPY_,
/* i/o: same as COPY below, but only first time in */
36
COPY,
/* i/o: waiting for input or output to copy stored block */
37
TABLE,
/* i: waiting for dynamic block table lengths */
38
LENLENS,
/* i: waiting for code length code lengths */
39
CODELENS,
/* i: waiting for length/lit and distance code lengths */
40
LEN_,
/* i: same as LEN below, but only first time in */
41
LEN,
/* i: waiting for length/lit/eob code */
42
LENEXT,
/* i: waiting for length extra bits */
43
DIST,
/* i: waiting for distance code */
44
DISTEXT,
/* i: waiting for distance extra bits */
45
MATCH,
/* o: waiting for output space to copy string */
46
LIT,
/* o: waiting for output space to write literal */
47
CHECK,
/* i: waiting for 32-bit check value */
48
LENGTH,
/* i: waiting for 32-bit length (gzip) */
49
DONE,
/* finished check, done -- remain here until reset */
50
BAD,
/* got a data error -- remain here until reset */
51
MEM,
/* got an inflate() memory error -- remain here until reset */
52
SYNC
/* looking for synchronization bytes to restart inflate() */
53
} inflate_mode;
54
55
56
State transitions between above modes -
57
58
(most modes can go to BAD or MEM on error -- not shown for clarity)
59
60
Process header:
61
HEAD -> (gzip) or (zlib) or (raw)
62
(gzip) -> FLAGS -> TIME -> OS -> EXLEN -> EXTRA -> NAME -> COMMENT ->
63
HCRC -> TYPE
64
(zlib) -> DICTID or TYPE
65
DICTID -> DICT -> TYPE
66
(raw) -> TYPEDO
67
Read deflate blocks:
68
TYPE -> TYPEDO -> STORED or TABLE or LEN_ or CHECK
69
STORED -> COPY_ -> COPY -> TYPE
70
TABLE -> LENLENS -> CODELENS -> LEN_
71
LEN_ -> LEN
72
Read deflate codes in fixed or dynamic block:
73
LEN -> LENEXT or LIT or TYPE
74
LENEXT -> DIST -> DISTEXT -> MATCH -> LEN
75
LIT -> LEN
76
Process trailer:
77
CHECK -> LENGTH -> DONE
78
79
80
/* state maintained between inflate() calls. Approximately 10K bytes. */
81
struct
inflate_state
82
inflate_mode mode;
/* current inflate mode */
83
int
last;
/* true if processing last block */
84
int
wrap;
/* bit 0 true for zlib, bit 1 true for gzip */
85
int
havedict;
/* true if dictionary provided */
86
int
flags;
/* gzip header method and flags (0 if zlib) */
87
unsigned
dmax;
/* zlib header max distance (INFLATE_STRICT) */
88
unsigned
long
check;
/* protected copy of check value */
89
unsigned
long
total;
/* protected copy of output count */
90
gz_headerp head;
/* where to save gzip header information */
91
/* sliding window */
92
unsigned
wbits;
/* log base 2 of requested window size */
93
unsigned
wsize;
/* window size or zero if not using window */
94
unsigned
whave;
/* valid bytes in the window */
95
unsigned
wnext;
/* window write index */
96
unsigned
char
FAR *window;
/* allocated sliding window, if needed */
97
/* bit accumulator */
98
unsigned
long
hold;
/* input bit accumulator */
99
unsigned
bits;
/* number of bits in "in" */
100
/* for string and stored block copying */
101
unsigned
length;
/* literal or length of data to copy */
102
unsigned
offset;
/* distance back to copy string from */
103
/* for table and code decoding */
104
unsigned
extra;
/* extra bits needed */
105
/* fixed and dynamic code tables */
106
code
const
FAR *lencode;
/* starting table for length/literal codes */
107
code
const
FAR *distcode;
/* starting table for distance codes */
108
unsigned
lenbits;
/* index bits for lencode */
109
unsigned
distbits;
/* index bits for distcode */
110
/* dynamic table building */
111
unsigned
ncode;
/* number of code length code lengths */
112
unsigned
nlen;
/* number of length code lengths */
113
unsigned
ndist;
/* number of distance code lengths */
114
unsigned
have;
/* number of code lengths in lens[] */
115
code
FAR *next;
/* next available space in codes[] */
116
unsigned
short
lens[320];
/* temporary storage for code lengths */
117
unsigned
short
work[288];
/* work area for code table building */
118
code
codes[ENOUGH];
/* space for code tables */
119
int
sane;
/* if false, allow invalid distance too far */
120
int
back;
/* bits back of last unprocessed length/lit */
121
unsigned
was;
/* initial length of match */
122
inflate_state
Definition:
inflate.h:82
code
Definition:
inftrees.h:25
