include/rtems/irq.h
1
8 /*
9  * CopyRight (C) 1998 valette@crf.canon.fr
10  *
11  * This code is heavilly inspired by the public specification of STREAM V2
12  * that can be found at :
13  *
14  * <http://www.chorus.com/Documentation/index.html> by following
15  * the STREAM API Specification Document link.
16  *
17  * The license and distribution terms for this file may be
18  * found in the file LICENSE in this distribution or at
19  * http://www.rtems.org/license/LICENSE.
20  */
21
22 #ifndef _RTEMS_IRQ_H
23 #define _RTEMS_IRQ_H
24
25 #ifndef ASM
26
27 #ifdef __cplusplus
28 extern "C" {
29 #endif
30
31
32 /*
33  * Type definition for RTEMS managed interrupts
34  */
35 typedef unsigned char rtems_irq_prio;
36 struct __rtems_irq_connect_data__; /* forward declaratiuon */
37
38 typedef unsigned int rtems_irq_number;
39 typedef void *rtems_irq_hdl_param;
40 typedef void (*rtems_irq_hdl) (rtems_irq_hdl_param);
41 typedef void (*rtems_irq_enable) (const struct __rtems_irq_connect_data__*);
42 typedef void (*rtems_irq_disable) (const struct __rtems_irq_connect_data__*);
43 typedef int (*rtems_irq_is_enabled) (const struct __rtems_irq_connect_data__*);
44
46  /*
47  * IRQ line
48  */
49  rtems_irq_number name;
50  /*
51  * handler. See comment on handler properties below in function prototype.
52  */
53  rtems_irq_hdl hdl;
54  /*
55  * Handler handle to store private data
56  */
57  rtems_irq_hdl_param handle;
58  /*
59  * function for enabling interrupts at device level (ONLY!).
60  * The BSP code will automatically enable it at i8259s level.
61  * RATIONALE : anyway such code has to exist in current driver code.
62  * It is usually called immediately AFTER connecting the interrupt handler.
63  * RTEMS may well need such a function when restoring normal interrupt
64  * processing after a debug session.
65  *
66  */
67  rtems_irq_enable on;
68  /*
69  * function for disabling interrupts at device level (ONLY!).
70  * The code will disable it at i8259s level. RATIONALE : anyway
71  * such code has to exist for clean shutdown. It is usually called
72  * BEFORE disconnecting the interrupt. RTEMS may well need such
73  * a function when disabling normal interrupt processing for
74  * a debug session. May well be a NOP function.
75  */
76  rtems_irq_disable off;
77  /*
78  * function enabling to know what interrupt may currently occur
79  * if someone manipulates the i8259s interrupt mask without care...
80  */
81  rtems_irq_is_enabled isOn;
82
83 #ifdef BSP_SHARED_HANDLER_SUPPORT
84  /*
85  * Set to -1 for vectors forced to have only 1 handler
86  */
87  void *next_handler;
88 #endif
89
91
92 typedef struct {
93  /*
94  * size of all the table fields (*Tbl) described below.
95  */
96  unsigned int irqNb;
97  /*
98  * Default handler used when disconnecting interrupts.
99  */
100  rtems_irq_connect_data defaultEntry;
101  /*
102  * Table containing initials/current value.
103  */
104  rtems_irq_connect_data* irqHdlTbl;
105  /*
106  * actual value of BSP_ISA_IRQ_VECTOR_BASE...
107  */
108  rtems_irq_number irqBase;
109  /*
110  * software priorities associated with interrupts.
111  * if (*irqPrio [i] > intrPrio [j] it means that
112  * interrupt handler hdl connected for interrupt name i
113  * will not be interrupted by the handler connected for interrupt j
114  * The interrupt source will be physically masked at i8259 level.
115  */
116  rtems_irq_prio* irqPrioTbl;
118
119 /*-------------------------------------------------------------------------+
120 | Function Prototypes.
121 +--------------------------------------------------------------------------*/
122 /*
123  * -------------------- RTEMS Single Irq Handler Mngt Routines ----------------
124  */
125 /*
126  * function to connect a particular irq handler. This hanlder will NOT be called
127  * directly as the result of the corresponding interrupt. Instead, a RTEMS
128  * irq prologue will be called that will :
129  *
130  * 1) save the C scratch registers,
131  * 2) switch to a interrupt stack if the interrupt is not nested,
132  * 3) store the current i8259s' interrupt masks
133  * 4) modify them to disable the current interrupt at 8259 level (and may
134  * be others depending on software priorities)
135  * 5) aknowledge the i8259s',
136  * 6) demask the processor,
137  * 7) call the application handler
138  *
139  * As a result the hdl function provided
140  *
141  * a) can perfectly be written is C,
142  * b) may also well directly call the part of the RTEMS API that can be
143  * used from interrupt level,
144  * c) It only responsible for handling the jobs that need to be done at
145  * the device level including (aknowledging/re-enabling the interrupt at
146  * device level, getting the data,...)
147  *
148  * When returning from the function, the following will be performed by
149  * the RTEMS irq epilogue :
150  *
151  * 1) masks the interrupts again,
152  * 2) restore the original i8259s' interrupt masks
153  * 3) switch back on the orinal stack if needed,
154  * 4) perform rescheduling when necessary,
155  * 5) restore the C scratch registers...
156  * 6) restore initial execution flow
157  *
158  */
159 int BSP_install_rtems_irq_handler (const rtems_irq_connect_data*);
160 /*
161  * function to get the current RTEMS irq handler for ptr->name. It enables to
162  * define hanlder chain...
163  */
164 int BSP_get_current_rtems_irq_handler (rtems_irq_connect_data* ptr);
165 /*
166  * function to get disconnect the RTEMS irq handler for ptr->name.
167  * This function checks that the value given is the current one for safety reason.
168  * The user can use the previous function to get it.
169  */
170 int BSP_remove_rtems_irq_handler (const rtems_irq_connect_data*);
171
172
173 /*
174  * ----------------- RTEMS Shared Irq Handler Mngt Routines ----------------
175  */
176 #ifdef BSP_SHARED_HANDLER_SUPPORT
177 int BSP_install_rtems_shared_irq_handler (const rtems_irq_connect_data*);
178 #endif
179
180 /*
181  * Less cumbersome, alternate entry points;
182  * RETURNS: more traditional, 0 on success, nonzero on error
183  *
184  * The BSP_rtems_int_connect() and BSP_rtems_int_disconnect() functions are
185  * only present on some PowerPC BSPs. Do not use them. Use
186  * rtems_interrupt_handler_install() instead.
187  */
188
189 int BSP_rtems_int_connect(
190  rtems_irq_number n,
191  rtems_irq_hdl hdl,
192  rtems_irq_hdl_param p
193 );
194
195 int BSP_rtems_int_disconnect(
196  rtems_irq_number n,
197  rtems_irq_hdl hdl,
198  rtems_irq_hdl_param p
199 );
200
201 /*
202  * ----------------- RTEMS Global Irq Handler Mngt Routines ----------------
203  */
204 /*
205  * (Re) Initialize the RTEMS interrupt management.
206  *
207  * The result of calling this function will be the same as if each individual
208  * handler (config->irqHdlTbl[i].hdl) different from "config->defaultEntry.hdl"
209  * has been individualy connected via
210  * BSP_install_rtems_irq_handler(&config->irqHdlTbl[i])
211  * And each handler currently equal to config->defaultEntry.hdl
212  * has been previously disconnected via
213  * BSP_remove_rtems_irq_handler (&config->irqHdlTbl[i])
214  *
215  * This is to say that all information given will be used and not just
216  * only the space.
217  *
218  * CAUTION : the various table address contained in config will be used
219  * directly by the interrupt mangement code in order to save
220  * data size so they must stay valid after the call => they should
221  * not be modified or declared on a stack.
222  */
223
224 int BSP_rtems_irq_mngt_set(rtems_irq_global_settings* config);
225
226 /*
227  * (Re) get info on current RTEMS interrupt management.
228  */
229 int BSP_rtems_irq_mngt_get(rtems_irq_global_settings**);
230
231 #ifdef __cplusplus
232 }
233 #endif
234
235 #endif /* ASM */
236 #endif /* _RTEMS_IRQ_H */
Definition: deflate.c:116
Definition: include/rtems/irq.h:92
Definition: include/rtems/irq.h:45
