include/rtems/fs.h
1
9 /*
10  * COPYRIGHT (c) 1989-2011.
11  * On-Line Applications Research Corporation (OAR).
12  *
13  * Modifications to support reference counting in the file system are
14  * Copyright (c) 2012 embedded brains GmbH.
15  *
16  * The license and distribution terms for this file may be
17  * found in the file LICENSE in this distribution or at
18  * http://www.rtems.org/license/LICENSE.
19  */
20
21 #ifndef _RTEMS_FS_H
22 #define _RTEMS_FS_H
23
24 #include <rtems/chain.h>
25
26 #ifdef __cplusplus
27 extern "C" {
28 #endif
29
30 /*
31  * File descriptor Table Information
32  */
33
34 /* Forward declarations */
35
36 /* FIXME: shouldn't this better not be here? */
37 typedef struct rtems_libio_tt rtems_libio_t;
38
42
47
54  rtems_chain_node mt_entry_node;
55  void *node_access;
56  void *node_access_2;
57  const rtems_filesystem_file_handlers_r *handlers;
60
83  int reference_count;
84
91
98
99 /*
100  * Return the mount table entry for a path location.
101  */
102 #define rtems_filesystem_location_mount(_pl) ((_pl)->mt_entry)
103
104 #ifdef __cplusplus
105 }
106 #endif
107
108 #endif
109 /* end of include file */
struct rtems_filesystem_global_location_t rtems_filesystem_global_location_t
Global file system location.
This is used to manage each element (node) which is placed on a chain.
Definition: score/include/rtems/score/chain.h:65
struct rtems_filesystem_location_info_tt rtems_filesystem_location_info_t
File system location.
File system node operations table.
Definition: libio.h:982
int deferred_released_count
A release within a critical section can happen multiple times.
Definition: include/rtems/fs.h:96
Mount table entry.
Definition: libio.h:1542
File system operations table.
Definition: libio.h:471
Chain API.
An open file data structure.
Definition: libio.h:1281
Definition: include/rtems/fs.h:81
Definition: include/rtems/fs.h:53
struct rtems_filesystem_global_location_t * deferred_released_next
A release within a critical section of the operating system will add this location to a list of defer...
Definition: include/rtems/fs.h:90
