admin
rtems-admin.git
doxygen
builder
latest
rtems.git
libnetworking
net
if_types.h
1
2
* Copyright (c) 1989, 1993, 1994
3
* The Regents of the University of California. All rights reserved.
4
5
6
* modification, are permitted provided that the following conditions
7
* are met:
8
* 1. Redistributions of source code must retain the above copyright
9
* notice, this list of conditions and the following disclaimer.
10
* 2. Redistributions in binary form must reproduce the above copyright
11
* notice, this list of conditions and the following disclaimer in the
12
* documentation and/or other materials provided with the distribution.
13
* 4. Neither the name of the University nor the names of its contributors
14
* may be used to endorse or promote products derived from this software
15
* without specific prior written permission.
16
17
* THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
18
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
19
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20
* ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
21
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
22
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
23
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
24
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
25
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
26
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
27
* SUCH DAMAGE.
28
29
* @(#)if_types.h 8.3 (Berkeley) 4/28/95
30
* $FreeBSD: src/sys/net/if_types.h,v 1.18 2005/02/22 13:04:03 glebius Exp $
31
* $NetBSD: if_types.h,v 1.16 2000/04/19 06:30:53 itojun Exp $
32
33
34
35
#ifndef _NET_IF_TYPES_H_
36
#define _NET_IF_TYPES_H_
37
38
39
* Interface types for benefit of parsing media address headers.
40
* This list is derived from the SNMP list of ifTypes, originally
41
* documented in RFC1573, now maintained as:
42
43
* ftp.isi.edu/in-notes/iana/assignments/smi-numbers
44
45
46
#define IFT_OTHER 0x1
/* none of the following */
47
#define IFT_1822 0x2
/* old-style arpanet imp */
48
#define IFT_HDH1822 0x3
/* HDH arpanet imp */
49
#define IFT_X25DDN 0x4
/* x25 to imp */
50
#define IFT_X25 0x5
/* PDN X25 interface (RFC877) */
51
#define IFT_ETHER 0x6
/* Ethernet CSMA/CD */
52
#define IFT_ISO88023 0x7
/* CMSA/CD */
53
#define IFT_ISO88024 0x8
/* Token Bus */
54
#define IFT_ISO88025 0x9
/* Token Ring */
55
#define IFT_ISO88026 0xa
/* MAN */
56
#define IFT_STARLAN 0xb
57
#define IFT_P10 0xc
/* Proteon 10MBit ring */
58
#define IFT_P80 0xd
/* Proteon 80MBit ring */
59
#define IFT_HY 0xe
/* Hyperchannel */
60
#define IFT_FDDI 0xf
61
#define IFT_LAPB 0x10
62
#define IFT_SDLC 0x11
63
#define IFT_T1 0x12
64
#define IFT_CEPT 0x13
/* E1 - european T1 */
65
#define IFT_ISDNBASIC 0x14
66
#define IFT_ISDNPRIMARY 0x15
67
#define IFT_PTPSERIAL 0x16
/* Proprietary PTP serial */
68
#define IFT_PPP 0x17
/* RFC 1331 */
69
#define IFT_LOOP 0x18
/* loopback */
70
#define IFT_EON 0x19
/* ISO over IP */
71
#define IFT_XETHER 0x1a
/* obsolete 3MB experimental ethernet */
72
#define IFT_NSIP 0x1b
/* XNS over IP */
73
#define IFT_SLIP 0x1c
/* IP over generic TTY */
74
#define IFT_ULTRA 0x1d
/* Ultra Technologies */
75
#define IFT_DS3 0x1e
/* Generic T3 */
76
#define IFT_SIP 0x1f
/* SMDS */
77
#define IFT_FRELAY 0x20
/* Frame Relay DTE only */
78
#define IFT_RS232 0x21
79
#define IFT_PARA 0x22
/* parallel-port */
80
#define IFT_ARCNET 0x23
81
#define IFT_ARCNETPLUS 0x24
82
#define IFT_ATM 0x25
/* ATM cells */
83
#define IFT_MIOX25 0x26
84
#define IFT_SONET 0x27
/* SONET or SDH */
85
#define IFT_X25PLE 0x28
86
#define IFT_ISO88022LLC 0x29
87
#define IFT_LOCALTALK 0x2a
88
#define IFT_SMDSDXI 0x2b
89
#define IFT_FRELAYDCE 0x2c
/* Frame Relay DCE */
90
#define IFT_V35 0x2d
91
#define IFT_HSSI 0x2e
92
#define IFT_HIPPI 0x2f
93
#define IFT_MODEM 0x30
/* Generic Modem */
94
#define IFT_AAL5 0x31
/* AAL5 over ATM */
95
#define IFT_SONETPATH 0x32
96
#define IFT_SONETVT 0x33
97
#define IFT_SMDSICIP 0x34
/* SMDS InterCarrier Interface */
98
#define IFT_PROPVIRTUAL 0x35
/* Proprietary Virtual/internal */
99
#define IFT_PROPMUX 0x36
/* Proprietary Multiplexing */
100
#define IFT_IEEE80212 0x37
/* 100BaseVG */
101
#define IFT_FIBRECHANNEL 0x38
/* Fibre Channel */
102
#define IFT_HIPPIINTERFACE 0x39
/* HIPPI interfaces */
103
#define IFT_FRAMERELAYINTERCONNECT 0x3a
/* Obsolete, use either 0x20 or 0x2c */
104
#define IFT_AFLANE8023 0x3b
/* ATM Emulated LAN for 802.3 */
105
#define IFT_AFLANE8025 0x3c
/* ATM Emulated LAN for 802.5 */
106
#define IFT_CCTEMUL 0x3d
/* ATM Emulated circuit */
107
#define IFT_FASTETHER 0x3e
/* Fast Ethernet (100BaseT) */
108
#define IFT_ISDN 0x3f
/* ISDN and X.25 */
109
#define IFT_V11 0x40
/* CCITT V.11/X.21 */
110
#define IFT_V36 0x41
/* CCITT V.36 */
111
#define IFT_G703AT64K 0x42
/* CCITT G703 at 64Kbps */
112
#define IFT_G703AT2MB 0x43
/* Obsolete see DS1-MIB */
113
#define IFT_QLLC 0x44
/* SNA QLLC */
114
#define IFT_FASTETHERFX 0x45
/* Fast Ethernet (100BaseFX) */
115
#define IFT_CHANNEL 0x46
/* channel */
116
#define IFT_IEEE80211 0x47
/* radio spread spectrum */
117
#define IFT_IBM370PARCHAN 0x48
/* IBM System 360/370 OEMI Channel */
118
#define IFT_ESCON 0x49
/* IBM Enterprise Systems Connection */
119
#define IFT_DLSW 0x4a
/* Data Link Switching */
120
#define IFT_ISDNS 0x4b
/* ISDN S/T interface */
121
#define IFT_ISDNU 0x4c
/* ISDN U interface */
122
#define IFT_LAPD 0x4d
/* Link Access Protocol D */
123
#define IFT_IPSWITCH 0x4e
/* IP Switching Objects */
124
#define IFT_RSRB 0x4f
/* Remote Source Route Bridging */
125
#define IFT_ATMLOGICAL 0x50
/* ATM Logical Port */
126
#define IFT_DS0 0x51
/* Digital Signal Level 0 */
127
#define IFT_DS0BUNDLE 0x52
/* group of ds0s on the same ds1 */
128
#define IFT_BSC 0x53
/* Bisynchronous Protocol */
129
#define IFT_ASYNC 0x54
/* Asynchronous Protocol */
130
#define IFT_CNR 0x55
/* Combat Net Radio */
131
#define IFT_ISO88025DTR 0x56
/* ISO 802.5r DTR */
132
#define IFT_EPLRS 0x57
/* Ext Pos Loc Report Sys */
133
#define IFT_ARAP 0x58
/* Appletalk Remote Access Protocol */
134
#define IFT_PROPCNLS 0x59
/* Proprietary Connectionless Protocol*/
135
#define IFT_HOSTPAD 0x5a
/* CCITT-ITU X.29 PAD Protocol */
136
#define IFT_TERMPAD 0x5b
/* CCITT-ITU X.3 PAD Facility */
137
#define IFT_FRAMERELAYMPI 0x5c
/* Multiproto Interconnect over FR */
138
#define IFT_X213 0x5d
/* CCITT-ITU X213 */
139
#define IFT_ADSL 0x5e
/* Asymmetric Digital Subscriber Loop */
140
#define IFT_RADSL 0x5f
/* Rate-Adapt. Digital Subscriber Loop*/
141
#define IFT_SDSL 0x60
/* Symmetric Digital Subscriber Loop */
142
#define IFT_VDSL 0x61
/* Very H-Speed Digital Subscrib. Loop*/
143
#define IFT_ISO88025CRFPINT 0x62
/* ISO 802.5 CRFP */
144
#define IFT_MYRINET 0x63
/* Myricom Myrinet */
145
#define IFT_VOICEEM 0x64
/* voice recEive and transMit */
146
#define IFT_VOICEFXO 0x65
/* voice Foreign Exchange Office */
147
#define IFT_VOICEFXS 0x66
/* voice Foreign Exchange Station */
148
#define IFT_VOICEENCAP 0x67
/* voice encapsulation */
149
#define IFT_VOICEOVERIP 0x68
/* voice over IP encapsulation */
150
#define IFT_ATMDXI 0x69
/* ATM DXI */
151
#define IFT_ATMFUNI 0x6a
/* ATM FUNI */
152
#define IFT_ATMIMA 0x6b
/* ATM IMA */
153
#define IFT_PPPMULTILINKBUNDLE 0x6c
/* PPP Multilink Bundle */
154
#define IFT_IPOVERCDLC 0x6d
/* IBM ipOverCdlc */
155
#define IFT_IPOVERCLAW 0x6e
/* IBM Common Link Access to Workstn */
156
#define IFT_STACKTOSTACK 0x6f
/* IBM stackToStack */
157
#define IFT_VIRTUALIPADDRESS 0x70
/* IBM VIPA */
158
#define IFT_MPC 0x71
/* IBM multi-protocol channel support */
159
#define IFT_IPOVERATM 0x72
/* IBM ipOverAtm */
160
#define IFT_ISO88025FIBER 0x73
/* ISO 802.5j Fiber Token Ring */
161
#define IFT_TDLC 0x74
/* IBM twinaxial data link control */
162
#define IFT_GIGABITETHERNET 0x75
/* Gigabit Ethernet */
163
#define IFT_HDLC 0x76
/* HDLC */
164
#define IFT_LAPF 0x77
/* LAP F */
165
#define IFT_V37 0x78
/* V.37 */
166
#define IFT_X25MLP 0x79
/* Multi-Link Protocol */
167
#define IFT_X25HUNTGROUP 0x7a
/* X25 Hunt Group */
168
#define IFT_TRANSPHDLC 0x7b
/* Transp HDLC */
169
#define IFT_INTERLEAVE 0x7c
/* Interleave channel */
170
#define IFT_FAST 0x7d
/* Fast channel */
171
#define IFT_IP 0x7e
/* IP (for APPN HPR in IP networks) */
172
#define IFT_DOCSCABLEMACLAYER 0x7f
/* CATV Mac Layer */
173
#define IFT_DOCSCABLEDOWNSTREAM 0x80
/* CATV Downstream interface */
174
#define IFT_DOCSCABLEUPSTREAM 0x81
/* CATV Upstream interface */
175
#define IFT_A12MPPSWITCH 0x82
/* Avalon Parallel Processor */
176
#define IFT_TUNNEL 0x83
/* Encapsulation interface */
177
#define IFT_COFFEE 0x84
/* coffee pot */
178
#define IFT_CES 0x85
/* Circiut Emulation Service */
179
#define IFT_ATMSUBINTERFACE 0x86
/* (x) ATM Sub Interface */
180
#define IFT_L2VLAN 0x87
/* Layer 2 Virtual LAN using 802.1Q */
181
#define IFT_L3IPVLAN 0x88
/* Layer 3 Virtual LAN - IP Protocol */
182
#define IFT_L3IPXVLAN 0x89
/* Layer 3 Virtual LAN - IPX Prot. */
183
#define IFT_DIGITALPOWERLINE 0x8a
/* IP over Power Lines */
184
#define IFT_MEDIAMAILOVERIP 0x8b
/* (xxx) Multimedia Mail over IP */
185
#define IFT_DTM 0x8c
/* Dynamic synchronous Transfer Mode */
186
#define IFT_DCN 0x8d
/* Data Communications Network */
187
#define IFT_IPFORWARD 0x8e
/* IP Forwarding Interface */
188
#define IFT_MSDSL 0x8f
/* Multi-rate Symmetric DSL */
189
#define IFT_IEEE1394 0x90
/* IEEE1394 High Performance SerialBus*/
190
#define IFT_IFGSN 0x91
/* HIPPI-6400 */
191
#define IFT_DVBRCCMACLAYER 0x92
/* DVB-RCC MAC Layer */
192
#define IFT_DVBRCCDOWNSTREAM 0x93
/* DVB-RCC Downstream Channel */
193
#define IFT_DVBRCCUPSTREAM 0x94
/* DVB-RCC Upstream Channel */
194
#define IFT_ATMVIRTUAL 0x95
/* ATM Virtual Interface */
195
#define IFT_MPLSTUNNEL 0x96
/* MPLS Tunnel Virtual Interface */
196
#define IFT_SRP 0x97
/* Spatial Reuse Protocol */
197
#define IFT_VOICEOVERATM 0x98
/* Voice over ATM */
198
#define IFT_VOICEOVERFRAMERELAY 0x99
/* Voice Over Frame Relay */
199
#define IFT_IDSL 0x9a
/* Digital Subscriber Loop over ISDN */
200
#define IFT_COMPOSITELINK 0x9b
/* Avici Composite Link Interface */
201
#define IFT_SS7SIGLINK 0x9c
/* SS7 Signaling Link */
202
#define IFT_PROPWIRELESSP2P 0x9d
/* Prop. P2P wireless interface */
203
#define IFT_FRFORWARD 0x9e
/* Frame forward Interface */
204
#define IFT_RFC1483 0x9f
/* Multiprotocol over ATM AAL5 */
205
#define IFT_USB 0xa0
/* USB Interface */
206
#define IFT_IEEE8023ADLAG 0xa1
/* IEEE 802.3ad Link Aggregate*/
207
#define IFT_BGPPOLICYACCOUNTING 0xa2
/* BGP Policy Accounting */
208
#define IFT_FRF16MFRBUNDLE 0xa3
/* FRF.16 Multilik Frame Relay*/
209
#define IFT_H323GATEKEEPER 0xa4
/* H323 Gatekeeper */
210
#define IFT_H323PROXY 0xa5
/* H323 Voice and Video Proxy */
211
#define IFT_MPLS 0xa6
/* MPLS */
212
#define IFT_MFSIGLINK 0xa7
/* Multi-frequency signaling link */
213
#define IFT_HDSL2 0xa8
/* High Bit-Rate DSL, 2nd gen. */
214
#define IFT_SHDSL 0xa9
/* Multirate HDSL2 */
215
#define IFT_DS1FDL 0xaa
/* Facility Data Link (4Kbps) on a DS1*/
216
#define IFT_POS 0xab
/* Packet over SONET/SDH Interface */
217
#define IFT_DVBASILN 0xac
/* DVB-ASI Input */
218
#define IFT_DVBASIOUT 0xad
/* DVB-ASI Output */
219
#define IFT_PLC 0xae
/* Power Line Communications */
220
#define IFT_NFAS 0xaf
/* Non-Facility Associated Signaling */
221
#define IFT_TR008 0xb0
/* TROO8 */
222
#define IFT_GR303RDT 0xb1
/* Remote Digital Terminal */
223
#define IFT_GR303IDT 0xb2
/* Integrated Digital Terminal */
224
#define IFT_ISUP 0xb3
/* ISUP */
225
#define IFT_PROPDOCSWIRELESSMACLAYER 0xb4
/* prop/Wireless MAC Layer */
226
#define IFT_PROPDOCSWIRELESSDOWNSTREAM 0xb5
/* prop/Wireless Downstream */
227
#define IFT_PROPDOCSWIRELESSUPSTREAM 0xb6
/* prop/Wireless Upstream */
228
#define IFT_HIPERLAN2 0xb7
/* HIPERLAN Type 2 Radio Interface */
229
#define IFT_PROPBWAP2MP 0xb8
/* PropBroadbandWirelessAccess P2MP*/
230
#define IFT_SONETOVERHEADCHANNEL 0xb9
/* SONET Overhead Channel */
231
#define IFT_DIGITALWRAPPEROVERHEADCHANNEL 0xba
/* Digital Wrapper Overhead */
232
#define IFT_AAL2 0xbb
/* ATM adaptation layer 2 */
233
#define IFT_RADIOMAC 0xbc
/* MAC layer over radio links */
234
#define IFT_ATMRADIO 0xbd
/* ATM over radio links */
235
#define IFT_IMT 0xbe
/* Inter-Machine Trunks */
236
#define IFT_MVL 0xbf
/* Multiple Virtual Lines DSL */
237
#define IFT_REACHDSL 0xc0
/* Long Reach DSL */
238
#define IFT_FRDLCIENDPT 0xc1
/* Frame Relay DLCI End Point */
239
#define IFT_ATMVCIENDPT 0xc2
/* ATM VCI End Point */
240
#define IFT_OPTICALCHANNEL 0xc3
/* Optical Channel */
241
#define IFT_OPTICALTRANSPORT 0xc4
/* Optical Transport */
242
243
#define IFT_STF 0xd7
/* 6to4 interface */
244
245
/* not based on IANA assignments */
246
#define IFT_GIF 0xf0
247
#define IFT_PVC 0xf1
248
#define IFT_FAITH 0xf2
249
#define IFT_PFLOG 0xf6
250
#define IFT_PFSYNC 0xf7
251
#define IFT_CARP 0xf8
/* Common Address Redundancy Protocol */
252
#endif
/* !_NET_IF_TYPES_H_ */
