i386/rtems/asm.h
1
17 /*
18  * COPYRIGHT:
19  *
20  * This file is based on similar code found in newlib available
21  * from ftp.cygnus.com. The file which was used had no copyright
22  * notice. This file is freely distributable as long as the source
23  * of the file is noted. This file is:
24  *
25  * COPYRIGHT (c) 1994-1997.
26  * On-Line Applications Research Corporation (OAR).
27  */
28
29 #ifndef _RTEMS_ASM_H
30 #define _RTEMS_ASM_H
31
32 /*
33  * Indicate we are in an assembly file and get the basic CPU definitions.
34  */
35
36 #ifndef ASM
37 #define ASM
38 #endif
39 #include <rtems/score/cpuopts.h>
40 #include <rtems/score/i386.h>
41
42 /*
43  * Recent versions of GNU cpp define variables which indicate the
44  * need for underscores and percents. If not using GNU cpp or
45  * the version does not support this, then you will obviously
46  * have to define these as appropriate.
47  */
48
49 #ifndef __USER_LABEL_PREFIX__
50 #define __USER_LABEL_PREFIX__
51 #endif
52
53 /*
54  * Looks like there is a bug in gcc 2.6.2 where this is not
55  * defined correctly when configured as i386-coff and
56  * i386-aout.
57  */
58
59 #undef __REGISTER_PREFIX__
60 #define __REGISTER_PREFIX__ %
61
62 /*
63 #ifndef __REGISTER_PREFIX__
64 #define __REGISTER_PREFIX__
65 #endif
66 */
67
68 #include <rtems/concat.h>
69
70 /* Use the right prefix for global labels. */
71
72 #define SYM(x) CONCAT0 (__USER_LABEL_PREFIX__, x)
73
74 /* Use the right prefix for registers. */
75
76 #define REG(x) CONCAT0 (__REGISTER_PREFIX__, x)
77
78 #define eax REG (eax)
79 #define ebx REG (ebx)
80 #define ecx REG (ecx)
81 #define edx REG (edx)
82 #define esi REG (esi)
83 #define edi REG (edi)
84 #define esp REG (esp)
85 #define ebp REG (ebp)
86 #define cr0 REG (cr0)
87 #define cr4 REG (cr4)
88
89 #define ax REG (ax)
90 #define bx REG (bx)
91 #define cx REG (cx)
92 #define dx REG (dx)
93 #define si REG (si)
94 #define di REG (di)
95 #define sp REG (sp)
96 #define bp REG (bp)
97
98 #define ah REG (ah)
99 #define bh REG (bh)
100 #define ch REG (ch)
101 #define dh REG (dh)
102
103 #define al REG (al)
104 #define bl REG (bl)
105 #define cl REG (cl)
106 #define dl REG (dl)
107
108 #define cs REG (cs)
109 #define ds REG (ds)
110 #define es REG (es)
111 #define fs REG (fs)
112 #define gs REG (gs)
113 #define ss REG (ss)
114
115 /*
116  * Define macros to handle section beginning and ends.
117  */
118
119
120 #define BEGIN_CODE_DCL .text
121 #define END_CODE_DCL
122 #define BEGIN_DATA_DCL .data
123 #define END_DATA_DCL
124 #define BEGIN_CODE .text
125 #define END_CODE
126 #define BEGIN_DATA .data
127 #define END_DATA
128 #define BEGIN_BSS .bss
129 #define END_BSS
130 #define END
131
132 /*
133  * Following must be tailor for a particular flavor of the C compiler.
134  * They may need to put underscores in front of the symbols.
135  */
136
137 #define PUBLIC(sym) .globl SYM (sym)
138 #define EXTERN(sym) .globl SYM (sym)
139
140 #endif
Intel I386 CPU Dependent Source.
This include file defines ANSI concatenation macros.
