Scheduler configuration
The scheduler configuration allows an application to select the scheduling policy to use. More...
Collaboration diagram for Scheduler configuration:
The supported configurations are:
If no configuration is specified by the application in a uniprocessor configuration, then CONFIGURE_SCHEDULER_PRIORITY is the default.
If no configuration is specified by the application in SMP configuration, then CONFIGURE_SCHEDULER_PRIORITY_SMP is the default.
An application can define its own scheduling policy by defining CONFIGURE_SCHEDULER_USER and the following:
