19 #if !defined (_RTEMS_FLASHDISK_H_) 20 #define _RTEMS_FLASHDISK_H_ 127 #define RTEMS_FLASHDISK_DEVICE_BASE_NAME "/dev/fdd" 129 #define RTEMS_FDISK_IOCTL_ERASE_DISK _IO('B', 128) 130 #define RTEMS_FDISK_IOCTL_COMPACT _IO('B', 129) 131 #define RTEMS_FDISK_IOCTL_ERASE_USED _IO('B', 130) 132 #define RTEMS_FDISK_IOCTL_MONITORING _IO('B', 131) 133 #define RTEMS_FDISK_IOCTL_INFO_LEVEL _IO('B', 132) 134 #define RTEMS_FDISK_IOCTL_PRINT_STATUS _IO('B', 133) 143 uint32_t block_count;
144 uint32_t unavail_blocks;
145 uint32_t device_count;
146 uint32_t segment_count;
148 uint32_t blocks_used;
149 uint32_t segs_available;
151 uint32_t segs_failed;
154 uint32_t pages_active;
181 #define RTEMS_FDISK_KBYTES(_k) (UINT32_C(1024) * (_k)) 410 #define RTEMS_FDISK_BACKGROUND_ERASE (1 << 0) 415 #define RTEMS_FDISK_BACKGROUND_COMPACT (1 << 1) 422 #define RTEMS_FDISK_CHECK_PAGES (1 << 2) 428 #define RTEMS_FDISK_BLANK_CHECK_BEFORE_WRITE (1 << 3) 443 rtems_device_minor_number minor,
const rtems_fdisk_device_desc * devices
The device descriptions.
Definition: flashdisk.h:381
Number of segments.
Definition: flashdisk.h:343
uint32_t info_level
Default info level.
Definition: flashdisk.h:400
ssize_t read(int fd, void *buffer, size_t count)
POSIX 1003.1b 6.4.1 - Read From a File.
Definition: libcsupport/src/read.c:27
The number of devices.
Definition: flashdisk.h:380
rtems_device_driver rtems_fdisk_initialize(rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
Flash disk device driver initialization.
Definition: flashdisk.c:2464
RTEMS Flash Disk configuration table used to initialise the driver.
Definition: flashdisk.h:377
ssize_t write(int fd, const void *buffer, size_t count)
POSIX 1003.1b 6.4.2 - Write to a File.
Definition: libcsupport/src/write.c:30
struct rtems_fdisk_monitor_data rtems_fdisk_monitor_data
Flash Disk Monitoring Data allows a user to obtain the current status of the disk.
rtems_status_code
Classic API Status.
Definition: status.h:46
uint16_t count
Number of segments of this type in a row.
Definition: flashdisk.h:172
struct rtems_fdisk_driver_handlers rtems_fdisk_driver_handlers
Flash Low Level driver handlers.
uint32_t compact_segs
Max number of segs to compact in one pass.
Definition: flashdisk.h:391
uint32_t flags
Set of flags to control driver.
Definition: flashdisk.h:382
Number of blocks not available to the file system.
Definition: flashdisk.h:389
const rtems_fdisk_segment_desc * segments
Array of segments.
Definition: flashdisk.h:344
uint32_t offset
Address offset of base segment in device.
Definition: flashdisk.h:174
uint32_t rtems_flashdisk_configuration_size
External reference to the number of configurations.
Flash Segment Descriptor holds, number of continuous segments in the device of this type...
Definition: flashdisk.h:170
Definition: flashdisk.h:140
uint16_t segment
The base segment number.
Definition: flashdisk.h:173
uint32_t avail_compact_segs
The number of segments when compaction occurs when writing.
Definition: flashdisk.h:399
struct rtems_flashdisk_config rtems_flashdisk_config
uint32_t block_size
The block size.
Definition: flashdisk.h:379
const rtems_fdisk_driver_handlers * flash_ops
Device handlers.
Definition: flashdisk.h:345
struct rtems_fdisk_device_desc rtems_fdisk_device_desc
Flash Device Descriptor holds the segments in a device.
Definition: flashdisk.h:341
uint32_t size
Size of the segment in bytes.
Definition: flashdisk.h:175
struct rtems_fdisk_segment_desc rtems_fdisk_segment_desc
Definition: flashdisk.h:196
