FIFO/Pipe Support.
More...
#include <sys/param.h>
#include <rtems/libio_.h>
#include <rtems/rtems/barrierimpl.h>
#include "pipe.h"
#define | LIBIO_ACCMODE(_iop) ((_iop)->flags & LIBIO_FLAGS_READ_WRITE) |
#define | LIBIO_NODELAY(_iop) ((_iop)->flags & LIBIO_FLAGS_NO_DELAY) |
#define | PIPE_EMPTY(_pipe) (_pipe->Length == 0) |
#define | PIPE_FULL(_pipe) (_pipe->Length == _pipe->Size) |
#define | PIPE_SPACE(_pipe) (_pipe->Size - _pipe->Length) |
#define | PIPE_WSTART(_pipe) ((_pipe->Start + _pipe->Length) % _pipe->Size) |
#define | PIPE_LOCK(_pipe) |
#define | PIPE_UNLOCK(_pipe) rtems_semaphore_release(_pipe->Semaphore) |
#define | PIPE_READWAIT(_pipe) |
#define | PIPE_WRITEWAIT(_pipe) |
#define | PIPE_WAKEUPREADERS(_pipe) do {uint32_t n; rtems_barrier_release(_pipe->readBarrier, &n); } while(0) |
#define | PIPE_WAKEUPWRITERS(_pipe) do {uint32_t n; rtems_barrier_release(_pipe->writeBarrier, &n); } while(0) |
void | pipe_release (pipe_control_t **pipep, rtems_libio_t *iop) |
| Release a pipe. More...
int | fifo_open (pipe_control_t **pipep, rtems_libio_t *iop) |
| File system open. More...
ssize_t | pipe_read (pipe_control_t *pipe, void *buffer, size_t count, rtems_libio_t *iop) |
| File system read. More...
ssize_t | pipe_write (pipe_control_t *pipe, const void *buffer, size_t count, rtems_libio_t *iop) |
| File system write. More...
int | pipe_ioctl (pipe_control_t *pipe, ioctl_command_t cmd, void *buffer, rtems_libio_t *iop) |
| File system Input/Output control. More...
◆ PIPE_LOCK
#define PIPE_LOCK |
_pipe | ) |
Value:This is the status to indicate successful completion.
Definition: status.h:50
rtems_status_code rtems_semaphore_obtain(rtems_id id, rtems_option option_set, rtems_interval timeout)
RTEMS Obtain Semaphore.
Definition: semobtain.c:34
#define RTEMS_NO_TIMEOUT
Constant for indefinite wait.
Definition: rtems.h:170
#define RTEMS_WAIT
This option constants indicates that the task is to wait on resource.
Definition: options.h:56
◆ PIPE_READWAIT
#define PIPE_READWAIT |
_pipe | ) |
rtems_status_code rtems_barrier_wait(rtems_id id, rtems_interval timeout)
RTEMS Barrier Wait.
Definition: barrierwait.c:27
◆ PIPE_WRITEWAIT
#define PIPE_WRITEWAIT |
_pipe | ) |
RTEMS Barrier Wait.
