CPU Usage Top. More...
#include <stdbool.h>
#include <ctype.h>
#include <inttypes.h>
#include <rtems/cpuuse.h>
#include <rtems/malloc.h>
#include <rtems/score/protectedheap.h>
struct | rtems_cpu_usage_plugin |
struct | rtems_cpu_usage_data |
#define | RTEMS_TOP_SORT_ID (0) |
#define | RTEMS_TOP_SORT_REAL_PRI (1) |
#define | RTEMS_TOP_SORT_CURRENT_PRI (2) |
#define | RTEMS_TOP_SORT_TOTAL (3) |
#define | RTEMS_TOP_SORT_CURRENT (4) |
#define | RTEMS_TOP_SORT_MAX (4) |
#define | CPU_usage_Equal_to(_lhs, _rhs) _Timestamp_Equal_to( _lhs, _rhs ) |
#define | CPU_usage_Set_to_zero(_time) _Timestamp_Set_to_zero( _time ) |
#define | CPU_usage_Less_than(_lhs, _rhs) _Timestamp_Less_than( _lhs, _rhs ) |
Typedefs | |
typedef void(* | rtems_per_thread_routine_2) (Thread_Control *, void *) |
void | rtems_iterate_over_all_threads_2 (rtems_per_thread_routine_2 routine, void *arg) |
void | rtems_cpu_usage_top_with_plugin (void *context, rtems_printk_plugin_t print) |
CPU usage Top plugin. More... | |
void | rtems_cpu_usage_top (void) |
CPU usage top. More... | |
CPU Usage Top.
