#define | JFFS2_RUBINMIPS_PRIORITY 10 |
#define | JFFS2_DYNRUBIN_PRIORITY 20 |
#define | JFFS2_LZARI_PRIORITY 30 |
#define | JFFS2_RTIME_PRIORITY 50 |
#define | JFFS2_ZLIB_PRIORITY 60 |
#define | JFFS2_LZO_PRIORITY 80 |
#define | JFFS2_RUBINMIPS_DISABLED /* RUBINs will be used only */ |
#define | JFFS2_DYNRUBIN_DISABLED /* for decompression */ |
#define | JFFS2_COMPR_MODE_NONE 0 |
#define | JFFS2_COMPR_MODE_PRIORITY 1 |
#define | JFFS2_COMPR_MODE_SIZE 2 |
#define | JFFS2_COMPR_MODE_FAVOURLZO 3 |
#define | JFFS2_COMPR_MODE_FORCELZO 4 |
#define | JFFS2_COMPR_MODE_FORCEZLIB 5 |
#define | FAVOUR_LZO_PERCENT 80 |
#define | jffs2_free_comprbuf(x, y) do { } while (0) |
int | jffs2_register_compressor (struct jffs2_compressor *comp) |
int | jffs2_unregister_compressor (struct jffs2_compressor *comp) |
int | jffs2_compressors_init (void) |
int | jffs2_compressors_exit (void) |
uint16_t | jffs2_compress (struct jffs2_sb_info *c, struct jffs2_inode_info *f, unsigned char *data_in, unsigned char **cpage_out, uint32_t *datalen, uint32_t *cdatalen) |
int | jffs2_decompress (struct jffs2_sb_info *c, struct jffs2_inode_info *f, uint16_t comprtype, unsigned char *cdata_in, unsigned char *data_out, uint32_t cdatalen, uint32_t datalen) |
