#include <rtems/score/watchdog.h>#include <rtems/score/tod.h>#include <rtems/rtems/status.h>#include <rtems/rtems/types.h>#include <rtems/config.h>#include <rtems/score/timecounterimpl.h>#include <sys/time.h>
Enumerations | |
| enum | rtems_clock_get_options { RTEMS_CLOCK_GET_TOD, RTEMS_CLOCK_GET_SECONDS_SINCE_EPOCH, RTEMS_CLOCK_GET_TICKS_SINCE_BOOT, RTEMS_CLOCK_GET_TICKS_PER_SECOND, RTEMS_CLOCK_GET_TIME_VALUE } |
| List of things which can be returned by the rtems_clock_get directive. More... | |
| rtems_status_code | rtems_clock_get (rtems_clock_get_options option, void *time_buffer) |
| Obtain Current Time of Day. More... | |
| rtems_status_code | rtems_clock_get_tod (rtems_time_of_day *time_buffer) |
| Obtain Current Time of Day (Classic TOD) More... | |
| rtems_status_code | rtems_clock_get_tod_timeval (struct timeval *time) |
| Obtain TOD in struct timeval Format. More... | |
| rtems_status_code | rtems_clock_get_seconds_since_epoch (rtems_interval *the_interval) |
| Obtain Seconds Since Epoch. More... | |
| RTEMS_INLINE_ROUTINE rtems_interval | rtems_clock_get_ticks_since_boot (void) |
| Gets the current ticks counter value. More... | |
| RTEMS_INLINE_ROUTINE rtems_interval | rtems_clock_tick_later (rtems_interval delta) |
| Returns the ticks counter value delta ticks in the future. More... | |
| RTEMS_INLINE_ROUTINE rtems_interval | rtems_clock_tick_later_usec (rtems_interval delta_in_usec) |
| Returns the ticks counter value at least delta microseconds in the future. More... | |
| RTEMS_INLINE_ROUTINE bool | rtems_clock_tick_before (rtems_interval tick) |
| Returns true if the current ticks counter value indicates a time before the time specified by the tick value and false otherwise. More... | |
| rtems_interval | rtems_clock_get_ticks_per_second (void) |
| Obtain Ticks Per Seconds. More... | |
| rtems_status_code | rtems_clock_set (const rtems_time_of_day *time_buffer) |
| Set the Current TOD. More... | |
| rtems_status_code | rtems_clock_tick (void) |
| Announce a Clock Tick. More... | |
| rtems_status_code | rtems_clock_get_uptime (struct timespec *uptime) |
| Obtain the System Uptime. More... | |
| void | rtems_clock_get_uptime_timeval (struct timeval *uptime) |
| Gets the System Uptime in the Struct Timeval Format. More... | |
| RTEMS_INLINE_ROUTINE time_t | rtems_clock_get_uptime_seconds (void) |
| Returns the system uptime in seconds. More... | |
| uint64_t | rtems_clock_get_uptime_nanoseconds (void) |
| Returns the system uptime in nanoseconds. More... | |
| bool | _TOD_Validate (const rtems_time_of_day *the_tod) |
| TOD Validate. More... | |
| Watchdog_Interval | _TOD_To_seconds (const rtems_time_of_day *the_tod) |
| TOD to Seconds. More... | |
