18 #ifndef _RTEMS_SCORE_APIEXT_H 19 #define _RTEMS_SCORE_APIEXT_H 42 #if defined(FUNCTIONALITY_NOT_CURRENTLY_USED_BY_ANY_API) 46 typedef void (*API_extensions_Predriver_hook)(void);
61 #if defined(FUNCTIONALITY_NOT_CURRENTLY_USED_BY_ANY_API) 69 API_extensions_Predriver_hook predriver_hook;
104 #if defined(FUNCTIONALITY_NOT_CURRENTLY_USED_BY_ANY_API) 110 void _API_extensions_Run_predriver(
void );
This is used to manage each element (node) which is placed on a chain.
Definition: score/include/rtems/score/chain.h:65
SCORE_EXTERN Chain_Control _API_extensions_List
This is the list of API extensions to the system initialization.
Definition: apiext.h:84
API_extensions_Postdriver_hook postdriver_hook
This field is the callout invoked during RTEMS initialization after RTEMS data structures and device ...
Definition: apiext.h:78
The control structure which defines the points at which an API can add an extension to the system ini...
Definition: apiext.h:58
This is used to manage a chain.
Definition: score/include/rtems/score/chain.h:83
Constants and Structures Related with the Thread Control Block.
void _API_extensions_Run_postdriver(void)
Execute all post-driver extensions.
Definition: apiext.c:56
void _API_extensions_Initialization(void)
Initialize the API extensions handler.
Definition: apiext.c:25
void _API_extensions_Add(API_extensions_Control *the_extension)
Add extension set to the active set.
Definition: apiext.c:30
Chain_Node Node
This field allows this structure to be used with the Chain Handler.
Definition: apiext.h:60
void(* API_extensions_Postdriver_hook)(void)
This type defines the prototype of the Postdriver Hook.
Definition: apiext.h:52
#define SCORE_EXTERN
The following ensures that all data is declared in the space of the initialization routine for either...
Definition: basedefs.h:81
