#define | BOOL_DEFINED |
#define | YPPROG ((u_long)100004) |
#define | YPVERS ((u_long)2) |
#define | YPVERS_ORIG ((u_long)1) |
#define | YPMAXRECORD ((u_long)1024) |
#define | YPMAXDOMAIN ((u_long)64) |
#define | YPMAXMAP ((u_long)64) |
#define | YPMAXPEER ((u_long)256) |
#define | YPMSGSZ 1600 |
#define | DATUM |
#define | ypxfr_domain map_parms.domain |
#define | ypxfr_map map_parms.map |
#define | ypxfr_ordernum map_parms.ordernum |
#define | ypxfr_owner map_parms.owner |
#define | YPPROC_NULL ((u_long)0) |
#define | YPPROC_DOMAIN ((u_long)1) |
#define | YPPROC_DOMAIN_NONACK ((u_long)2) |
#define | YPPROC_MATCH ((u_long)3) |
#define | YPPROC_FIRST ((u_long)4) |
#define | YPPROC_NEXT ((u_long)5) |
#define | YPPROC_XFR ((u_long)6) |
#define | YPPROC_CLEAR ((u_long)7) |
#define | YPPROC_ALL ((u_long)8) |
#define | YPPROC_MASTER ((u_long)9) |
#define | YPPROC_ORDER ((u_long)10) |
#define | YPPROC_MAPLIST ((u_long)11) |
#define | YP_TRUE ((long)1) /* general purpose success code */ |
#define | YP_NOMORE ((long)2) /* no more entries in map */ |
#define | YP_FALSE ((long)0) /* general purpose failure code */ |
#define | YP_NOMAP ((long)-1) /* no such map in domain */ |
#define | YP_NODOM ((long)-2) /* domain not supported */ |
#define | YP_NOKEY ((long)-3) /* no such key in map */ |
#define | YP_BADOP ((long)-4) /* invalid operation */ |
#define | YP_BADDB ((long)-5) /* server data base is bad */ |
#define | YP_YPERR ((long)-6) /* YP server error */ |
#define | YP_BADARGS ((long)-7) /* request arguments bad */ |
#define | YP_VERS ((long)-8) /* YP server version mismatch */ |
#define | YPBINDPROG ((u_long)100007) |
#define | YPBINDVERS ((u_long)2) |
#define | YPBINDVERS_ORIG ((u_long)1) |
#define | YPBINDPROC_NULL ((u_long)0) |
#define | YPBINDPROC_DOMAIN ((u_long)1) |
#define | YPBINDPROC_SETDOM ((u_long)2) |
#define | YPBIND_ERR_ERR 1 /* internal error */ |
#define | YPBIND_ERR_NOSERV 2 /* no bound server for passed domain */ |
#define | YPBIND_ERR_RESC 3 /* system resource allocation failure */ |
#define | ypsetdom_addr ypsetdom_binding.ypbind_binding_addr |
#define | ypsetdom_port ypsetdom_binding.ypbind_binding_port |
#define | YPPUSHVERS ((u_long)1) |
#define | YPPUSHVERS_ORIG ((u_long)1) |
#define | YPPUSHPROC_NULL ((u_long)0) |
#define | YPPUSHPROC_XFRRESP ((u_long)1) |
#define | YPPUSH_SUCC ((long)1) /* Success */ |
#define | YPPUSH_AGE ((long)2) /* Master's version not newer */ |
#define | YPPUSH_NOMAP ((long)-1) /* Can't find server for map */ |
#define | YPPUSH_NODOM ((long)-2) /* Domain not supported */ |
#define | YPPUSH_RSRC ((long)-3) /* Local resource alloc failure */ |
#define | YPPUSH_RPC ((long)-4) /* RPC failure talking to server */ |
#define | YPPUSH_MADDR ((long)-5) /* Can't get master address */ |
#define | YPPUSH_YPERR ((long)-6) /* YP server/map db error */ |
#define | YPPUSH_BADARGS ((long)-7) /* Request arguments bad */ |
#define | YPPUSH_DBM ((long)-8) /* Local dbm operation failed */ |
#define | YPPUSH_FILE ((long)-9) /* Local file I/O operation failed */ |
#define | YPPUSH_SKEW ((long)-10) /* Map version skew during transfer */ |
#define | YPPUSH_CLEAR ((long)-11) /* Can't send "Clear" req to local ypserv */ |
#define | YPPUSH_FORCE ((long)-12) /* No local order number in map - use -f */ |
#define | YPPUSH_XFRERR ((long)-13) /* ypxfr error */ |
#define | YPPUSH_REFUSED ((long)-14) /* Transfer request refused by ypserv */ |
