rtems-4.11.3
libmisc
shell
vis.h
1
/* $NetBSD: vis.h,v 1.16 2005/09/13 01:44:32 christos Exp $ */
2
3
4
* Copyright (c) 1990, 1993
5
* The Regents of the University of California. All rights reserved.
6
7
8
* modification, are permitted provided that the following conditions
9
* are met:
10
* 1. Redistributions of source code must retain the above copyright
11
* notice, this list of conditions and the following disclaimer.
12
* 2. Redistributions in binary form must reproduce the above copyright
13
* notice, this list of conditions and the following disclaimer in the
14
* documentation and/or other materials provided with the distribution.
15
* 3. Neither the name of the University nor the names of its contributors
16
* may be used to endorse or promote products derived from this software
17
* without specific prior written permission.
18
19
* THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
20
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
21
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
22
* ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
23
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
24
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
25
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
26
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
27
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
28
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
29
* SUCH DAMAGE.
30
31
* @(#)vis.h 8.1 (Berkeley) 6/2/93
32
33
34
#ifndef _VIS_H_
35
#define _VIS_H_
36
37
#include <sys/types.h>
38
39
40
* to select alternate encoding format
41
42
#define VIS_OCTAL 0x01
/* use octal \ddd format */
43
#define VIS_CSTYLE 0x02
/* use \[nrft0..] where appropiate */
44
45
46
* to alter set of characters encoded (default is to encode all
47
* non-graphic except space, tab, and newline).
48
49
#define VIS_SP 0x04
/* also encode space */
50
#define VIS_TAB 0x08
/* also encode tab */
51
#define VIS_NL 0x10
/* also encode newline */
52
#define VIS_WHITE (VIS_SP | VIS_TAB | VIS_NL)
53
#define VIS_SAFE 0x20
/* only encode "unsafe" characters */
54
55
56
* other
57
58
#define VIS_NOSLASH 0x40
/* inhibit printing '\' */
59
#define VIS_HTTPSTYLE 0x80
/* http-style escape % HEX HEX */
60
61
62
* unvis return codes
63
64
#define UNVIS_VALID 1
/* character valid */
65
#define UNVIS_VALIDPUSH 2
/* character valid, push back passed char */
66
#define UNVIS_NOCHAR 3
/* valid sequence, no character produced */
67
#define UNVIS_SYNBAD -1
/* unrecognized escape sequence */
68
#define UNVIS_ERROR -2
/* decoder in unknown state (unrecoverable) */
69
70
71
* unvis flags
72
73
#define UNVIS_END 1
/* no more characters */
74
75
#include <sys/cdefs.h>
76
77
__BEGIN_DECLS
78
char
*vis(
char
int
int
int
79
char
*svis(
char
int
int
int
const
char
80
int
strvis(
char
const
char
int
81
int
strsvis(
char
const
char
int
const
char
82
int
strvisx(
char
const
char
size_t
int
83
int
strsvisx(
char
const
char
size_t
int
const
char
84
int
strunvis(
char
const
char
85
int
strunvisx(
char
const
char
int
86
#ifndef __LIBC12_SOURCE__
87
//int unvis(char *, int, int *, int) __RENAME(__unvis13);
88
#endif
89
__END_DECLS
90
91
#endif
/* !_VIS_H_ */
