rtems-4.11.3
score
cpu
m32c
varvects.h
1
10
11
* Copyright (c) 2008 Red Hat Incorporated.
12
* All rights reserved.
13
14
15
* modification, are permitted provided that the following conditions are met:
16
17
* Redistributions of source code must retain the above copyright
18
* notice, this list of conditions and the following disclaimer.
19
20
* Redistributions in binary form must reproduce the above copyright
21
* notice, this list of conditions and the following disclaimer in the
22
* documentation and/or other materials provided with the distribution.
23
24
* The name of Red Hat Incorporated may not be used to endorse
25
* or promote products derived from this software without specific
26
* prior written permission.
27
28
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
29
* * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
30
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
31
* DISCLAIMED. IN NO EVENT SHALL RED HAT INCORPORATED BE LIABLE FOR ANY
32
* DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
33
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
34
* LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
35
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
36
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
37
* SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
38
39
40
#ifndef _VARVECTS_H_
41
#define _VARVECTS_H_
42
43
typedef
void (*_m32c_interrupt_func)(void) __attribute__((mode(SI)));
44
extern
_m32c_interrupt_func _var_vects[];
45
46
#if defined(__r8c_cpu__) || defined (__m16c_cpu__)
47
48
#define _set_var_vect(f,n) \
49
{ __asm__ ("mov.w #%%lo16(%d0),__var_vects+%d1" : : "s" (f), "g" (n*4)); \
50
__asm__ ("mov.w #%%hi16(%d0),__var_vects+%d1" : : "s" (f), "g" (n*4+2)); }
51
52
#else
53
54
55
_var_vects[n] = f
56
57
#endif
58
#endif
