elf_machdep.h File Reference
#define ELF32_MACHDEP_ENDIANNESS   ELFDATA2LSB
#define ELF32_MACHDEP_ID_CASES
#define ELF32_MACHDEP_ID   EM_V850
#define EF_V850_ARCH   0xf0000000
#define E_V850_ARCH   0x00000000
#define E_V850E_ARCH   0x10000000
#define E_V850E1_ARCH   0x20000000
#define E_V850E2_ARCH   0x30000000
#define E_V850E2V3_ARCH   0x40000000
#define ARCH_ELFSIZE   32
#define R_V850_NONE   0
#define R_V850_9_PCREL   1
#define R_V850_22_PCREL   2
#define R_V850_HI16_S   3
#define R_V850_HI16   4
#define R_V850_LO16   5
#define R_V850_ABS32   6
#define R_V850_16   7
#define R_V850_8   8
#define R_V850_SDA_16_16_OFFSET   9
#define R_V850_SDA_15_16_OFFSET   10
#define R_V850_ZDA_16_16_OFFSET   11
#define R_V850_ZDA_15_16_OFFSET   12
#define R_V850_TDA_6_8_OFFSET   13
#define R_V850_TDA_7_8_OFFSET   14
#define R_V850_TDA_7_7_OFFSET   15
#define R_V850_TDA_16_16_OFFSET   16
#define R_V850_TDA_4_5_OFFSET   17
#define R_V850_TDA_4_4_OFFSET   18
#define R_V850_SDA_16_16_SPLIT_OFFSET   19
#define R_V850_ZDA_16_16_SPLIT_OFFSET   20
#define R_V850_CALLT_6_7_OFFSET   21
#define R_V850_CALLT_16_16_OFFSET   22
#define R_V850_GNU_VTINHERIT   23
#define R_V850_GNU_VTENTRY   24
#define R_V850_LONGCALL   25
#define R_V850_LONGJUMP   26
#define R_V850_ALIGN   27
#define R_V850_REL32   28
#define R_V850_LO16_SPLIT_OFFSET   29
#define R_V850_16_PCREL   30
#define R_V850_17_PCREL   31
#define R_V850_23   32
#define R_V850_32_PCREL   33
#define R_V850_32_ABS   34
#define R_V850_16_SPLIT_OFFSET   35
#define R_V850_16_S1   36
#define R_V850_LO16_S1   37
#define R_V850_CALLT_15_16_OFFSET   38
#define R_V850_32_GOTPCREL   39
#define R_V850_16_GOT   40
#define R_V850_32_GOT   41
#define R_V850_22_PLT   42
#define R_V850_32_PLT   43
#define R_V850_COPY   44
#define R_V850_GLOB_DAT   45
#define R_V850_JMP_SLOT   46
#define R_V850_RELATIVE   47
#define R_V850_16_GOTOFF   48
#define R_V850_32_GOTOFF   49
#define R_V850_CODE   50
#define R_V850_DATA   51
#define R_TYPE(name)   __CONCAT(R_V850_,name)
◆ ELF32_MACHDEP_ID_CASES
Value:
case EM_V850: \
break;
