rtems-4.11.3
score
include
sys
timex.h
1
2
3
4
* Copyright (c) David L. Mills 1993-2001 *
5
* Copyright (c) Poul-Henning Kamp 2000-2001 *
6
7
* Permission to use, copy, modify, and distribute this software and *
8
* its documentation for any purpose and without fee is hereby *
9
* granted, provided that the above copyright notice appears in all *
10
* copies and that both the copyright notice and this permission *
11
* notice appear in supporting documentation, and that the name *
12
* University of Delaware not be used in advertising or publicity *
13
* pertaining to distribution of the software without specific, *
14
* written prior permission. The University of Delaware makes no *
15
* representations about the suitability this software for any *
16
* purpose. It is provided "as is" without express or implied *
17
* warranty. *
18
19
20
21
* $FreeBSD r277406 2015-01-20T03:54:30Z$
22
23
* This header file defines the Network Time Protocol (NTP) interfaces
24
* for user and daemon application programs.
25
26
* This file was originally created 17 Sep 93 by David L. Mills, Professor
27
* of University of Delaware, building on work which had already been ongoing
28
* for a decade and a half at that point in time.
29
30
* In 2000 the APIs got a upgrade from microseconds to nanoseconds,
31
* a joint work between Poul-Henning Kamp and David L. Mills.
32
33
34
35
#ifndef _SYS_TIMEX_H_
36
#define _SYS_TIMEX_H_ 1
37
38
#define NTP_API 4
/* NTP API version */
39
40
#ifdef __FreeBSD__
41
#include <sys/_timespec.h>
42
#endif
/* __FreeBSD__ */
43
44
45
* The following defines establish the performance envelope of the
46
* kernel discipline loop. Phase or frequency errors greater than
47
* NAXPHASE or MAXFREQ are clamped to these maxima. For update intervals
48
* less than MINSEC, the loop always operates in PLL mode; while, for
49
* update intervals greater than MAXSEC, the loop always operates in FLL
50
* mode. Between these two limits the operating mode is selected by the
51
* STA_FLL bit in the status word.
52
53
54
#define MAXPHASE 500000000L
/* max phase error (ns) */
55
#define MAXFREQ 500000L
/* max freq error (ns/s) */
56
#define MINSEC 256
/* min FLL update interval (s) */
57
#define MAXSEC 2048
/* max PLL update interval (s) */
58
#define NANOSECOND 1000000000L
/* nanoseconds in one second */
59
#define SCALE_PPM (65536 / 1000)
/* crude ns/s to scaled PPM */
60
#define MAXTC 10
/* max time constant */
61
62
63
* Control mode codes (timex.modes)
64
65
#define MOD_OFFSET 0x0001
/* set time offset */
66
#define MOD_FREQUENCY 0x0002
/* set frequency offset */
67
#define MOD_MAXERROR 0x0004
/* set maximum time error */
68
#define MOD_ESTERROR 0x0008
/* set estimated time error */
69
#define MOD_STATUS 0x0010
/* set clock status bits */
70
#define MOD_TIMECONST 0x0020
/* set PLL time constant */
71
#define MOD_PPSMAX 0x0040
/* set PPS maximum averaging time */
72
#define MOD_TAI 0x0080
/* set TAI offset */
73
#define MOD_MICRO 0x1000
/* select microsecond resolution */
74
#define MOD_NANO 0x2000
/* select nanosecond resolution */
75
#define MOD_CLKB 0x4000
/* select clock B */
76
#define MOD_CLKA 0x8000
/* select clock A */
77
78
79
* Status codes (timex.status)
80
81
#define STA_PLL 0x0001
/* enable PLL updates (rw) */
82
#define STA_PPSFREQ 0x0002
/* enable PPS freq discipline (rw) */
83
#define STA_PPSTIME 0x0004
/* enable PPS time discipline (rw) */
84
#define STA_FLL 0x0008
/* enable FLL mode (rw) */
85
#define STA_INS 0x0010
/* insert leap (rw) */
86
#define STA_DEL 0x0020
/* delete leap (rw) */
87
#define STA_UNSYNC 0x0040
/* clock unsynchronized (rw) */
88
#define STA_FREQHOLD 0x0080
/* hold frequency (rw) */
89
#define STA_PPSSIGNAL 0x0100
/* PPS signal present (ro) */
90
#define STA_PPSJITTER 0x0200
/* PPS signal jitter exceeded (ro) */
91
#define STA_PPSWANDER 0x0400
/* PPS signal wander exceeded (ro) */
92
#define STA_PPSERROR 0x0800
/* PPS signal calibration error (ro) */
93
#define STA_CLOCKERR 0x1000
/* clock hardware fault (ro) */
94
#define STA_NANO 0x2000
/* resolution (0 = us, 1 = ns) (ro) */
95
#define STA_MODE 0x4000
/* mode (0 = PLL, 1 = FLL) (ro) */
96
#define STA_CLK 0x8000
/* clock source (0 = A, 1 = B) (ro) */
97
98
#define STA_RONLY (STA_PPSSIGNAL | STA_PPSJITTER | STA_PPSWANDER | \
99
STA_PPSERROR | STA_CLOCKERR | STA_NANO | STA_MODE | STA_CLK)
100
101
102
* Clock states (ntptimeval.time_state)
103
104
#define TIME_OK 0
/* no leap second warning */
105
#define TIME_INS 1
/* insert leap second warning */
106
#define TIME_DEL 2
/* delete leap second warning */
107
#define TIME_OOP 3
/* leap second in progress */
108
#define TIME_WAIT 4
/* leap second has occured */
109
#define TIME_ERROR 5
/* error (see status word) */
110
111
112
* NTP user interface -- ntp_gettime(2) - used to read kernel clock values
113
114
struct
ntptimeval
115
struct
timespec time;
/* current time (ns) (ro) */
116
long
maxerror;
/* maximum error (us) (ro) */
117
long
esterror;
/* estimated error (us) (ro) */
118
long
tai;
/* TAI offset */
119
int
time_state;
/* time status */
120
121
122
123
* NTP daemon interface -- ntp_adjtime(2) -- used to discipline CPU clock
124
* oscillator and control/determine status.
125
126
* Note: The offset, precision and jitter members are in microseconds if
127
* STA_NANO is zero and nanoseconds if not.
128
129
struct
timex
130
unsigned
int
modes;
/* clock mode bits (wo) */
131
long
offset;
/* time offset (ns/us) (rw) */
132
long
freq;
/* frequency offset (scaled PPM) (rw) */
133
long
maxerror;
/* maximum error (us) (rw) */
134
long
esterror;
/* estimated error (us) (rw) */
135
int
status;
/* clock status bits (rw) */
136
long
constant;
/* poll interval (log2 s) (rw) */
137
long
precision;
/* clock precision (ns/us) (ro) */
138
long
tolerance;
/* clock frequency tolerance (scaled
139
* PPM) (ro) */
140
141
* The following read-only structure members are implemented
142
* only if the PPS signal discipline is configured in the
143
* kernel. They are included in all configurations to insure
144
* portability.
145
146
long
ppsfreq;
/* PPS frequency (scaled PPM) (ro) */
147
long
jitter;
/* PPS jitter (ns/us) (ro) */
148
int
shift;
/* interval duration (s) (shift) (ro) */
149
long
stabil;
/* PPS stability (scaled PPM) (ro) */
150
long
jitcnt;
/* jitter limit exceeded (ro) */
151
long
calcnt;
/* calibration intervals (ro) */
152
long
errcnt;
/* calibration errors (ro) */
153
long
stbcnt;
/* stability limit exceeded (ro) */
154
155
156
#ifdef __FreeBSD__
157
158
#ifdef _KERNEL
159
void
ntp_update_second(int64_t *adjustment, time_t *newsec);
160
#else
/* !_KERNEL */
161
#include <sys/cdefs.h>
162
163
__BEGIN_DECLS
164
int
ntp_adjtime(
struct
timex
165
int
ntp_gettime(
struct
ntptimeval
166
__END_DECLS
167
#endif
/* _KERNEL */
168
169
#endif
/* __FreeBSD__ */
170
171
#endif
/* !_SYS_TIMEX_H_ */
ntptimeval
Definition:
timex.h:115
timex
Definition:
timex.h:130
