rtems-4.11.3
libnetworking
netinet
tcp_seq.h
1
2
* Copyright (c) 1982, 1986, 1993, 1995
3
* The Regents of the University of California. All rights reserved.
4
5
6
* modification, are permitted provided that the following conditions
7
* are met:
8
* 1. Redistributions of source code must retain the above copyright
9
* notice, this list of conditions and the following disclaimer.
10
* 2. Redistributions in binary form must reproduce the above copyright
11
* notice, this list of conditions and the following disclaimer in the
12
* documentation and/or other materials provided with the distribution.
13
* 4. Neither the name of the University nor the names of its contributors
14
* may be used to endorse or promote products derived from this software
15
* without specific prior written permission.
16
17
* THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
18
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
19
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20
* ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
21
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
22
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
23
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
24
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
25
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
26
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
27
* SUCH DAMAGE.
28
29
* @(#)tcp_seq.h 8.3 (Berkeley) 6/21/95
30
* $FreeBSD: src/sys/netinet/tcp_seq.h,v 1.26 2006/06/18 14:24:12 andre Exp $
31
32
33
34
#ifndef _NETINET_TCP_SEQ_H_
35
#define _NETINET_TCP_SEQ_H_
36
37
* TCP sequence numbers are 32 bit integers operated
38
* on with modular arithmetic. These macros can be
39
* used to compare such integers.
40
41
#define SEQ_LT(a,b) ((int)((a)-(b)) < 0)
42
#define SEQ_LEQ(a,b) ((int)((a)-(b)) <= 0)
43
#define SEQ_GT(a,b) ((int)((a)-(b)) > 0)
44
#define SEQ_GEQ(a,b) ((int)((a)-(b)) >= 0)
45
46
/* for modulo comparisons of timestamps */
47
#define TSTMP_LT(a,b) ((int)((a)-(b)) < 0)
48
#define TSTMP_GEQ(a,b) ((int)((a)-(b)) >= 0)
49
50
51
* TCP connection counts are 32 bit integers operated
52
53
54
55
#define CC_LT(a,b) ((int)((a)-(b)) < 0)
56
#define CC_LEQ(a,b) ((int)((a)-(b)) <= 0)
57
#define CC_GT(a,b) ((int)((a)-(b)) > 0)
58
#define CC_GEQ(a,b) ((int)((a)-(b)) >= 0)
59
60
/* Macro to increment a CC: skip 0 which has a special meaning */
61
#define CC_INC(c) (++(c) == 0 ? ++(c) : (c))
62
63
64
* Macros to initialize tcp sequence numbers for
65
* send and receive from initial send and receive
66
* sequence numbers.
67
68
#define tcp_rcvseqinit(tp) \
69
(tp)->rcv_adv = (tp)->rcv_nxt = (tp)->irs + 1
70
71
#define tcp_sendseqinit(tp) \
72
(tp)->snd_una = (tp)->snd_nxt = (tp)->snd_max = (tp)->snd_up = \
73
(tp)->iss
74
75
#define TCP_PAWS_IDLE (uint32_t)(24L * 24L * 60L * 60L * PR_SLOWHZ)
76
/* timestamp wrap-around time */
77
78
#ifdef _KERNEL
79
extern
tcp_cc tcp_ccgen;
/* global connection count */
80
81
82
* Increment for tcp_iss each second.
83
* This is designed to increment at the standard 250 KB/s,
84
* but with a random component averaging 128 KB.
85
* We also increment tcp_iss by a quarter of this amount
86
* each time we use the value for a new connection.
87
* If defined, the tcp_random18() macro should produce a
88
* number in the range [0-0x3ffff] that is hard to predict.
89
90
#ifndef tcp_random18
91
#define tcp_random18() (((uint32_t)random() >> 14) & 0x3ffffL)
92
#endif
93
#define TCP_ISSINCR (uint32_t)(122L*1024L + tcp_random18())
94
95
extern
tcp_seq tcp_iss;
/* tcp initial send seq # */
96
#else
97
#define TCP_ISSINCR (250*1024)
/* increment for tcp_iss each second */
98
#endif
/* _KERNEL */
99
#endif
/* _NETINET_TCP_SEQ_H_ */
