Information About the Thread Stack Handler. More...
| struct | Stack_Control |
| The following defines the control block used to manage each stack. More... | |
| #define | STACK_MINIMUM_SIZE CPU_STACK_MINIMUM_SIZE |
| The following constant defines the minimum stack size which every thread must exceed. | |
| uint32_t | rtems_minimum_stack_size |
| This variable contains the the minimum stack size;. More... | |
This include file contains all information about the thread Stack Handler. This Handler provides mechanisms which can be used to initialize and utilize stacks.
