12 #ifndef _JFFS2_FS_XATTR_H_ 13 #define _JFFS2_FS_XATTR_H_ 18 #define JFFS2_XFLAGS_HOT (0x01) 19 #define JFFS2_XFLAGS_BIND (0x02) 20 #define JFFS2_XFLAGS_DEAD (0x40) 21 #define JFFS2_XFLAGS_INVALID (0x80) 65 #define XREF_DELETE_MARKER (0x00000001) 68 return ((ref->xseqno & XREF_DELETE_MARKER) != 0);
71 #ifdef CONFIG_JFFS2_FS_XATTR 73 extern void jffs2_init_xattr_subsystem(
struct jffs2_sb_info *c);
74 extern void jffs2_build_xattr_subsystem(
75 extern void jffs2_clear_xattr_subsystem(
78 uint32_t xid, uint32_t version);
92 extern int do_jffs2_getxattr(
struct inode *inode,
int xprefix,
const char *xname,
93 char *buffer,
size_t size);
94 extern int do_jffs2_setxattr(
int xprefix,
const char *xname,
95 const char *buffer,
size_t size,
int flags);
97 extern const struct xattr_handler *jffs2_xattr_handlers[];
98 extern const struct xattr_handler jffs2_user_xattr_handler;
99 extern const struct xattr_handler jffs2_trusted_xattr_handler;
101 extern ssize_t jffs2_listxattr(
struct dentry *,
char *,
size_t);
102 #define jffs2_getxattr generic_getxattr 103 #define jffs2_setxattr generic_setxattr 104 #define jffs2_removexattr generic_removexattr 108 #define jffs2_init_xattr_subsystem(c) 109 #define jffs2_build_xattr_subsystem(c) 110 #define jffs2_clear_xattr_subsystem(c) 112 #define jffs2_xattr_do_crccheck_inode(c, ic) 113 #define jffs2_xattr_delete_inode(c, ic) 114 #define jffs2_xattr_free_inode(c, ic) 115 #define jffs2_verify_xattr(c) (1) 117 #define jffs2_xattr_handlers NULL 118 #define jffs2_listxattr NULL 119 #define jffs2_getxattr NULL 120 #define jffs2_setxattr NULL 121 #define jffs2_removexattr NULL 125 #ifdef CONFIG_JFFS2_FS_SECURITY 126 extern int jffs2_init_security(
struct inode *dir,
127 const struct qstr *qstr);
128 extern const struct xattr_handler jffs2_security_xattr_handler;
130 #define jffs2_init_security(inode,dir,qstr) (0) Definition: nodelist.h:83
Definition: nodelist.h:159
Definition: jffs2_fs_sb.h:49
