rtems-4.11.3
score
cpu
sparc64
asm.h
1
17
18
* COPYRIGHT:
19
20
* This file is based on similar code found in newlib available
21
* from ftp.cygnus.com. The file which was used had no copyright
22
* notice. This file is freely distributable as long as the source
23
* of the file is noted.
24
25
26
#ifndef _RTEMS_ASM_H
27
#define _RTEMS_ASM_H
28
29
30
* Indicate we are in an assembly file and get the basic CPU definitions.
31
32
33
#ifndef ASM
34
#define ASM
35
#endif
36
#ifndef __ASM__
37
#define __ASM__
38
#endif
39
40
41
#include <rtems/score/cpu.h>
42
43
44
* Recent versions of GNU cpp define variables which indicate the
45
* need for underscores and percents. If not using GNU cpp or
46
* the version does not support this, then you will obviously
47
* have to define these as appropriate.
48
49
50
/* XXX __USER_LABEL_PREFIX__ and __REGISTER_PREFIX__ do not work on gcc 2.7.0 */
51
/* XXX The following ifdef magic fixes the problem but results in a warning */
52
/* XXX when compiling assembly code. */
53
54
#ifndef __USER_LABEL_PREFIX__
55
#define __USER_LABEL_PREFIX__ _
56
#endif
57
58
#ifndef __REGISTER_PREFIX__
59
#define __REGISTER_PREFIX__
60
#endif
61
62
rtems/concat.h
63
64
/* Use the right prefix for global labels. */
65
66
#define SYM(x) CONCAT1 (__USER_LABEL_PREFIX__, x)
67
68
/* Use the right prefix for registers. */
69
70
#define REG(x) CONCAT1 (__REGISTER_PREFIX__, x)
71
72
73
* define macros for all of the registers on this CPU
74
75
* EXAMPLE: #define d0 REG (d0)
76
77
78
79
* Define macros to handle section beginning and ends.
80
81
82
83
#define BEGIN_CODE_DCL .text
84
#define END_CODE_DCL
85
#define BEGIN_DATA_DCL .data
86
#define END_DATA_DCL
87
#define BEGIN_CODE .text
88
#define END_CODE
89
#define BEGIN_DATA
90
#define END_DATA
91
#define BEGIN_BSS
92
#define END_BSS
93
#define END
94
95
96
* Following must be tailor for a particular flavor of the C compiler.
97
* They may need to put underscores in front of the symbols.
98
99
100
#define PUBLIC(sym) .globl SYM (sym)
101
#define EXTERN(sym) .globl SYM (sym)
102
103
#endif
concat.h
This include file defines ANSI concatenation macros.
