42 #define _AVR_SLEEP_H_ 1 145 #if defined(SLEEP_CTRL) 148 #define _SLEEP_CONTROL_REG SLEEP_CTRL 149 #define _SLEEP_ENABLE_MASK SLEEP_SEN_bm 153 #define _SLEEP_CONTROL_REG SMCR 154 #define _SLEEP_ENABLE_MASK _BV(SE) 156 #elif defined(__AVR_AT94K__) 158 #define _SLEEP_CONTROL_REG MCUR 159 #define _SLEEP_ENABLE_MASK _BV(SE) 163 #define _SLEEP_CONTROL_REG MCUCR 164 #define _SLEEP_ENABLE_MASK _BV(SE) 170 #if defined(__AVR_ATmega161__) 172 #define SLEEP_MODE_IDLE 0 173 #define SLEEP_MODE_PWR_DOWN 1 174 #define SLEEP_MODE_PWR_SAVE 2 176 #define set_sleep_mode(mode) \ 178 MCUCR = ((MCUCR & ~_BV(SM1)) | \ 179 ((mode) == SLEEP_MODE_PWR_DOWN || \ 180 (mode) == SLEEP_MODE_PWR_SAVE ? _BV(SM1) : 0)); \ 181 EMCUCR = ((EMCUCR & ~_BV(SM0)) | \ 182 ((mode) == SLEEP_MODE_PWR_SAVE ? _BV(SM0) : 0)); \ 186 #elif defined(__AVR_ATmega162__) \ 187 || defined(__AVR_ATmega8515__) 189 #define SLEEP_MODE_IDLE 0 190 #define SLEEP_MODE_PWR_DOWN 1 191 #define SLEEP_MODE_PWR_SAVE 2 192 #define SLEEP_MODE_ADC 3 193 #define SLEEP_MODE_STANDBY 4 194 #define SLEEP_MODE_EXT_STANDBY 5 196 #define set_sleep_mode(mode) \ 198 MCUCR = ((MCUCR & ~_BV(SM1)) | \ 199 ((mode) == SLEEP_MODE_IDLE ? 0 : _BV(SM1))); \ 200 MCUCSR = ((MCUCSR & ~_BV(SM2)) | ((mode) == SLEEP_MODE_STANDBY || \ 201 (mode) == SLEEP_MODE_EXT_STANDBY ? _BV(SM2) : 0)); \ 202 EMCUCR = ((EMCUCR & ~_BV(SM0)) | ((mode) == SLEEP_MODE_PWR_SAVE || \ 203 (mode) == SLEEP_MODE_EXT_STANDBY ? _BV(SM0) : 0)); \ 206 #elif defined(__AVR_AT90S2313__) \ 207 || defined(__AVR_AT90S2323__) \ 208 || defined(__AVR_AT90S2333__) \ 209 || defined(__AVR_AT90S2343__) \ 210 || defined(__AVR_AT43USB320__) \ 211 || defined(__AVR_AT43USB355__) \ 212 || defined(__AVR_AT90S4414__) \ 213 || defined(__AVR_AT90S4433__) \ 214 || defined(__AVR_AT90S8515__) \ 215 || defined(__AVR_ATtiny22__) 217 #define SLEEP_MODE_IDLE 0 218 #define SLEEP_MODE_PWR_DOWN _BV(SM) 220 #define set_sleep_mode(mode) \ 222 _SLEEP_CONTROL_REG = ((_SLEEP_CONTROL_REG & ~__BV(SM)) | (mode)); \ 225 #elif defined(__AVR_ATtiny167__) \ 226 || defined(__AVR_ATtiny87__) 228 #define SLEEP_MODE_IDLE 0 229 #define SLEEP_MODE_ADC _BV(SM0) 230 #define SLEEP_MODE_PWR_DOWN _BV(SM1) 232 #define set_sleep_mode(mode) \ 234 _SLEEP_CONTROL_REG = ((_SLEEP_CONTROL_REG & \ 235 ~(_BV(SM0) | _BV(SM1))) | (mode)); \ 238 #elif defined(__AVR_AT90S4434__) \ 239 || defined(__AVR_AT76C711__) \ 240 || defined(__AVR_AT90S8535__) \ 241 || defined(__AVR_ATmega103__) \ 242 || defined(__AVR_ATmega161__) \ 243 || defined(__AVR_ATmega163__) \ 244 || defined(__AVR_ATtiny13__) \ 245 || defined(__AVR_ATtiny13A__) \ 246 || defined(__AVR_ATtiny15__) \ 247 || defined(__AVR_ATtiny24__) \ 248 || defined(__AVR_ATtiny24A__) \ 249 || defined(__AVR_ATtiny44__) \ 250 || defined(__AVR_ATtiny44A__) \ 251 || defined(__AVR_ATtiny84__) \ 252 || defined(__AVR_ATtiny25__) \ 253 || defined(__AVR_ATtiny45__) \ 254 || defined(__AVR_ATtiny48__) \ 255 || defined(__AVR_ATtiny85__) \ 256 || defined(__AVR_ATtiny261__) \ 257 || defined(__AVR_ATtiny261A__) \ 258 || defined(__AVR_ATtiny461__) \ 259 || defined(__AVR_ATtiny461A__) \ 260 || defined(__AVR_ATtiny861__) \ 261 || defined(__AVR_ATtiny861A__) \ 262 || defined(__AVR_ATtiny88__) 264 #define SLEEP_MODE_IDLE 0 265 #define SLEEP_MODE_ADC _BV(SM0) 266 #define SLEEP_MODE_PWR_DOWN _BV(SM1) 267 #define SLEEP_MODE_PWR_SAVE (_BV(SM0) | _BV(SM1)) 269 #define set_sleep_mode(mode) \ 271 _SLEEP_CONTROL_REG = ((_SLEEP_CONTROL_REG & \ 272 ~(_BV(SM0) | _BV(SM1))) | (mode)); \ 275 #elif defined(__AVR_ATtiny2313__) \ 276 || defined(__AVR_ATtiny2313A__) \ 277 || defined(__AVR_ATtiny4313__) 279 #define SLEEP_MODE_IDLE 0 280 #define SLEEP_MODE_PWR_DOWN (_BV(SM0) | _BV(SM1)) 281 #define SLEEP_MODE_STANDBY _BV(SM1) 283 #define set_sleep_mode(mode) \ 285 _SLEEP_CONTROL_REG = ((_SLEEP_CONTROL_REG & \ 286 ~(_BV(SM0) | _BV(SM1))) | (mode)); \ 289 #elif defined(__AVR_AT94K__) 291 #define SLEEP_MODE_IDLE 0 292 #define SLEEP_MODE_PWR_DOWN _BV(SM1) 293 #define SLEEP_MODE_PWR_SAVE (_BV(SM0) | _BV(SM1)) 295 #define set_sleep_mode(mode) \ 297 _SLEEP_CONTROL_REG = ((_SLEEP_CONTROL_REG & \ 298 ~(_BV(SM0) | _BV(SM1))) | (mode)); \ 301 #elif defined(__AVR_ATtiny26__) \ 302 || defined(__AVR_ATtiny43U__) 304 #define SLEEP_MODE_IDLE 0 305 #define SLEEP_MODE_ADC _BV(SM0) 306 #define SLEEP_MODE_PWR_DOWN _BV(SM1) 307 #define SLEEP_MODE_STANDBY (_BV(SM0) | _BV(SM1)) 309 #define set_sleep_mode(mode) \ 311 _SLEEP_CONTROL_REG = ((_SLEEP_CONTROL_REG & \ 312 ~(_BV(SM0) | _BV(SM1))) | (mode)); \ 315 #elif defined(__AVR_AT90PWM216__) \ 316 || defined(__AVR_AT90PWM316__) \ 317 || defined(__AVR_AT90PWM81__) 319 #define SLEEP_MODE_IDLE 0 320 #define SLEEP_MODE_ADC _BV(SM0) 321 #define SLEEP_MODE_PWR_DOWN _BV(SM1) 322 #define SLEEP_MODE_STANDBY (_BV(SM1) | _BV(SM2)) 324 #define set_sleep_mode(mode) \ 326 _SLEEP_CONTROL_REG = ((_SLEEP_CONTROL_REG & \ 327 ~(_BV(SM0) | _BV(SM1) | _BV(SM2))) | (mode)); \ 330 #elif defined(__AVR_AT90CAN128__) \ 331 || defined(__AVR_AT90CAN32__) \ 332 || defined(__AVR_AT90CAN64__) \ 333 || defined(__AVR_AT90PWM1__) \ 334 || defined(__AVR_AT90PWM2__) \ 335 || defined(__AVR_AT90PWM2B__) \ 336 || defined(__AVR_AT90PWM3__) \ 337 || defined(__AVR_AT90PWM3B__) \ 338 || defined(__AVR_AT90USB162__) \ 339 || defined(__AVR_AT90USB82__) \ 340 || defined(__AVR_AT90USB1286__) \ 341 || defined(__AVR_AT90USB1287__) \ 342 || defined(__AVR_AT90USB646__) \ 343 || defined(__AVR_AT90USB647__) \ 344 || defined(__AVR_ATmega128__) \ 345 || defined(__AVR_ATmega1280__) \ 346 || defined(__AVR_ATmega1281__) \ 347 || defined(__AVR_ATmega1284P__) \ 348 || defined(__AVR_ATmega128RFA1__) \ 349 || defined(__AVR_ATmega16__) \ 350 || defined(__AVR_ATmega16A__) \ 351 || defined(__AVR_ATmega162__) \ 352 || defined(__AVR_ATmega164A__) \ 353 || defined(__AVR_ATmega164P__) \ 354 || defined(__AVR_ATmega165__) \ 355 || defined(__AVR_ATmega165A__) \ 356 || defined(__AVR_ATmega165P__) \ 357 || defined(__AVR_ATmega168__) \ 358 || defined(__AVR_ATmega168A__) \ 359 || defined(__AVR_ATmega168P__) \ 360 || defined(__AVR_ATmega169__) \ 361 || defined(__AVR_ATmega169A__) \ 362 || defined(__AVR_ATmega169P__) \ 363 || defined(__AVR_ATmega169PA__) \ 364 || defined(__AVR_ATmega16HVA__) \ 365 || defined(__AVR_ATmega16HVA2__) \ 366 || defined(__AVR_ATmega16HVB__) \ 367 || defined(__AVR_ATmega16M1__) \ 368 || defined(__AVR_ATmega16U2__) \ 369 || defined(__AVR_ATmega16U4__) \ 370 || defined(__AVR_ATmega2560__) \ 371 || defined(__AVR_ATmega2561__) \ 372 || defined(__AVR_ATmega32__) \ 373 || defined(__AVR_ATmega323__) \ 374 || defined(__AVR_ATmega324A__) \ 375 || defined(__AVR_ATmega324P__) \ 376 || defined(__AVR_ATmega324PA__) \ 377 || defined(__AVR_ATmega325__) \ 378 || defined(__AVR_ATmega3250__) \ 379 || defined(__AVR_ATmega328__) \ 380 || defined(__AVR_ATmega328P__) \ 381 || defined(__AVR_ATmega329__) \ 382 || defined(__AVR_ATmega329P__) \ 383 || defined(__AVR_ATmega329PA__) \ 384 || defined(__AVR_ATmega3290__) \ 385 || defined(__AVR_ATmega3290P__) \ 386 || defined(__AVR_ATmega32C1__) \ 387 || defined(__AVR_ATmega32HVB__) \ 388 || defined(__AVR_ATmega32M1__) \ 389 || defined(__AVR_ATmega32U2__) \ 390 || defined(__AVR_ATmega32U4__) \ 391 || defined(__AVR_ATmega32U6__) \ 392 || defined(__AVR_ATmega406__) \ 393 || defined(__AVR_ATmega48__) \ 394 || defined(__AVR_ATmega48A__) \ 395 || defined(__AVR_ATmega48P__) \ 396 || defined(__AVR_ATmega64__) \ 397 || defined(__AVR_ATmega640__) \ 398 || defined(__AVR_ATmega644__) \ 399 || defined(__AVR_ATmega644A__) \ 400 || defined(__AVR_ATmega644P__) \ 401 || defined(__AVR_ATmega644PA__) \ 402 || defined(__AVR_ATmega645__) \ 403 || defined(__AVR_ATmega645A__) \ 404 || defined(__AVR_ATmega645P__) \ 405 || defined(__AVR_ATmega6450__) \ 406 || defined(__AVR_ATmega6450A__) \ 407 || defined(__AVR_ATmega6450P__) \ 408 || defined(__AVR_ATmega649__) \ 409 || defined(__AVR_ATmega649A__) \ 410 || defined(__AVR_ATmega6490__) \ 411 || defined(__AVR_ATmega6490A__) \ 412 || defined(__AVR_ATmega6490P__) \ 413 || defined(__AVR_ATmega649P__) \ 414 || defined(__AVR_ATmega64C1__) \ 415 || defined(__AVR_ATmega64HVE__) \ 416 || defined(__AVR_ATmega64M1__) \ 417 || defined(__AVR_ATmega8__) \ 418 || defined(__AVR_ATmega8515__) \ 419 || defined(__AVR_ATmega8535__) \ 420 || defined(__AVR_ATmega88__) \ 421 || defined(__AVR_ATmega88A__) \ 422 || defined(__AVR_ATmega88P__) \ 423 || defined(__AVR_ATmega88PA__) \ 424 || defined(__AVR_ATmega8HVA__) \ 425 || defined(__AVR_ATmega8U2__) 428 #define SLEEP_MODE_IDLE (0) 429 #define SLEEP_MODE_ADC _BV(SM0) 430 #define SLEEP_MODE_PWR_DOWN _BV(SM1) 431 #define SLEEP_MODE_PWR_SAVE (_BV(SM0) | _BV(SM1)) 432 #define SLEEP_MODE_STANDBY (_BV(SM1) | _BV(SM2)) 433 #define SLEEP_MODE_EXT_STANDBY (_BV(SM0) | _BV(SM1) | _BV(SM2)) 436 #define set_sleep_mode(mode) \ 438 _SLEEP_CONTROL_REG = ((_SLEEP_CONTROL_REG & \ 439 ~(_BV(SM0) | _BV(SM1) | _BV(SM2))) | (mode)); \ 442 #elif defined(__AVR_ATxmega16A4__) \ 443 || defined(__AVR_ATxmega16D4__) \ 444 || defined(__AVR_ATxmega32A4__) \ 445 || defined(__AVR_ATxmega32D4__) \ 446 || defined(__AVR_ATxmega64A1__) \ 447 || defined(__AVR_ATxmega64A3__) \ 448 || defined(__AVR_ATxmega64D3__) \ 449 || defined(__AVR_ATxmega128A1__) \ 450 || defined(__AVR_ATxmega128A3__) \ 451 || defined(__AVR_ATxmega128D3__) \ 452 || defined(__AVR_ATxmega192A3__) \ 453 || defined(__AVR_ATxmega192D3__) \ 454 || defined(__AVR_ATxmega256A3__) \ 455 || defined(__AVR_ATxmega256D3__) \ 456 || defined(__AVR_ATxmega256A3B__) 458 #define SLEEP_MODE_IDLE (0) 459 #define SLEEP_MODE_PWR_DOWN (SLEEP_SMODE1_bm) 460 #define SLEEP_MODE_PWR_SAVE (SLEEP_SMODE1_bm | SLEEP_SMODE0_bm) 461 #define SLEEP_MODE_STANDBY (SLEEP_SMODE2_bm | SLEEP_SMODE1_bm) 462 #define SLEEP_MODE_EXT_STANDBY (SLEEP_SMODE2_bm | SLEEP_SMODE1_bm | \ 465 #define set_sleep_mode(mode) \ 467 _SLEEP_CONTROL_REG = ((_SLEEP_CONTROL_REG & \ 468 ~(SLEEP_SMODE2_bm | SLEEP_SMODE1_bm | SLEEP_SMODE0_bm)) | (mode)); \ 471 #elif defined(__AVR_AT90SCR100__) 473 #define SLEEP_MODE_IDLE (0) 474 #define SLEEP_MODE_PWR_DOWN _BV(SM1) 475 #define SLEEP_MODE_PWR_SAVE (_BV(SM0) | _BV(SM1)) 476 #define SLEEP_MODE_STANDBY (_BV(SM1) | _BV(SM2)) 477 #define SLEEP_MODE_EXT_STANDBY (_BV(SM0) | _BV(SM1) | _BV(SM2)) 479 #define set_sleep_mode(mode) \ 481 _SLEEP_CONTROL_REG = ((_SLEEP_CONTROL_REG & \ 482 ~(_BV(SM0) | _BV(SM1) | _BV(SM2))) | (mode)); \ 485 #elif defined(__AVR_ATA6289__) 487 #define SLEEP_MODE_IDLE (0) 488 #define SLEEP_MODE_SENSOR_NOISE_REDUCTION (_BV(SM0)) 489 #define SLEEP_MODE_PWR_DOWN (_BV(SM1)) 491 #define set_sleep_mode(mode) \ 493 _SLEEP_CONTROL_REG = ((_SLEEP_CONTROL_REG & \ 494 ~(_BV(SM0) | _BV(SM1) | _BV(SM2))) | (mode)); \ 499 #error "No SLEEP mode defined for this device." 512 #if defined(__DOXYGEN__) 521 #define sleep_enable() \ 523 _SLEEP_CONTROL_REG |= (uint8_t)_SLEEP_ENABLE_MASK; \ 529 #if defined(__DOXYGEN__) 534 extern void sleep_disable (
void);
538 #define sleep_disable() \ 540 _SLEEP_CONTROL_REG &= (uint8_t)(~_SLEEP_ENABLE_MASK); \ 550 #if defined(__DOXYGEN__) 556 #define sleep_cpu() \ 558 __asm__ __volatile__ ( "sleep" "\n\t" :: ); \ 564 #if defined(__DOXYGEN__) 566 extern void sleep_mode (
void);
570 #define sleep_mode() \ 580 #if defined(__DOXYGEN__) 582 extern void sleep_bod_disable (
void);
586 #if defined(BODS) && defined(BODSE) 588 #define sleep_bod_disable() \ 591 __asm__ __volatile__("in %[tempreg], %[mcucr]" "\n\t" \ 592 "ori %[tempreg], %[bods_bodse]" "\n\t" \ 593 "out %[mcucr], %[tempreg]" "\n\t" \ 594 "andi %[tempreg], %[not_bodse]" "\n\t" \ 595 "out %[mcucr], %[tempreg]" \ 596 : [tempreg] "=&d" (tempreg) \ 597 : [mcucr] "I" _SFR_IO_ADDR(MCUCR), \ 598 [bods_bodse] "i" (_BV(BODS) | _BV(BODSE)), \ 599 [not_bodse] "i" (~_BV(BODSE))); \ #define sleep_enable()
Put the device in sleep mode.
Definition: sleep.h:521
#define sleep_cpu()
Put the device into sleep mode.
Definition: sleep.h:556
AVR device-specific IO Definitions.
