rtems-4.11.3
libnetworking
net
raw_cb.h
1
2
* Copyright (c) 1980, 1986, 1993
3
* The Regents of the University of California. All rights reserved.
4
5
6
* modification, are permitted provided that the following conditions
7
* are met:
8
* 1. Redistributions of source code must retain the above copyright
9
* notice, this list of conditions and the following disclaimer.
10
* 2. Redistributions in binary form must reproduce the above copyright
11
* notice, this list of conditions and the following disclaimer in the
12
* documentation and/or other materials provided with the distribution.
13
* 4. Neither the name of the University nor the names of its contributors
14
* may be used to endorse or promote products derived from this software
15
* without specific prior written permission.
16
17
* THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
18
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
19
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20
* ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
21
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
22
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
23
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
24
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
25
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
26
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
27
* SUCH DAMAGE.
28
29
* @(#)raw_cb.h 8.1 (Berkeley) 6/10/93
30
* $FreeBSD: src/sys/net/raw_cb.h,v 1.19 2005/01/07 01:45:35 imp Exp $
31
32
33
34
#ifndef _NET_RAW_CB_H_
35
#define _NET_RAW_CB_H_
36
37
sys/socket.h
38
39
#include <sys/queue.h>
40
41
42
* Raw protocol interface control block. Used
43
* to tie a socket to the generic raw interface.
44
45
struct
rawcb
46
LIST_ENTRY(
rawcb
) list;
47
struct
socket
*rcb_socket;
/* back pointer to socket */
48
struct
sockaddr
*rcb_faddr;
/* destination address */
49
struct
sockaddr
*rcb_laddr;
/* socket's address */
50
struct
sockproto
rcb_proto;
/* protocol family, protocol */
51
52
53
#define sotorawcb(so) ((struct rawcb *)(so)->so_pcb)
54
55
56
* Nominal space allocated to a raw socket.
57
58
#define RAWSNDQ 8192
59
#define RAWRCVQ 8192
60
61
#ifdef _KERNEL
62
extern
LIST_HEAD(rawcb_list_head,
rawcb
) rawcb_list;
63
64
int
raw_attach(
struct
socket
int
65
void
raw_ctlinput(
int
struct
sockaddr
void
66
void
raw_detach(
struct
rawcb
67
void
raw_disconnect(
struct
rawcb
68
void
raw_init(
void
69
void
raw_input(
struct
mbuf
70
struct
sockproto
struct
sockaddr
struct
sockaddr
71
int
raw_usrreq(
struct
socket
72
int
struct
mbuf
struct
mbuf
struct
mbuf
73
#endif
74
75
#endif
sockproto
Definition:
socket.h:190
socket
Definition:
socketvar.h:49
sockaddr
Definition:
socket.h:180
rawcb
Definition:
raw_cb.h:46
mbuf
Definition:
mbuf.h:103
socket.h
