prioritybitmap.h
1
10 /*
11  * COPYRIGHT (c) 1989-2010.
12  * On-Line Applications Research Corporation (OAR).
13  *
14  * The license and distribution terms for this file may be
15  * found in the file LICENSE in this distribution or at
16  * http://www.rtems.org/license/LICENSE.
17  */
18
19 #ifndef _RTEMS_SCORE_PRIORITYBITMAP_H
20 #define _RTEMS_SCORE_PRIORITYBITMAP_H
21
22 #include <rtems/score/cpu.h>
23
24 #ifdef __cplusplus
25 extern "C" {
26 #endif
27
35 /*
36  * The definition of the Priority_bit_map_Word type is CPU dependent.
37  *
38  */
39
40 typedef struct {
45  Priority_bit_map_Word major_bit_map;
46
55  Priority_bit_map_Word bit_map[ 16 ];
57
62 typedef struct {
64  Priority_bit_map_Word *minor;
66  Priority_bit_map_Word ready_major;
68  Priority_bit_map_Word ready_minor;
70  Priority_bit_map_Word block_major;
72  Priority_bit_map_Word block_minor;
74
77 #ifdef __cplusplus
78 }
79 #endif
80
81 #endif
82 /* end of include file */
Definition: prioritybitmap.h:40
This is the priority bit map ready mask.
Definition: prioritybitmap.h:66
This is the priority bit map block mask.
Definition: prioritybitmap.h:70
Definition: prioritybitmap.h:72
Priority_bit_map_Word * minor
This is the address of minor bit map slot.
Definition: prioritybitmap.h:64
Definition: prioritybitmap.h:68
Each sixteen bit entry in this word is associated with one of the sixteen entries in the bit map...
Definition: prioritybitmap.h:45
The following record defines the information associated with each thread to manage its interaction wi...
Definition: prioritybitmap.h:62
