| int | pci_cfg_r8 (pci_dev_t dev, int ofs, uint8_t *data) |
| int | pci_cfg_r16 (pci_dev_t dev, int ofs, uint16_t *data) |
| int | pci_cfg_r32 (pci_dev_t dev, int ofs, uint32_t *data) |
| int | pci_cfg_w8 (pci_dev_t dev, int ofs, uint8_t data) |
| int | pci_cfg_w16 (pci_dev_t dev, int ofs, uint16_t data) |
| int | pci_cfg_w32 (pci_dev_t dev, int ofs, uint32_t data) |
| void | pci_modify_cmdsts (pci_dev_t dev, uint32_t mask, uint32_t val) |
| int | pci_access_drv_register (struct pci_access_drv *drv) |
| struct pci_access_drv | pci_access_ops |
| struct pci_access_drv pci_access_ops |
