rtems-4.11.3
libnetworking
opt_tcpdebug.h
1
/* intentionally empty file */
2
3
4
* Uncomment the following line to turn on debug code. When you define
5
* this symbol, tcp_trace() is called. If you want tcp_trace() to
6
* print, then you need to edit netinet/tcp_debug to set the variable
7
* "tcpconsdebug" to 1.
8
9
10
11
#define TCPDEBUG
12
